'05 TL not downshifting :( !!!!!!!!
Old Apr 18, 2011 | 11:57 PM
mark0135's Avatar
Angry '05 TL not downshifting :( !!!!!!!!
when i drive at 40mph and floor it , my car used to downshift into 2nd , now it seems like its not downshifting properly ie into 3rd instead of 2nd , it accelerates just wont downshift properly, any ideas???? , already changed oil, air filter, spark plugs, added gumout injector cleaner, intake cleaner
Old Apr 19, 2011 | 12:36 PM
csmeance's Avatar
the car adapts to the way you drive; if you constantly drive it like your racing it, at 50% throttle it'll shift to the lowest gear and get you going. However if you drive like "grandma" a bit of the time it'll only downshift a gear or two.
Try this:
Get in the car and turn it on; turn off all accessories such as A/C, radio, heater, etc.
Then turn the car off.
Then put the car in "position 2" where the lights and such are on but the motor isn't.
hold the gas pedal to the floor for about 30 seconds.
after that turn off the car, then turn on to where the motor cranks and is running. Take it for a spirited drive. This resets the transmission learning so you'll have a fresh slate.
Old Apr 19, 2011 | 02:47 PM
Majofo's Avatar
good info csmeance!
out of curiosity, how many miles do you have on your TL OP?
Old Apr 19, 2011 | 07:48 PM
tones160's Avatar
[x] FWCC [x]
wow good info here, i definitely need to remember this lol.
Old Apr 19, 2011 | 10:19 PM
mark0135's Avatar
mine has about 72,000+
Old Apr 19, 2011 | 10:21 PM
mark0135's Avatar
i always drive fast , always thats why im concerned that its not reacting the same way
Old Apr 20, 2011 | 03:25 PM
lowbudgetTL's Avatar
Yeah... Been having the same problem off and on for a while.
I've reset the ECU a few times/switched out the 3rd and 4th tranny switches. But I'm still having intermittant problems with the down-shifting
I'm thinking it could be:
1. Solenoid assy., AT shift lock 54040-sec-A81
2. Switch assy., Parking Pin & shift 35740-sec-A82
Before I replace above parts..... I'm going to take them out and clean with electric cleaner and see if that might due the trick
Old Apr 20, 2011 | 03:47 PM
RU_JELLY's Avatar
Redwood Original
sure am glad i got a six speed. :p
Old Apr 20, 2011 | 04:09 PM
mark0135's Avatar
How do you reset the ecu?
Old Apr 20, 2011 | 05:29 PM
SpiderX1016's Avatar
Yup, first thing I'd do is reset the ECU and csmeance already mentioned it in the thread.
Originally Posted by csmeance
Try this:
Old Apr 20, 2011 | 10:39 PM
mark0135's Avatar
tried that today, still nothing...... acceleration is still not what it was a few months ago, is car supposed to display any kind of message?
Old Mar 8, 2012 | 04:48 PM
Acura Girl 2005's Avatar
3rd Gear
Seeking Parts
Hey,
Where were you able to order the 35740-SEC-A82 part? I have a p0958 code coming up, marking that part as an easy fix. Had a kid spill jalepeno juice down the shifter. Took the area apart, cleaned it...all is shifting fine, but the code stands.
Any direction would be greatly appreciated!
Thanks!
Old Mar 9, 2012 | 04:36 PM
I hate cars's Avatar
Originally Posted by Acura Girl 2005
Hey,
Thanks!
If everything functions fine, clearing the code should be all that's needed.
Old Dec 15, 2018 | 05:23 PM
Hansell M Disla's Avatar
My car has a p0816 code the d light blink and the check engine is on
hello i have a p0816 code in my acura tl the d light is blinking and the check engine is on i already changed the 3rd and 4th gear switch and the dual pressure solenoid but the problem is still there any idea of what could be a guy told me to try the transmission gear selection switch but iam confused about that parts if someone knows the parts number for this i will appreciated thank you.
Old Dec 15, 2018 | 05:29 PM
Midnight Mystery's Avatar
Null and proud of it
If you floor it from a stop does it feel strong? Or, go 40 then put it into 2nd via slap shift, then floor it... Something to try, I guess...
Mike Pilipenko
Mar 26, 2024 09:21 PM
kixo
Sep 5, 2015 08:54 PM
mrlemonjello
Sep 1, 2015 08:52 PM
Crazy Bimmer
May 2, 2010 06:34 PM
Universe93B
Mar 28, 2001 08:43 PM
