Project Blown TL Type S is underway
Old 01-06-2009, 11:46 AM
  #201
Former Sponsor
Excelerate's Avatar
Originally Posted by BLACKURA_NY
engine mounts FTMFW.... they will eliminate the wheel hop... but will surely increase the vibrations in the cabin, and when you let loose on the throttle.... your wheels will probably just spin.... im N/A and i cant get ANY traction when i go WOT... VSA on or off
And if Sean (OP) wants he can come down a pick up a set. We have some here.
Old 01-06-2009, 01:12 PM
  #202
paliknight's Avatar
im getting the hint that auto type S's lucked out on this one.
Old 01-06-2009, 01:28 PM
  #203
08 TL-S NBP
msala524's Avatar
It will still work, we just need to upgrade the tranny and all that fun stuff....
Old 01-06-2009, 02:23 PM
  #204
subsonicman's Avatar
I think we will use the 70a motor mounts.... We will just need to turn up the radio.... How come lowering has not been mentioned yet?
Old 01-06-2009, 03:06 PM
  #205
Any one have any gauges yet? If so, where did you put them
Old 01-06-2009, 03:07 PM
  #206
Any have any gauges yet? If so were did you put them
Old 01-06-2009, 04:17 PM
  #207
Not your moms TL.
Ac_Attack's Avatar
SubSonic: Pm me if you need any more pin-out or comp info. I have the service Man w/ type-s Schematics.
Old 01-06-2009, 04:33 PM
  #208
I have car ADD
BLACKURA_NY's Avatar
seriously. this is gonna be the greatest thread ever
thanks to the OP, the installer and the knowledgable people.... some ground breaking stuff... as you know, i was planning this out alot too....
yes, and no.... luckily, because acura (honda) F*ED up the automatic transmission soooooo badly in the 99-01 AV6 ,CL-p\s TL-p\s... they did some solid upgrades to the 3G auto transmission....
go lurk around the 2G forum, and see how many people had/have transmission problems.... look into 3G problems & fixes... not too much trouble in there, eh?
they beefed these trannys up, so I think a blown tl-s 5AT can handle it.. the tq convertor may be another issue... maybe we should get Dr.Evil involved on the 3G (((anybody else on here remember him and his terrible tranny tq convertors????))
so anyways, the 6SPD still has a LSD installed... one thing we will always be missing in the 5AT world.... but dont forget about the wonderful 3rd gear issue with our cars 6SPD and the Civic Si's..... so each tranny has pro's and con's.... plus, the gradelogic kicks ASS in the 07+ 5AT.
my
Old 01-06-2009, 04:56 PM
  #209
2009 g37s 6mt
ssmtl2nv's Avatar
agreed. You really did your hw Allon.
Old 01-06-2009, 05:35 PM
  #210
200,000 mile club
mmade22's Avatar
my
That is fixed with good old GM synchromesh....100% success rate. GM is finally good for something.
  #211
StYLeZz101's Avatar
when i had mine in...i still have both gauges some where lemme know if you would want them
Old 01-06-2009, 06:02 PM
  #212
1st TL-S on air in
wrxyboy's Avatar
So were looking at a pretty expensive s/c build for the tl-s. My question is how will the top half of the motor hold up to 7 psi. We all know that the bottom half can be built out but what about valves and springs all that other stuff. I am almost to the point of buying a short block from Acura and builing out the motor for turbo after now realizing the cost of having this semi bolt on s/c kit work and other things that are still needed to do this. My next question is with the ECU cracked can i add a piggy back system to help with the fuel and timing mapping. Tuning has always made give up on thinking about building a turbo system out. So this has givin me a big grin with wanting to fab up my own custom turbo system knowing that tuning is now a option.
Old 01-06-2009, 06:09 PM
  #213
The cost of the supercharger was expensive, the modification were easy, and fairly cheap. I used the ct engineering acm. The CAR runs great. Still waiting on the dyno, to confirm, but NO knocking, no common lean issues. The only part i think really sucks is the rev limit of 5500
Old 01-06-2009, 06:18 PM
  #214
1st TL-S on air in
wrxyboy's Avatar
Yes the s/c is very expensive and i would like to do just a tune to squeeze out whatever power is left with the mods i have done. So hopefully a piggy back system can work.
Old 01-06-2009, 06:24 PM
  #215
The s/c kit was expensive, the required modifications were inexpensive, we went the ct engineering acm. The only crappy thing about that is that it is non tunable. But then again, it comes programmed for 6 pounds of boost. We are only ar 4-5 pounds for now. I am looking into better fuel upgrades, but at this point the acm works great ct makes a great product. The fuel regulator needs a lot more finessing, because it is different then the non type s
Old 01-06-2009, 06:41 PM
  #216
I have car ADD
^ if you were to work with the fuel system..... i believe the RDX injectors are closest and best match to use, and should only require slight modification to make them fit... but you'll probably need to upgrade your fuel pump too
Old 01-06-2009, 06:51 PM
  #217
1st TL-S on air in
wrxyboy's Avatar
Are the RDX injectors best to use cause the spray pattern is the same or because easy of install. All great info if i plan to build custom turbo setup.
