'04 TL code questions
Old Jun 17, 2019 | 09:41 AM
skierz's Avatar
'04 TL with 179K miles is throwing the following codes:
25-1 YAW rate sensor malfunction
61-1 battery voltage malfunction
P2197 O2 sensor signal biased / stuck lean Bank 2 Sensor 1
The CEL light is on most of the time as well as the Airbag light on the left side of the speedometer window. Also the car surges fairly consistently while accelerating. Are these codes relative to that? Thanks.
Old Jun 17, 2019 | 10:01 AM
troubleshooting 101, tackle one problem at a time.
figure out the charging issue...bad alternator? bad ground? bad battery?
once you figure that out; the other issues will fall in line and will be easy to diagnose
Old Jun 17, 2019 | 10:56 AM
skierz's Avatar
Thanks justnspace. Being a VERY novice wrencher, what would be the best way to go about checking these things? Bringing it to my (trusted) mechanic? I'd like to avoid that if possible in the spirit of saving $$$.
Old Jun 17, 2019 | 11:21 AM
Replace your battery.
Old Jun 17, 2019 | 11:34 AM
I'd start with the battery. How old is it? Is it outputting the correct voltage when the car is off? 12.2-12.4 volts.
Next, i'd check the cables itself. Are they corroded? Are they making good contact with the battery?
Next, look at the ground wires. Are they corroded? Are they making good contact with the chassis?
Then have the alternator checked at AutoZone. Check the ground wires there as well.
ace2525
Mar 8, 2012 01:09 PM
piggydog
Feb 11, 2010 11:05 AM
tsxnation
Apr 19, 2007 03:30 PM
Trevor
Jun 28, 2004 05:23 PM
projextion
Jul 21, 2002 04:43 PM
