'04 to '08 front lower control arm bushing failure - please read and look
#841
^ i THINK so too,
btw eg, if you'd check out the design of these bushings, these are "shaped" the way your black bushing picture is "worn" ...
sohclubkid @ veesix performance says they're designed to allow the 3 axis movement of compliance bushing,, and to me, it sounds right.
here are the pictures
diagram and stock photo belong to superpro
the two other are from sohclubkid's thread, linked above.
** note this picture below is eccentric to allow caster adjustment **
#846
Not sure I even this is even going to go anywhere but does anyone here work with honda/acrua that could answer me this? I'm curious if there is a specific press tool that was ordered to press out the old bushing. Only reason I ask is we have the same kind of issues on subaru bushings and we were able to order up the cup for pressing. Naturally as flat raters we came up with a way to press in and out the bushings on the car without removing the control arm so the job takes us maybe 10 min. and it's a lot easier. Obviously I looked at mine and they are torn. It's not the end of the world but at some point I'd like to at least replace them. I kind of glaced around at our subaru press tools and haven't found anything usable yet. Oh yeah if you can purchase them a part number would be nice. I'd gladly change anyones tl's in the area too for a reasonable price. lol
#847
http://www.harborfreight.com/fwd-fro...ers-66829.html
http://www.autotoolworld.com/product...FelDMgodyTsANQ
Keep us updated if you figure out a way to press the bushings "on the car". AFAIK, no one has been able to do this.
#848
The ride on smooth roads is roughly the same, but more "feel" of the surface through the wheel. Beautiful on the highway, feels really tight. On rough roads, or potholes you definitely feel the impact more through the front end. But as I said I'm in NS Canada and most roads are shit, lol, but I'm quite content with them.
#849
After finding a machine shop that was willing to remove and press in new one for $10 a side, I wouldn't bother going on the mission myself. Removing the Control arm was easy in comparison to trying to use sections of pipe and sockets with a huge vice.
#850
Members have used these tools for pressing the bushings with the control arm removed. Don't know if either one will work without removing the control arm. See post #817 and #819.
Edit2: and another review:
http://www.amazon.com/Schley-SCH6810.../dp/B0079GQLO2
He added a follow-up comment saying that using an impact wrench finally wore out the bolt...The update was done 6 months later. No indication on how many times it was used before it wore out...
glennjr15 (01-06-2017)
#851
does everyone change out the other 2 bushings on the control arm too? i did the compliance bushing and the bushing under the suspension, but not the one that goes towards the subframe, but I did notice it was cracked when I had my lca removed
#853
Also that's basically how we came up with the on car process. We get 3 hrs for replacing the bushings. We started pulling off the control arms and using the press with the proper tool. We then used some press pieces laying around along with a bolt for our wheel bearing kit and made it work to use it while it was on car to get the job done way faster.
#854
Edit: There is now a review for the Schley tool where the user removed the bushings "on the car"....YMMV...
#855
In theory it should be super cheap to piece a tool like that together for one specific purpose. The problem is knowing what size pieces you need, and where to buy them. If someone DOES build their own tool, it would be great if they provided specs on the parts used and possible sources.
BTW: LoL @ the Schley tool kit. It's twice the price and less than half the parts of the Harbor Freight one. I've personally used the Harbor Freight FWD Bearing kit to press bearings and bushings. It's definitely worth the ~$80 even if the screw strips or breaks.
#856
The only reason I ask is the one from auto tool world basically looks exactly like the tool we made for our subaru's at work. Given there is room to leave the ball joint attached and pull out the other two bolts to swing down the arm enough to pop in the tool and bang out that bushing. As long as that is possible like I said before it would only take 10-15 min at a shop to do a bushing job.
#857
Yes, but have you used it for Acura LCA bushings? Do you know for sure that it has the proper size fittings for the LCA bushings? And do you know for sure that the bolt is long enough for it to work "on car"?
#858
compliance, rear, shock, and sway bar bolt undone. (duh..)
but he warned that he risked pulling apart the CV axle and it's the DIYer's fault if that happens. it's on this forum. somewhere.
