HYPER VOLTAGE & GROUNDING KIT INSTALL
Old 10-23-2006, 12:39 PM
pohljm's Avatar
Here is the overall view of my Hyper Voltage GT install with DIY ground kit and the ground points I used. unit is mounted with a modified bracket to the underside of the strut bar per the hondatuner article
Path of daisy chain of grounding cables from chassis to motor to alternator to throttle body ending at Hyper Voltage device.
Daisy chain throttle body to Hyper Voltage device
Ground point at chassis and tranny.
ground point at top of motor
Grounding wires are from an auto battery supply house and come in various lengths already made with the connectors in place. $19 for the entire set instead of the $110 thas Sun is asking. The GT kit is a little easier to install since you can terminate your grounding cables to it rather than going to the add on battery post.
Old 06-21-2012, 12:05 AM
jonmizu's Avatar
More info on DIY install please!
Old 06-21-2012, 12:37 AM
UA6
UA6's Avatar
What is this for?
Old 06-21-2012, 05:29 AM
HE>i
05_NBP_TL's Avatar
Holy thread bump!
good thing the OP is still around. maybe he can chime in
Old 06-21-2012, 10:17 AM
Where Did My Garage Go?!!
lucnex's Avatar
I would think so....he linked everyone to this thread from here....
https://acurazine.com/forums/showthr...=859713&page=2
Old 06-21-2012, 11:09 AM
UA6
UA6's Avatar
Originally Posted by 05_NBP_TL
Holy thread bump!
I just noticed it was from 2006. Damn noobs always bumping old threads
Undying Dreams (06-21-2012)
Old 06-21-2012, 12:49 PM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
^At least they are searching
Old 06-21-2012, 12:59 PM
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
Originally Posted by ua6
what is this for?
+1
Old 06-24-2012, 01:04 PM
pohljm's Avatar
The intent is to provide consistent voltage and ground values to all of the sensors and electronics. I did it primarily for upgrading the ground system. I did this in conjunction with a few other mods so I was not able to tell if there was a detectable improvement from just this. I did increase my freeway MPG after said mods. Hodatuner did an article and they documented some improvements. Its not going to be much.
IHC has recently posted a thread where the solution to his poor performance in hot weather has been eliminated by using a high performance battery. These cars are ultra sensitive to voltage and ground issues. I figure I have never had any issues so it may be successful in that way.
Old 06-24-2012, 01:07 PM
pohljm's Avatar
I cannot recall if I ever posted this in the performance mod section, only photo section as thats how I documented it.
Anyway here is a link to old article. http://www.hondatuningmagazine.com/t.../photo_03.html
sockr1 (01-17-2016)
UA6
UA6's Avatar
Thanks for clearing that up even though its an old thread.
Old 06-24-2012, 01:14 PM
pohljm's Avatar
I figured that there are several threads currently that are discussing the issues that people have experienced with weak batteries, or weak grounds so I thought I would share a mod that has kept me free of those issues. And its one that you do not see discussed much. And also supported by a magazine test. also not seen much! TL does not get much aftermarket love.
Old 01-16-2016, 01:55 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Is there any way you can put the pics back up?
Old 01-17-2016, 03:13 PM
pohljm's Avatar
P1020057_zpsrrgcuxcr.jpg Photo by pohljm | Photobucket
sockr1 (01-17-2016)
Old 01-17-2016, 06:07 PM
sockr1's Avatar
Thanks! Which battery supple store did you go to in San Diego?
What gauge wire is that? 4?
Old 01-18-2016, 12:01 PM
pohljm's Avatar
It was over near la mesa. I do not see it now. They did a lot of work with golf carts too?
Old 01-18-2016, 12:48 PM
sockr1's Avatar
hmm yea not sure which store it is. where did you get your hyper voltage box?
Old 09-29-2017, 01:53 PM
314_04TL's Avatar
Thread revival. I need this and have looked and it looks like Sigma Automotive :: Accessories that make your car go cleaner, meaner & greener might still have some by the looks of the site it's super outdated. Anyone know of a good link or a plce where these are still available?
Old 09-29-2017, 02:31 PM
Received 16,260 Likes on 11,971 Posts
I dont know what the little box does, but doesnt have to be that brand...i googled voltage stabilizer and TONS of different branded little boxes come up
Old 09-29-2017, 02:33 PM
googling some more; it's just capacitors.
Old 09-29-2017, 02:36 PM
also, that engine bay is SQUEAKY CLEAN! Pohljm was modding his brand new car!
Old 09-29-2017, 02:42 PM
314_04TL's Avatar
Ok so even if I wanted to try it the cheap ones will suffice
I have seen some kits from some compnay in Tawain called D1 spec and thos kits run like 100 and Buddy club makes one that's 150-180 depending on where you buy it. Of course there are those lovely 20 specials on ebay
Old 09-30-2017, 01:27 PM
pohljm's Avatar
Yes that was a brand new engine bay. I would try the least expensive option. not really much measurable gains
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
ibGTV
09-28-2015 03:40 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: HYPER VOLTAGE & GROUNDING KIT INSTALL
