Thermo Spacers labor cost
Just got the thermo spacers installed, the shop charged my $180 for a 2 hour job. NUTS!
Could somebody tell me why gaskets costs more to install? Did I get ripped off?
Well- it takes about 1.5 to 2 hours to do normally- and if the intake had gasket stuck to it really bad, or the bolts were stuck or broke, or it was the first one they had ever done and you paid for the learning time........
$90 an hour is close to dealer rates- but in LA who knows- what does the sign showing the labor rate say? Did they quote you less than they charged you? Gave no estimate?
Whats the rest of the story?
I'm pretty sure you got ripped off... it took me about an hour or two to install mine on my own... almost as easy as the intake was to install
www.outlawengineering.com and trying a search will give you all the info you need on them... they're worth the $100, but anything over $50 for an install, you might as well do it yourself
I guess I need to start looking for another mechanic that don't charge based on "different parts".. sigh
How many miles do you have on your 06?
I've got an 06 with low mileage and the gaskets looked like new when I took it all apart.
The installation was really easy and even taking my time, it took less than 2 hrs to install. If those guys had done it before, it should be even less.
I've never heard of anyone charging more when gaskets involved but I try and do everything myself, so maybe that's normal.
i bought the spacer kit, now for a dumb question. I plan on doing it myself but was wondering about the old gasket. do you have to buy a new gasket to or just use a permatex silicone gasket maker. please let me know in a hurry i'm itching to put them on.
Hacker
No, you use the gasket that comes provided with the kit. The point is to NOT use the stock gasket, as that transfers heat really well and is thus what we are trying to avoid by using the thermoplastic one they provide.
You can always use the old gasket as a paper weight, or maybe a tray to serve crackers on.
go back to the shop and tell them what you learned here- and that you will be posting the biz name to warn others~
Your 1 mechanic versus the thousands of aziners and others who understand heat transfer and its effect on engine performance- its the best 100 bucks you can drop on your car
Originally Posted by Pizza4Everyone
i asked auto mechanic and they say thermo spacer really won't help on performance. it's waste of money.
well i just installed the thermo spacers on my 07 tl-s. first of all easy job, i'm no mechanic by any means but this was one easy install. i can't really tell any difference in anything except maybe just a bit better response in mid-range rpm. it might be helping but the type s feels good just the way it is. just my opinion.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
