05 TL knock
Old Apr 11, 2021 | 10:27 AM
oldfaithful's Avatar
05 TL knock
Has anybody had rod knock with one of these cars? Has a noise that really sounds like knock coming from what I think is the passenger side of the engine, always had regular synthetic oil changes, approx 160k miles. I have seen a few videos of timing belt tensioner ls that fail and sound kind of similiar. When cold started it seems quiet for about 15 seconds and then the noise starts up. I don’t believe it is Piston slap because it stays until the engine is right up to operating temp. Thanks
Old Apr 11, 2021 | 10:29 AM
The only way to find out is to dive right in, and we can't do that for you
Old Apr 11, 2021 | 12:56 PM
Just wondering if anybody has spun bearings in these engines and if it’s a common thing. Didn’t really think it would be. Tensioner failure looks somewhat common
Old Apr 11, 2021 | 01:06 PM
a spun bearing is not impossible...
meaning; lack of oil, high RPMS and excessive heat can cause a spun bearing...
Did that happen in your case?
it would be a case by case basis...so it's not impossible.. it can and will happen.
but in general, no...it's not a common occurrence.
and the only way to find out if one spun a bearing would be to tear down the engine.
the only way to figure out where your noise is coming from is to dive right in...the easiest place to start would be the tensioners and crank pulley..
so check the pulleys out...
Old Apr 11, 2021 | 01:08 PM
horseshoez's Avatar
Latent car nut
Short of running the engine low on oil, no, spun bearings are not even remotely common with J-Series engines, in fact, they are well known for running hundreds of thousands of miles with just basic maintenance.
Old Apr 11, 2021 | 05:55 PM
Acura TL Builder's Avatar
Gotta love the JSeries!
- Hype man
Old Apr 16, 2021 | 03:37 PM
phyyr's Avatar
gotta post a vid or sound clip to get even a ballpark guess. maybe just serp belt, power steering, or TB tensioner as mentioned?
Old Apr 16, 2021 | 05:12 PM
If your 3G is knocking, let it in...
TCM 01 CL-S
Jun 26, 2018 02:34 AM
dyang17
Jun 27, 2017 09:52 PM
fam
Feb 15, 2015 10:05 PM
Soriano4life
Feb 11, 2014 04:09 PM
Ruserious
1G TSX Problems & Fixes
May 9, 2006 11:23 PM
