Spark plug upgrades?
Originally Posted by BLACKURA_NY
Anybody change their spark plugs to something better then stock?? how about wires (i.e, nology)
or would this be a pointless upgrade??
First off...copper is better conductor when compared to iridium and platinum alloys. Don't argue...you are wrong.
B...The core of the plus is still copper with just the tips being alloys of platinum or iridium. They add in longevity of the plug...NOTHING more.
III...Iridium, is extremely hard and brittle material and extremely rare as well. The melting point is 4,466 degrees F. and it is considered the densest of the stable elements. Iridium is used solely as an alloying material for platinum. Platinum alloys contains a small amount of iridium which is much harder than pure platinum.
4...Split fire - Platinum 4 - EFire - U-Groove, Etc...Are all snake oil. I've dynoed many cars and these plugs do nothing that a fresh set of stock plugs can't do. Snake Oil! Look electricity flows to the path of least resistance. Period.
Five...If you are supercharged then you should consider a plug that is at the MINIMUM...one heat range colder than stock. I usually go two heat ranges colder. Ford uses 1 heat range on the 2003-2004 Mustang Cobra and 2 heat ranges colder than normal on the 1999-2003 Lightning Pick-ups (supercharged as well).
A colder plug will pull more heat from the combustion chambers and send it into the heads and cooling system. This will keep you LESS knock constrained.
IF YOU ARE NATURALLY ASPIRATED YOU DO NOT NEED TO CHANGE HEAT RANGES.
Last...It is believed that Iridium is not from Earth.
A-Train
A-Train
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
