Would adding another Resonator help?
Old Dec 30, 2017 | 12:54 AM
Acura TL Builder's Avatar
Exclamation Would adding another Resonator help?
Hey all,
I'd like to add one more 22" resonator to my ATLP v2 jpipe, high flow cat. w/ resonator exhaust. This is due to some drone during light acceleration at 2-2.5k RPM. There is no rasp or any other drone at any time with this Exhaust.
Question -
1. Will a second resonator reduce the drone at 2-2.5k rpm, and will it reduce HP/TQ?
2. Would you guys recomend a Helmholtz resonator system to eliminate the 2-2.5k RPM drone?
Old Dec 30, 2017 | 04:17 AM
a resonator is a straight through pipe designed to get rid of certain frequencies...
a Helmholtz resonator always involves a chamber with an open port...where would you put this chamber on the exhaust?
hint* all i did was google the difference between a muffler and a resonator...
then googled for helmholtz resonator...
Old Dec 30, 2017 | 12:17 PM
I went through a tunnel on my way to work this morning and WOT'd. Man the notes were impressive! I can only imagine how it will sound with an added whine!
Thank you for the google Justin.
Old Dec 30, 2017 | 05:10 PM
Scottwax's Avatar
Mr. Detail
What kind of mufflers do you have? Going to a turbo style muffler on my first Accord killed the drone. Same on my G35, cut it way down but didn't totally eliminate it. Considering the Vibrant Ultra quiet resonator for it.
https://www.summitracing.com/parts/vpe-1142/overview/
Old Dec 30, 2017 | 08:41 PM
Thank you sir! I have ATLP mufflers, not sure what the specific company is.
Would I be able to add it along with my ATLP resonator?
Old Dec 30, 2017 | 10:16 PM
Scottwax's Avatar
Mr. Detail
Depends on the room you have underneath.
My current set up is XLR8 v2 J-pipe, Dynomax resonator and mid-muffler delete, precats and cat back are stock. Nice growl when you get on it, zero rasp, zero drone. If I get a catback, going to have it built at a shop that specializes in custom performance exhaust so it stays similarly quiet at cruising speeds. Seems most aftermarket cat backs have at least some drone in them so I'd prefer to stay away from that and not have the issues I'm having with my G35 and having to add a resonator to the y-pipe and replace the muffler like I had to do.
Old Dec 30, 2017 | 11:46 PM
At cruising speeds its almost silent. Its only when I give it very little gas during acceleration from a stop that i can hear it, its not as bad as I'm painting it. I'm accustomed to not hearing any exhaust notes. It sings very well the ATLP does!
Side Note - I raced my against my lil' bros 2008 Acura TL-S today and he beat me; By 3 cars @ 100mph!
Old Jan 3, 2018 | 06:41 AM
a six speed base would have taken care of him.
Old Jan 3, 2018 | 11:34 AM
Ive been thinking to do a 5AT to 6MT swap sometime after the S/C is installed and my CC is paid off.How much do you reckon it will cost?$1.5k - manny tranny$120 - shift linkage$110 - clutch/brake pedals$xxx - Slave cylinder?
Old Jan 3, 2018 | 11:36 AM
I have no clue!
with these cars being as cheap as they are now, i bet you can find everything at the junk yard for pennies.
Old Jan 3, 2018 | 02:55 PM
Do we have a swap guide on here? I'm curious to know the amount of work involved. I'm guessing I would have to change the ECU aswell as the gauge cluster?
Seems like a good amount of money/work, but this will make he car more controllable, fun to drive(though it already is), harness more of the engines power, and get better fuel economy.
How many 6MTs were made in 07-08? Our cars may be cheaper these days but 6MT 07-08 ' is still the holy grail.
wilspainar's Avatar
The vibrant ultra quiet fits find. I have one installed just pasted the Jpipe.
Old Jan 3, 2018 | 04:25 PM
Did you feel any power loss?
Old Jan 3, 2018 | 05:08 PM
EvilVirus's Avatar
You do not lose power from a resonator. Even if you did it is negligible.
azeezp13
Mar 8, 2015 09:17 AM
The Machine
23
Sep 4, 2012 10:33 AM
bigg_86
Mar 11, 2011 10:39 AM
AMGala
Apr 7, 2009 07:52 AM
NOVAwhiteTypeS
Jul 10, 2001 11:37 AM
