05 6MT revving/acceleration/transmission issue?
Old May 13, 2018 | 01:30 AM
Hi, it's been years since I've posted here. I have an issue with my 05 6MT that I've owned for the last 10 years. It's a little hard to describe, so please bear with me.
When I accelerate in 3rd or 4th gear going around 25-30 mph, engine RPM would go start going up by ~1000 RPMs, then it should drop ~500 RPMs, then start going up again. This is without me changing and pressure on the gas pedal, feels like the car hesitates. This issue happens in other gears as well, but most prominent in 3rd and 4th.
The problem is always re-producible, but also some times something different happens. I would be in 3/4/5th gear, I step on the gas pedal, the RPMs would keep going up (to redline), but the car is not accelerating. Almost like it's not even in gear, even though it's been in gear and all I did was try to accelerate. This doesn't always happen, but happens most when the car is cold.
There's no check engine light or anything else wrong, but I already changed the APPS sensor and MAS sensor. Didn't help at all.
Any help here is appreciated. Thanks!
Old May 13, 2018 | 08:30 AM
MyGuti's Avatar
Your clutch is slipping....time for a new replacement
Old May 13, 2018 | 10:07 PM
Jackass's Avatar
As already stated...clutch is done. If RPMs are going up and the vehicle isn't accelerating, it is in gear and clutch pedal is released, there are only a couple of things that could be happening:
1.) Tires are spinning
2.) Axle is broken
3.) Clutch is slipping
Pretty sure #1 you would know. #2 you would really be going anywhere. So that leaves #3.
Old May 14, 2018 | 01:33 AM
nick_rp's Avatar
Had an issue like this on an automatic. Was low trans fluid after service. Topped it off and issue was gone.
just something else easy to check
cheers
Old May 14, 2018 | 08:07 AM
Jackass's Avatar
cheers
OP doesn't have an auto and trans fluid level has no role in power delivery in a MT.
Old May 14, 2018 | 08:11 AM
nick_rp's Avatar
oops. I saw the "6MT" but it didn't register in my head. Keep on keepin on
Old May 14, 2018 | 08:13 AM
horseshoez's Avatar
Latent car nut
I third the motion, the clutch is toast.
Old May 14, 2018 | 11:39 PM
Thanks guys. Looks like time for a new clutch. 120k on the original clutch isn't too bad.
Old May 15, 2018 | 02:56 PM
DMZ's Avatar
DMZ
Head a da Family
Get the LUK clutch kit from rockauto. Take it from 1st hand experience here, make sure you replace the flywheel at the same time, not much more money. Rockauto has those also by LUK.
alexpapas90
Dec 3, 2017 11:33 PM
paperboy42190
Oct 22, 2013 11:05 PM
jdmaszfcuk
2G TSX Performance Parts & Modifications
Feb 25, 2013 10:39 AM
MinTS
2G CL Problems & Fixes
17
Dec 6, 2011 05:49 PM
