'05 TL, P0958 code...
Old Aug 27, 2010 | 03:32 PM
camosilver's Avatar
4th Gear
i have an 05 tl that has a code for P0958 Auto Shift Manual Mode Circuit High. when i try to do the shift selector mode, the D for drive flashes and the CEL comes on. i have read that this means i need to replace the pin shift selector switch, part # 35740-SEC-A82. found a place that sells it for $38, but, i have not found anywhere that tells where this is located so i can replace it myself.
any input would be great.
thanks!
Old Aug 29, 2010 | 06:33 PM
camosilver's Avatar
4th Gear
anyone?
Old Aug 29, 2010 | 07:34 PM
nfnsquared's Avatar
It's under the center console just in front of the shift lever:
Also, part #2 in this diagram:
http://www.acurapartswarehouse.com/o...gPicture=False
There are several DIY and even a video or two on how to remove the center console in the 3 G Garage. Use this link to find the Garage and other valuable info:
https://acurazine.com/forums/3g-tl-problems-fixes-114/check-these-sources-out-if-youre-having-problem-just-want-learn-something-767930/
Old Aug 30, 2010 | 03:15 PM
camosilver's Avatar
4th Gear
thank you very much, i ordered the part and will be installing it soon. thanks again!
Old Jun 24, 2011 | 09:12 AM
Tegnut's Avatar
Camosilver, Were you able to fix your P0958 with this part? I have the same problem and I wanted to make sure I get the right part. Did you tackle this yourself? Was it hard? Thanks for your help.
Old Mar 8, 2012 | 04:42 PM
Acura Girl 2005's Avatar
3rd Gear
Seeking that same part!
Hey Camosilver,
I am looking for this exact same part! I've tried looking at on-line distributors, and they tell me it a part onlt a dealership can order.
How / where did you find this part?
Thanks!
Old Jan 16, 2013 | 02:14 PM
jason0119135's Avatar
i am having the same issue w/ the D light blinking with CEL. did you guys fix the issue with the new part 35740-SEC-A82? thanks.
Old Oct 3, 2016 | 03:29 PM
Yordan1k's Avatar
P0958 Manual Shifter Switch
Does anyone have a link or video on how to replace the switch, my mechanic personally told me its under the shifter / center console, but before I tare out my car I want to know a little more ..please and thank you
new to the forum
#j32 3rd gen 05 tl
Old Oct 4, 2016 | 11:05 AM
alexb92's Avatar
new to the forum
#j32 3rd gen 05 tl
Old Apr 13, 2018 | 02:11 PM
Frankie J Feliciano's Avatar
thanks!
could you send me the link where you purchased it?
Old Apr 13, 2018 | 02:50 PM
Yordan1k's Avatar
honestly I found it through Offer up , they totaled my car last year , I have the link in another phone
Old Apr 13, 2018 | 03:13 PM
thanks!
Originally Posted by Acura Girl 2005
Hey Camosilver,
Thanks!
oh ok thanks
Old Apr 13, 2018 | 10:23 PM
Yordan1k's Avatar
https://www.acurapartswarehouse.com/...0-sec-a82.html
there you go ! It’s not as cheap as I got it but still affordable 👌🏽
acufan1
Dec 14, 2018 05:47 AM
Spankytaco
1G TL (1996-1998)
May 23, 2015 10:36 AM
lankanboy1
Mar 8, 2012 05:26 PM
Tegnut
Jun 19, 2011 01:12 PM
bigeshorte45
Jan 19, 2009 11:56 AM
