'05 Acura TL airbag light
If you have nav, you can look in your messages and it should tell you the diagnostic code. I think it was under messages. It's somewhere in the nav.
I had an intermittent airbag light showing the code 42-1, which indicates a problem with the front right impact sensor. It was only a $37 part to replace.
The seat belts tend to give an intermittent problem too. Some people have gotten the dealer to fix the seat belt problem for free since the seat belts have a lifetime warranty. Other people haven't been so lucky.
Here's a link to how I recently fixed my airbag light. It hasn't come back on since.
https://acurazine.com/forums/problem...cement-931465/
Registered but harmless
Received 1,106 Likes
However, the SRS lights up, then goes off and stays off if the driver's belt is put on before the ignition is turned on. I think it's a buckle problem.
Compressed air has helped others whose buckles had debris causing the SRS light.
Try that with your car to see if it might be the buckle.
I have the same issue. Airbag light was on when I bought the car, it went away a couple times but right now it's on. I don't really know how to proceed since the dealer wants 100$ just for getting the damn code and then I can't find any information about possibly having the issue covered since I'm in Canada and information seems hard to find :S
Registered Bunny
Once you have the code it's time to troubleshoot.
Registered Bunny
You can also use a $5 tool to reset the SRS DTC if you can fix the issue yourself but don't want to pay for someone to reset it for you (07PAZ-0010100, or paperclip haha). Although if you find someone to read it for you cheap and you can fix the issue yourself, they'll probably won't mind resetting it for you for a small price.
Registered Bunny
It's a DTC (Diagnostic Trouble Code), not a CEL/MIL that you can use OBD2 to troubleshoot. You need a HDS (Honda Diagnostic System) to get them.
I said "like any other code" because it's a DTC like all other DTC. Sorry for the confusion.
Thanks for the info man. I'm not super knowledgeable when it comes to those things do your help is really appreciated.
If I remember correctly you're from MTL right? Do you have a trusted Honda guy nearby? I go to a place in Repentigny, the guy is great and is recommended by lots of people but he's far :S
Registered Bunny
Where are you in Montreal? I can always ask around.
The Honda guy I was talking about used to work at Lallier but started his own place a couple years back. He's a little expensive for an independent though but I think I'm gonna have to pay him a visit...
Where are you in MTL? East? West?
Registered Bunny
I actually have family at Lallier. I go there as much as I can but since I live in west Montreal it's real far. Luciani acura is right by my place but I don't trust anyone there except the parts guy.
I'm outside Montreal anyway. On the north shore, Boisbriand more precisely. It's just easier to say Montreal since I end up there a few days a week anyway.
I thought you'd be more west than that the way you talked. Repentigny is 30 minutes by the 40, unless you actually drive 70km/h...
You work in MTL? Do you work in something car related in order to be able to do all of your work yourself?
Registered Bunny
And no, I've learned from my experiences. Lots of DIY, lots of friends who know and knew more than me, an uncle who helps me with the big jobs and a big dose of patience. I buy the tools I need as I go.
In the end cars are like lego bricks. Rusty, expensive, dangerous lego bricks.
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
