Wide band o2 advice
Wide band o2 advice
I need to monitor the afr for nitrous. I know the TL o2 is wideband, so has anyone tapped into them? I can also install AEM wideband on each bank. If you tapped in, where or a wiring diagram would help. For those with a wide band, please describe your install. Thanks in advance. I ideally want one 0-5v output for afr. I don't see how that will happen.
TLOHTL (03-11-2014)
Keep it mind you should also get an AEM FIC if your planning to play with nitrous.
I tried to get the bungs after the y-pipe. The guy told me to put it in on the down pipe. I have always heard that they should be after the y. I did not know since there is a cat before it. The guy did not want to do it after the J-pipe. I guess I won't be going there. And thanks!
soupi
14
11-15-2015 11:15 AM
