Upgraded brake lines
Old Jun 20, 2009 | 05:40 AM
HEATSEEKER's Avatar
Fire/medic
I just replaced my oem brake lines with Goodridge steel braided lines.. Wow what a difference feels like I have a new brake system, and I haven't even upgraded my rotors or pads yet. I would higly recommend it if you looking for a easy way to improve your braking.
Peace out!!!!
Old Jun 20, 2009 | 01:33 PM
TL|GTX's Avatar
A Black TL
How much, and how hard was the install?
Old Jun 20, 2009 | 02:38 PM
SCS15's Avatar
Installing lines is a pretty simple job if your any bit good with hand tools.
Old Jun 20, 2009 | 04:35 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
the improvement in braking is sort of subjective... what I mean is you could have had a little bit of air in the lines and a simple bleed would have been suffice
the only reason I see upgraded brake lines to be needed is when the factory requires replacing
furthermore better fluid w/ oe brake lines is also a cheaper solution
Old Jun 21, 2009 | 03:19 AM
greco9885's Avatar
^i agree. SS lines are mainly just to make the rubber lines not expand and cause a loss of pressure.
Old Jun 21, 2009 | 12:36 PM
HEATSEEKER's Avatar
Fire/medic
the price was a little steep. Acura did it for 200 under the table. they wanted to originally charge me 480. I told them to go pound sand...
Old Jun 26, 2009 | 09:41 PM
andyc123's Avatar
I Have A Meth Lab In
Better fluid, and I'm no expert (but I've done this before) is really all about the boiling point. Unless you REALLY race a lot, you're never going to get to the point of boiling it. I still haven't found any evidence that SS lines do much, not that they don't look pretty cool. If you can lock up your brakes with rubber lines, what's the point of SS lines? It'd be nice to see an objective before/after test with stopping distances.
Old Jun 26, 2009 | 10:29 PM
NAiL05's Avatar
I bought techna fits off a site for 78 or so shipped. I still need to put it on since I am debating what color to powdercoat the calipers then do it all the same time...Anyway if you plan to diy make sure you take those fittings off with a flare nut wrench to prevent stripping of the fitting. A normal wrench will usually round it off.
yesSIR-S
May 13, 2016 05:42 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 17, 2015 08:57 PM
02tljj
Sep 11, 2015 12:37 PM
