Stroke to 3.7?
Old Feb 3, 2010 | 10:31 AM
xoulu's Avatar
Stroke to 3.7?
anyone knows anyone who can stroke our TL engines to 3.7
trying to buy RACINGHART03's 3.5 shortblock but would like it to be stroked to 3.7
if anyone knows anyone who can stroke our engine please let me know
thanks
Old Feb 3, 2010 | 10:36 AM
xoulu's Avatar
also anyone knows if his type s heads, shortblock, and large throttle body fit the 04-06 TL?
need to make sure it fits before I buy. Thanks
Old Feb 3, 2010 | 12:52 PM
ussi's Avatar
I (don't) whine.
Paul has stroked a j32 to a 3.6 using j37 crank and rods, and 05RL pistons...thats pretty much the maximum displacement you're going to get out of these engines without boring it. Type-S heads will fit also.
You're looking good for Friday btw
Old Feb 3, 2010 | 12:55 PM
xoulu's Avatar
yes we look good for this friday =)
btw whose paul anyway i can get a hold of paul?
Old Feb 3, 2010 | 01:03 PM
ussi's Avatar
I (don't) whine.
Nva-av6. He's on here, really knowledgeable guy, knows everything about everything when it comes to tl/accord engines.
Old Feb 4, 2010 | 09:31 AM
TL2004CUSTOM's Avatar
TL2004CUSTOM
The type-S TL head fits the base model? What kind of horsepower gains are we talking about? Can it be done with nothing else upgraded?
Old Feb 4, 2010 | 09:39 AM
djbonsu's Avatar
"Like None Other"
^^i dont think you have significant gains...just the benefit of letting the engine breathe better and stiffer valve springs. i could be wrong tho
Old Feb 4, 2010 | 11:15 AM
tenzingsherpa's Avatar
J36Twingt28r's,nextgt30r
the only problem with the 3.7 build, cause i talked to him extensively about this, is that the 3.7 is strickly for N/A application only. the only way to us F/I for the 3.7 is to resleeve the block. the J36 however will give u basically the same power, it is like a 5-10 hp/torque difference and u can run safely 10lbs of boost on a j36. paul is the man to talk to.
Old Feb 5, 2010 | 07:42 PM
Staysik's Avatar
B A N N E D
Yup checkout the .net forum.
I'll be buildig a j36 using the j32a3 block on my 03 accord v6
Old Feb 7, 2010 | 03:02 AM
acura_dipset_tl's Avatar
AM To WDP In My Garage
Don't want to get off topic but paul is the man he definitely knows his stuff. He's putting a Honda accord tranny in my cls. He mentioned that the tranny was from a guy that he did a manual swap, by any chance is this you?
Old Feb 7, 2010 | 12:45 PM
tl2slow's Avatar
Bored at work
its not complicated ...its all stock parts ......the out come is a very smooth reliable powerful engine.....you will be very happy.....
Old Feb 7, 2010 | 12:58 PM
^^ actually i am not sure?? paul has a couple transmissions at his place so im not sure. i take that back most likely it is now me.
Cool so, this was of your 03 accord? How many miles were on your tranny before he took it out?
Old Feb 7, 2010 | 04:17 PM
sry i meant to say i don't think it was me. long day at work tired as f**k sry for the confusion.
Old Feb 7, 2010 | 06:44 PM
05AcTL's Avatar
with just the heads the gains aren't huge but they are noticeable, you have stiffer springs, tl's cams (suppose to be 2lbs lighter then the base 3.2 cams), and i think the valves might be a couple MM's bigger (Not positive though) but its definately worth it to me and im actually in the process of buying some type s heads to build that motor you gave me!!
Sep 22, 2022 08:34 AM
mlody
Dec 4, 2019 02:11 PM
Sep 17, 2015 09:01 PM
kuzdu
Sep 10, 2015 08:42 PM
EvilVirus
Aug 31, 2015 05:24 PM