Old 01-06-2009, 09:04 PM
  #218
94 DC4 RS LSV/Turbo
stillhere153's Avatar
my turn to help
injectors... rc injectors 440cc ftw
as for where to put the gauges... I can help with that also
Old 01-06-2009, 10:44 PM
  #219
6-SPEED LOVER
ABP_04TL's Avatar
dis is y im still savin up for my CT!!!
http://www.youtube.com/watch?v=03GXNVGvB4U
Old 01-06-2009, 11:00 PM
  #220
2009 g37s 6mt
ssmtl2nv's Avatar
why is the revy maxed at 5500??? something to do with the acm????
Old 01-06-2009, 11:05 PM
  #221
ONE OF A KIND TL-S
s_heng_62's Avatar
That was a typo. It definitely doesn't redline at 5500.
Old 01-06-2009, 11:11 PM
  #222
greco9885's Avatar
6750 redline
Old 01-07-2009, 01:35 AM
  #223
I have car ADD
i believe the ACM doesnt change the rev limiter.. it just lowers VTEC engagement point from like 4700RPM to like 3000RPM
Old 01-07-2009, 01:37 AM
  #224
I have car ADD
so whats up with this weekend s_heng & subsonicman.. i might be inclined to take a ride up to connecticut to check this out !!
Old 01-07-2009, 05:35 AM
  #225
we can go to the body shop and check it oout,
#####sorry for the typo, i have the flu, and a fever#####
Old 01-07-2009, 07:56 AM
  #226
ONE OF A KIND TL-S
s_heng_62's Avatar
Stillhere, I like your idea w/ the guages, but if I go that route, I'd like to just fab up a piece to sit in the center channel speaker hole. I mean, how useful is that speaker anyway?
Old 01-07-2009, 09:38 AM
  #227
94 DC4 RS LSV/Turbo
well if you get the cluster I linked, you can run it up through there... make it so that they pop up peaking at you lol... you'd have to take the dashboard out and get the dremel out... but... the work would be worth it
Old 01-07-2009, 09:53 AM
  #228
CTS-V Import Slayer
MichaelBenz's Avatar
Do you have NAVI? If so...I believe this center speaker is kind of crucial.
Old 01-07-2009, 10:21 AM
  #229
"Like None Other"
djbonsu's Avatar
^^+1...i was just about to sa that.....you will lose all voice commands and such
Old 01-07-2009, 10:43 AM
  #230
But i can put a voice speaker any place.
Old 01-07-2009, 11:29 AM
  #231
07 TL type S NBP!
modificata3's Avatar
if your vibe audio sponsorship is solid, they may be able to do the install of a voice command speaker/etc somehwere
Old 01-07-2009, 01:06 PM
  #232
1fsthatch's Avatar
my
my cars 3rd gear along with all synchros were replaced and shifts better then when i bought it even in freezing cold conditions it dosen't grind feel notchy just perfct shifting and i have regular honda MT fluid
Old 01-07-2009, 01:57 PM
  #233
I (don't) whine.
ussi's Avatar
Top end of the motor on the Type-S is beefed up and shldn't be a problem. I've seen the inside of both heads 04-07 and 07-08-S and the main difference is the stronger valve springs and cams on the type-S. Either way the issue is in the bottom end, not the top end.
Old 01-07-2009, 04:39 PM
  #234
2009 g37s 6mt
ssmtl2nv's Avatar
the s/cer is great but it should be no worries tou any of you. I have 5000 miles on it and no problems.
Old 01-07-2009, 05:08 PM
  #235
milk man's Avatar
5000 hard miles hahaha j/k
Old 01-07-2009, 05:17 PM
  #236
1st TL-S on air in
wrxyboy's Avatar
So with that being said i might just buy the short block from Acura and start to build out the bottom end maybe get a little more displacement out of the 3.5 to 3.7 with solid pistons and cylinder sleeves to handle more boost. But it still all comes down to being able to tune everything that is going in.
Old 01-07-2009, 05:19 PM
  #237
if you build it it will run
Old 01-07-2009, 05:50 PM
  #238
CleanCL's Avatar
I wonder if the 3.7L short block will bolt up to your heads...
Old 01-07-2009, 05:51 PM
  #239
I (don't) whine.
ussi's Avatar
forget sleeving it. Go with the short block and stroke it using RL/MDX internals which are forged. I would use Type-S heads for sure. You can get it to a 3.7 too without sleeves.
Old 01-07-2009, 05:53 PM
  #240
1st TL-S on air in
wrxyboy's Avatar
Yeah the heads will bolt right back to the short block with no problem, and i was looking at cryo freezing CP forged pistons and a lightened crankshaft. That might be a cheaper more reliabale route than trying to get RL/MDX internals from Acura.
Quick Reply: Project Blown TL Type S is underway
