UR Crank Pulley on Blown TL Issue??
So I took my UR Crank pulley to be installed to the shop that installed my supercharger and the owner there was adament that it would cause some 'harmonic imbalance' because there wasn't a layer of rubber around the pulley like the stock pulley, so basically it won't be able to absorb the vibrations...
Now I read a bit about this on other threads but do you guys think this will be an issue a couple months down the road???
I would not worry about this as the Tl is internally balanced. This was the story years ago when the Crank was balanced partially by the pulley which is not the case on our motors. I had my underdrive pulley on for over 25k and no problems. I jsut installed the stock diameter for the blower and still no problems. I would not worry.
OMGWTF4THGENTL
Probably not... It's a harmonic dampener not a harmonic balancer. Search also NVH - Noise Harshness and Vibration
Lot's of good reading in the 2nd Gen forums. Do some searching and get some already posted thoughts.
Lots of 2nd Gen postings, since they've been using them longer.
https://acurazine.com/forums/search.php?searchid=367729
kennedy, i actually did read up alot on dampeners/balancers and thats why i didn't think it would be a problem, I wouldn't think a layer of rubber would be all that significant. However, my tech was pretty adament that on a Supercharged Tl it would cause problems down the line.. maybe a couple months.. and he's pretty knowledgable about acuras since that is all he works on.
I don't doubt the product or your advice but i think im thinking i might just play it safe and wait a couple months before installing this i guess
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
OMGWTF4THGENTL
I don't doubt the product or your advice but i think im thinking i might just play it safe and wait a couple months before installing this i guess![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
OMGWTF4THGENTL
Originally Posted by joed40
I'm lost here.
Does he mean the vibration that a rubber belt would produce, or the vibration that would be passed on from the pulley to the rubber belt???![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Some internet theory's think this vibration will cause cause your crank bearings to fail... especially on engines not as well balanced as Honda's.
Originally Posted by Kennedy
The rubber on the stock pulley serves an engine noise/vibration dampener. Replacing it with a UR removeds this capability. Thsi means supposedly, more noise, more vibration, transmitted to the engine, and thus to you.
Originally Posted by special-ed
here we go again.....
There should be sticky's on the most overtalked issues.
![Popcorn](https://acurazine.com/forums/images/smilies/popcorn.gif)
I should have actually waited a few weeks and just waited for feedback from those who HAD it installed on their supercharged TLs.
OHHH WELL LETS WAIT AND SEE.
Former Sponsor
If your mechanic worked on Honda/Acura's then he probably is concerned b/c the B and D series engines do have a crank pulley set up to do more "balancing/damping". The F, J, and I believe the H series have different style crank pulleys with a rubber insert (elastomer). The engines are internally balanced. Even so there are many ppl w/ B and D series engines who run the UR crank pulleys with no issues at all. Sometimes some ppl say there is an issue when running a turbo kit on the B and D series (Civic, Integra) engines but I have yet to see one personally have an issue.
And I have a boosted F series engine (F23A1) running 15 lbs of boost with the UR pulleys and I have no issues at all.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
