Rear mount turbo - Type S
I was planning on waiting for a little bit before sharing, but I'm so excited that I thought I would post this up now. I just received an early Christmas present to myself today.
![](http://s26.postimg.org/5xc0jdvah/IMG_20141125_140603364.jpg)
click image upload
![](http://s26.postimg.org/5luk6meuh/IMG_20141125_140616513.jpg)
uploading images
![](http://s26.postimg.org/kj317ms2x/IMG_20141125_140744726.jpg)
imgurl
I've been working towards doing this for about 6 years, and it's finally going to happen thanks to Utah TSX and Utah Type S for the initial research in their thread and the recommendation of STS turbo.
Now that I've got the turbo kit in my possession, the next step is getting an appointment setup to get it installed. I've reached out to a local shop that does mainly honda/acura tuning and I'm waiting to hear back from them about an estimate and a time. It's going to be tough waiting, but I'm hoping to get it installed in december. I'll keep this thread updated with the progression.
click image upload
uploading images
imgurl
deematic (01-10-2015)
Merry Christmas, the wait is the worst, very excited to see this
maddogtheta (11-25-2014)
Need more turbo pictures, is it a Comp turbo ? what coating is on the turbine housing is it Ruske coating ? and what size turbine wheel ?
The universal kit which included a bunch of piping and fittings, oil scavenge pump, oil pump failure alarm, turbo heat shield, BOV, wastegate and the turbo was 3600 including shipping.
I had to source my own intercooler, fuel pump, injectors and flashpro. I'll get as many pics as I can get. The only hindrance will be that I'm not going to be at the shop for the whole install. (unless they let me, I would love to watch it get installed)
I'll get some more turbo pics up tomorrow. It's an STS GT-35 journal bearing turbo good for 750HP with a ceramic coated .58 A/R turbine.
Ive flirted with this idea myself
maddogtheta (11-26-2014)
What all was included in the universal kit? I figured:
Turbo
Intercooler
Wastegate
Blow off valve
oil pump
Does it also include the:
turbo flange
intake piping
Do they give you any kind of generic straps to mount the turbo or must that all be custom fabbed?
I look forward to seeing your progress. Do you already have a Hondata? Don't forget that - it's the MOST important part!
Turbo
Intercooler
Wastegate
Blow off valve
oil pump
turbo flange
intake piping
The turbo is a china turbo sts had made for themselves. Buddy used to work there. They have TONS of failures if the boost is raised over 8 psi. IT was hit or miss though with those china turbo's. Some would last and others tanked. They later found it was the balancing in some and the bearings in others. Personally would have gone the comp turbo oiless route. I installed an oiless turbo in a m coupe and it is not driven much, but he has about 3000 miles on it with 2 track days and still going strong.
Turbo
Intercooler
Wastegate
Blow off valve
oil pump
turbo flange
intake piping
Turbo
Intercooler
Wastegate
Blow off valve
oil pump
turbo flange
intake piping
The universal kit included a lot of u bend and 90 degree bent pipes, some straight pipe and the fittings and silicone connectors, there will have to be some custom fabbing to go from the turbo to the intercooler and from the intercooler to the intake but that should be about all of the custom fabbing necessary.
Well, I haven't gotten it installed yet, but on the hondata traction control page, it lists the 07-08 TL as compatible. Traction Control
When I talked to the shop about getting it installed, they researched it and are going to install it.
Has it not worked in TL's before?
^ I agree, as soon as I saw videos of turbo'd civics just mashing the pedal down and traction control keeping the wheels from uselessly spinning I knew that's what I wanted on my TL when I boosted it.
Hell, even on a non boosted TL I've had times when the wheels spun a little too much when I launched hard, of course that was back when I was running no-season tires instead of summers...
runnin a little boost
I run with TC on all the time with the turbo and it works well. I am running wider tires so there is not much tire spin unless I'm trying to overwhelm the tires.
From what I've read, Hondata traction control is better than the stock tc, it allows for the customization of how much slip to allow. I'm going to get it installed since I already bought the unit, I'll give a review of it in the TL once I've gotten everything installed.
I couldn't wait till Monday to hear from the shop so I called them today, good thing too because they only had one opening for December 8th, otherwise they're booked out through March. Looks like I'll be turbocharged by mid December!
thisaznboi88 (11-28-2014)
this would definitely be a mod on my list if it works out.
looks like you lucked out getting your car in when you did. i would hate to have to sit on a kit like that until march. knowing what it could be doing instead
and a little bit of advice for the guys at the shop, when we were planning on doing a remote mount. the only way we see to run the charge pipe was to basically follow the shift cable over the steering gear and transmission and use a dual pass intercooler with an inlet and outlet on the same side.
please let us know what you think of the traction control.
I would've had to find somewhere else to get it installed, I couldn't sit on the kit for that long. It's bad enough braving to wait the 10 days as it is...
I'll make sure to tell the guys at the shop about routing the charge pipe, although the intercooler I bought has the inlet and outlet on opposite ends so I hope they can make that one work. Worst case I'll buy a different intercooler...
ive been down for bout 3 weeks now an im gonna be down till about christmas.
and to make things worse.... im stuck driving this abomination
![](https://cimg8.ibsrv.net/gimg/acurazine.com-vbulletin/960x1280/2014_03_27_12_28_26_1aed746f908b799bc13684eeb38945af357415b3.png)
1fstTL (12-09-2014)
Aww yeah... Hot wheels there lol.
Off topic question - I notice there is no grass - is the entire yard like that, or just the side? I assume for water conservation, correct? It always amazes me with the difference in land(hard)scaping across the country.=, all due to water availability.
That is a brutal wait, in a terrible car... I'm counting on not having to go three weeks without my TL, mostly because I can't afford to pay for three weeks of labor cost, plus it shouldn't take three weeks to install the rear mount turbo, I'm hoping it'll be a week at most.
the rest of the yard is grass
Did they give you a quote?
They were guessing somewhere in the ballpark of 5-6k with tuning. I was told that they are guessing on the high side because they haven't done this on a TL before.
Im guessing the TL is your daily. Are you trying to get as many ponies out of the turbo as possible or are you going for a more manageable everyday setup
I did research an aftermarket torque converter through level 10, but if I'm going to upgrade the torque converter for more hp, I think I have to upgrade the transmission and engine internals.
That'll have to be a project for another time (or when my engine blows up...) but it would be fun to go for some big turbo numbers at some point.
The TL is my daily driver. I'm shooting for the 400-450whp mark. I believe I remember reading in a previous turbo thread that the stock torque converter had problems with getting any power beyond 450 to the wheels.
I'm going to be running off of 92 octane for now. When I researched E85, the nearest station that sold it is 23 miles from my house. I don't have plans for methanol/water injection right now. I'm not going to go over 10-12psi of boost at this time, if and when I do I'll be sure to get a methanol/water injection system.
2004 TL SSM w/NAVI
10k to turbo your automatic TL. damn!!! i mean i'm impressed but there is a limit on how much $$$$ makes sense. it's your money and i'm in for results but the money you paid STS WITHOUT intercooler injectors ect ect. and they gave you a china turbo??? i feel like that price is a little crazy. GL
