Spec Flywheel
Old May 29, 2019 | 08:56 AM
Joseph Butts's Avatar
Question Spec Flywheel
I'm needing to replace my clutch and figured I might as well get a little upgrade. Has anyone used this?
https://www.specclutches.com/705650
Old May 29, 2019 | 09:23 AM
@Saving4aTL Just put in the Spec single-mass LW FW last weekend.
Originally Posted by Saving4aTL
Just keep in mind that if you go to an unsprung single-mass light weight FW and non adjusting pressure plate, you should try and purchase a sprung clutch disc like the one below.
In addition, any clutch adjustment, with these types of 'upgraded' kits will have to be achieved at the clutch pedal.
Furthermore, clutch engagement points usually change as well. They have been known to land farther out than OEM kits around mid to 3/4 pedal.
In all it’s non-SAC glory!
Old May 29, 2019 | 10:03 AM
I'm not familiar with dual mass flywheel and self adjusting pressure plate setups, but I've driven one with a single-mass flywheel and felt like I thought it should (not sure on clutch kit). I don't see any reason why just the SM flywheel wouldn't play nice with the adjusting pressure plate.
"Furthermore, clutch engagement points usually change as well. They have been known to land farther out than OEM kits around mid to 3/4 pedal."
That's reassurance on disengagement.
"Just keep in mind that if you go to an unsprung single-mass light weight FW and non adjusting pressure plate, you should try and purchase a sprung clutch disc like the one below."
What's the reason for this?
^^Duh smooth shifting
Last edited by Joseph Butts; May 29, 2019 at 10:13 AM. Reason: I read the quoted post and answered my own questions
Old May 29, 2019 | 10:19 AM
You are correct. The SM FW can play nice to a self adjusting pressure plate. Just be sure to get a sprung clutch disc to help absorb 'drive train' shock the heavy factory sprung OEM dual-mass FW was designed for.
That's reassurance on disengagement. Just normal
The OEM clutch disc is not sprung because the OEM dual mass FW is. If you eliminate the heavy sprung factory DM FW for a light weight non sprung SM FW, then you should try to make-up for that loss with a sprung clutch disc to help with 'drive train' shock.
Old May 29, 2019 | 10:44 AM
Thank you for enabling laziness today.
I did follow the threads and just did extensive reading. Kudos to the engineers who designed DM flywheels, but I'm really hating they went with that choice in these cars.
Old May 30, 2019 | 08:08 AM
Acura TL Builder's Avatar
I recommend the installed clutch setup.
No issues. Drives nice. Pedal feel is perfect.
Do your own research. I trusted the word of @gerzand and he came through once again.
Thanks Andy!
Old May 31, 2019 | 07:05 AM
Euro-R_Spec_TSX's Avatar
Brock
Spec is highly known to have quality control problems at their factory and the main reason that I will never own their products again.
Also, you can only use Spec clutches with their flywheels as the locating pins are larger and will only accommodate their pressure plates.
If you want to use a stock pressure plate, then you want an Aasco aluminum flywheel. As mentioned, you will need a disc with damping
springs. I have a couple brand new Aisin discs that will work with that setup if you decide to go that route.
Old May 31, 2019 | 09:26 AM
Now that's good to know.
A clever proprietary way to lock the consumer into having to purchase a complete clutch kit from you as well.
If you want to use a stock pressure plate, then you want an Aasco aluminum flywheel. As mentioned, you will need a disc with damping springs. I have a couple brand new Aisin discs that will work with that setup if you decide to go that route.
The Aasco FW is the 'no-brainer' choice if the OP wants the utility of an OEM PP.
They are also competitively priced to the Spec SA40A-3 $548.10 before shipping for an 04 TL six speed.
Lowest I could find an Aasco #103212-11 was on ebay for $534.99 shipped.
Old Jun 10, 2019 | 07:29 AM
DMZ's Avatar
DMZ
Head a da Family
LUK clutch kit and flywheel. The genuine OEM replacement.
End of story.............
faketree
Jan 24, 2015 08:02 AM
Euro-R_Spec_TSX
Jul 27, 2014 02:43 PM
camrtm3
Dec 27, 2013 10:07 PM
jprows
Feb 15, 2013 02:16 PM
