04 TL - Rough starting
Old Nov 14, 2010 | 02:22 AM
ezol's Avatar
I have a 2004 TL with 99k km. I just got the car 2 months ago and noticed when I start the car in the morning it kind of has a rough start. I have no issues cranking it over and it never stalls on me. But it's just not 'smooth' when starting. It kind of shakes a little. However, the car drives smooth and haven't had any issues.
Additional Notes: I'm not sure when the last time the spark plugs have been changed. I did a B2 Service 1 month ago. Like I said, I only had the TL for about 2 months now.
Old Nov 14, 2010 | 05:48 AM
Turbonut's Avatar
Depending on the severity, but a slight vibration/roughness is normal with the elevated idle speed..
A search will provide all day reading, but here's one to start:
https://acurazine.com/forums/showthr...ht=cold+start+
Old Nov 14, 2010 | 06:43 AM
VQPower37's Avatar
thats normal ... most tl's if they have been sitting over night in the cold, they start a little rough, and like u said after getting to operating temps they run smooth as butter
Old Nov 14, 2010 | 07:19 AM
Ruby's Avatar
US Navy Seabees
mine does this as well. Seems like if its a cold start, it fires up nicely. But if its been warmed up it shakes and stutters a bit before firing up. Maybe the starter?
Old Nov 14, 2010 | 09:25 AM
Babnik's Avatar
Mine does it too. I mentioned it at the dealership and they said it was normal and even brand new ones did it. I think it has something to do with the computer intentionally delaying the starting in order to reduce wear and tear, tho I'm not sure how that would work.
Old Nov 14, 2010 | 09:37 AM
MofroS's Avatar
Saysdamnalot
I bought mine used - from day one I just did not think that it started the way you would expect a 3.5 RL engine to. They cleaned the throttle body. That helped a bit. But after that, the issue seemed to slowly reappear. Complained about it again when my transmission went out. Have not asked them what the repair was, but it has helped quite a bit. It was listed on the invoice as:
11 Engine Minor - 18927 CA
Someone may be able to cross-reference that and give you some insight as to possible alleviation of the issue. I know we are talking different year model/engines though...
Old Nov 14, 2010 | 09:50 AM
VQPower37's Avatar
maybe to get the oil flowing faster? ... i know that it idles higher to get everything to proper operating temps faster, so that may add to the rough start. i would think as long as it smoothens out in time ur good to go. if it idles rough after its heated up, then you may have some other problems to look into
Old Nov 14, 2010 | 09:53 AM
jwerks's Avatar
8th Gear
Lol mine does the same thing but I know its just cuz the cold starting
Old Nov 14, 2010 | 12:14 PM
ezol's Avatar
Should it still start rough when it's not cold? My car is parked underground..
Old Nov 14, 2010 | 02:45 PM
Ruby's Avatar
US Navy Seabees
Damn dude, your tranny went out? Is that common on 3G Type-S's?
Old Nov 14, 2010 | 06:30 PM
Hi speed's Avatar
runnin a little boost
The engine intentionally mis fires to throw raw gas on the cats to assist in getting the cats warmed up and working. My afr gauge catches the tail end of it since it takes 15 or so seconds to warm up itself.
Old Nov 15, 2010 | 07:45 PM
I hate cars's Avatar
I wasn't going to bother posting but you're right. We have one of these threads once a week and judging by the responses you would think these guys had never read one of them.
Old Nov 18, 2010 | 09:20 PM
blkfeet's Avatar
it has to do with the smog sensors on your tl. the car is trying to reduce it. its normal
Old Nov 19, 2010 | 07:48 PM
MofroS's Avatar
Saysdamnalot
Yeah, man. At 48k. Just before warranty. I do not think it is common at all on the 07-08.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
scionxb3003
Sep 14, 2015 01:52 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