#859
Urethane will be DESTROYED in this application. They are meant only to allow rotation of the inner sleeve....not deflection or pivot. In fact this is what happens to a poly compensartor bushing after a couple years when it's mounted the "correct" way (from a Civic/Integra):
The Super-pro idea looks like a good compromise, but honestly the Fastline/PCI compliance bearings are really the best, most permanent, no compromise option.
#860
Sweet, maybe I'll order it up sooner rather then later. If anyone is in the surrounding Philly area and wants it done cheaper then the dealers shoot me a pm.
#861
Good point. I have not tried that kit on this specific bushing. I suppose the major factor would be determining if the forcing-screw would even fit through the bolt hole in the bushing. The specialized tool is probably a much safer bet. Though it costs like 5 times as much as having someone press the bushings for you, so it's kind of a difficult sale if you're not a shop.
#862
^^^that was exactly my point.
If the product had been ready when I did mine, I would have gone with Marcus' product.
That said, my new LCA with the window weld has been holding up really well.
#863
#864
Anyone know the diameters required to press out the bushings? On a Honda, its 68mm and 65mm. Is it the same for the TL?
And after re-looking at this, I'm not sure that you can press out the bushing with the control arm still on the car. Sure looks like the lip/flange over the end of the control arm that houses the bushing will prevent this:
#866
So the Harbor Freight kit may work? I'm looking at the 2.90" (73.66mm) bushing and the 2.997" (76.12mm) sleeve. I think the main issue is how deep is the 2.997" sleeve?? In the picture, it looks like the sleeves are deep enough...
#867
Like Eg mentioned, if you're not a shop, why not just have it pressed in/out for you? I'm a die hard diy'er in the sense that I HATE paying for something I can do myself...after the headaches etc...for $20, I'd rather go that route the next time.
#868
But one could buy the HF kit for $87 shipped (with coupon), use it and then resell it in the BM for $60 -$65 (or just keep it). And it allows all the work to be done at home, saving the time it takes to drive to and from a shop with a press and waiting while they try to figure out how to press the bushings out.
It's a very viable option IMO.
#869
^^^true, I guess I'd have gone that route too.
Well, I'm FOS because I DID go that route, I just ended up breaking my buddy's vice 1/2 through the install which added to my frustration. So at the end of it, I was like, FK THAT...should have dropped it off to be pressed and then gone to have a beer.
#870
This isn't necessarily for me. I have access to a lift and press at the base auto hobby shop.
As for the cups being deep enough, that is not a problem. They are designed to press wheel bearings which are thicker than any bushing I've seen on a Honda. They will have plenty of depth.
#871
But that does not mean the suspension is cycling correct. Anyway, if you wanna give the FLP bearings a try let me know.
rockstar143 (02-09-2013)
#872
It all depends on weather or not the forcing screw is narrow enough to fit through the bolt hole in the center of this bushing. The screw in that kit is pretty damn big.
#876
FYI, found a universal ball joint separator that works on Hondas (according to multiple reviews). Only $19 shipped. I'll let you know if it works on the TL in about 2 weeks
http://www.sears.com/kd-tools-univer...-00996404000P?
#877
Don't quote me, nfn, but I'm almost positive that one won't work. I tried using a fork style on the first side and although it probably could have worked, I tore the boot and it's a bishhhhh to replace that boot or balljoint.
Anyway, I had one of these 5 piece kits from advance auto, and the one that ended up working flawlessly because it spreads wide enough to grab the top portion of the wide lower control arm (at the point where the balljoint goes through).
#878
#880
Seems like it's been forever but finally got some bushings that failed inspection today. Took a couple snap shots so you guys can see how the tool is used. It's very easy on subaru's to do it on car but the TL's hopefully should be about the same. At the least the tool is nearly identical just subaru's bushings are smaller.
I mark the control arm which is coincides with the pattern on the inside of the bushing just to make it easy and make sure I install it correctly.
Cup half way though bushing almost out.
Bushing hanging out there and completely out.
New bushing marked at the same spot the old one was marked at on the control arm for correct instal.
Pretty simple. Just hope there is enough swing on the control arm on the TL.
