Ported/Polished Upper Intake Manifold and Runners!
#921
takin care of Business in
Received 4,732 Likes
here let me put an end to this argument LOL....
i mod my car so when i run it against someone i come out on top....so for me top end is more important....i would rather have 10 WTQ/WHP in the 4500+ zone....and i dont mind sacrificing 10WTQ/WHP below the 2500 zone....
most the races i do are not from a stand still....hence that scenario....
but if you race someone from a dig, you might want a different scenario....or if you dont race anyone at all then you might want the low end powaaaaa......
The following 2 users liked this post by swoosh:
flexer (03-22-2012),
thisaznboi88 (03-21-2012)
#923
^ Very often, a graph is using a different scale for the TQ number than the HP numbers. Only if the TQ and HP are using the same scale would the lines cross at 5252. The lines MUST cross at 5252 due to the math formula to derive HP. HP is a calculated figure. HP is not measured. Only TQ is measured. then the TQ values are used to calculate HP.
The following 2 users liked this post by Inaccurate:
thisaznboi88 (03-21-2012),
veggiemonster (03-23-2012)
#924
#925
what are you guys talking about?? WTF The RPM is on the bottom. HP is a comparison on the top graph. The lower graph is tq...
The graph is being compared and that why it is separated. hp old vs hp new, tq old vs tq new
#926
^^^ well when a graph is at a particular scale the HP and TQ lines intersect at 5252 rpm....but when its not in scale that doesnt happen.....
doesnt mean the graph is flawed.....just on a different scale....
#929
#931
^ but if that the case. Then wouldn't you have more power with the MDX spacer since there is an increase up in 5.5k which help the car pull. Your only losing the top top end power 6.3k to 6.7k?
Not trying to pick a fight but that the way I see it. You shift at red line yes, but the RPM drops and to where there is an increase from the MDX spacer that wasn't there without it. So in theory shouldn't it be faster? Its just like what the J&R ecu did when you swap the vtec cross over to 5k, but then again top end tq and hp kinda sucks. with the MDX spacer you started with Less top end tq then you did without it.
lol. damn decision decision decisions.
I kinda want it myself to try it out and see if I can notice it. If not definitely looking to do some PNP work like you did yourself.
#932
Alex, go to bed YO !!!
WhyTF are you still on the thread....you said you were gonna sleep almost 30 minutes back....
The following 3 users liked this post by rush:
#935
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
#936
Sorry thisaznboi88. I didn't look at the graph before I posted.
An engine can be modded to shift the TQ production more into the lower RPM range or more into the higher RPM range. The slang "torquey" or "has a lot of torque" is just a slang meaning that the torque is biased toward the lower RPM range. The slang "peaky" or "has low torque" is just slang meaning the torque production is biased toward the higher RPM range.
I also wish that people would stop saying TQ causes this and HP is responsible for that. If a person would learn what the technical term (I am not being sarcastic) of Power really meant, it would help a lot. First of all, do a google search for "Quarter mile acceleration formula" (or click here). All you will see is HP is used to predict acceleration, not TQ. This applies for max top end speed too. That is, if you wanted to predict top speed, HP is used not TQ. So, please stop saying that TQ is used for that and HP is used for this. The only thing that matters is HP, not TQ.
The key to understanding this whole mess is that HP involves the overall gearing of the vehicle. If the torque is produced in the higher RPM ranges, then the car can stay in a lower gear longer for the torque multiplication from the gearing. Guess what, that is the definition of Power in a nutshell.
Now there is one exception to what I said.... the concern of having the power from a dig provided that you have traction to put the power to the ground. In a race car, the gearing would be changed to be at the optimum gearing from a dig to suit the powerband. But for us, we can not change our gearing. So, yes we need to be careful to not shift too much torque away from the low rpm's toward the higher rpm's. Racing is about compromises. Pick where you what your torque to be located to match your needs. If you seldom race from a dig, then you can afford to move your torque to higher rpm's.
The key to this is to pick where you want your strength to be. If you are only interested in having the most acceleration from a roll, determine what your usable rpm range is. For the 5AT, it is approx 4500 - 6500 RPM (provided that you are not using SS). In this example, you would need to focus on the *average HP* produced between 4500 - 6500 RPM.
If you modded the engine to shift more power between 4500-5500 than 5500-6500, the car would accelerate the same if it had more power between 5500-6500 than 4500-5500, This is because the average power has remain the same within the overall 4500 - 6500 RPM range.
#937
But HP is directly proportional to Tq, so its all the same. You are stressing HP, but I am fine with someone saying torque as well if they know what to say.
Since HP = torque * Engine RPM, than really they should say they are trying to hold torque out in the upper RPM range, or trying to increase torque at higher RPM's. Than anyone that understands the formula would know that higher torque, at higher RPM, means higher HP.
Here is a good article about it:
http://www.enginebasics.com/Engine%2...%20Torque.html
JR
JR
#939
Guys I got a question maybe problem
Other than PCDs I'm near fully bolted on my 6 speed speed .. Port n polished .. Intake Jpipe exhaust under drive pulley plus I'm a 6speed... I was driving home tonight , I just installed my CAI tonight .. And when I'm in lower gear and in my power band I go full throttle and car pulls .. But when I get to Vtec , car backfires a little stability blinks once or twice and I continue to go ... Now it's nothing serious BUT when I spoke to my mechanic who did my install he said its because I've done all these mods adding more air into the engine but fuel is still the same .. And I need more fuel .. He said higher output fuel pump or fuel injectors or even some type of tune or programme
Now my accord uses regular 87 octane so I'm thinking and my mechanic recommended using 93octane in the meantime since it could help
I actually agree .. What do I think
#940
I think your running rich now. Too much air. Then car dumps more fuel to compensate. When you shift some of the fuels escape without getting burned. and then ignites in the exhuast area.
BostonSilverTypeS (03-23-2012)
#942
can you data log the car A/F?
I know my car backfires/ pop everytime I shift gears, but it sounds pretty kool. That was before I did runners and IM. only j-pipe and exhaust cause it to pop.
#943
^all depends...I know it's hard to find but there is a part store around my way that sells 102 octane booster and it does wonders!!!...but yeah can't go wrong with some 103 race fuel if you can find some that is....prolly easier out west to find that stuff...around here only place that sells race fuel is a sunoco station at the strip when its open season !!
#946
thanks fir the response guys , im gonna take a video tomorrow to show u .. its kinda cool though going wot and heating the car and than the bop bop sound
I'm gonna run 93 though for a little to see I'm actually surprised what i thought of doing was actually your opinion too.. I'll post a sloppy video tomorow but its hard driving stick n doing videos lol r
as for the.103 octane there'snothing by me that settle but i bet i could find some online of i looked hard enough
#947
Chapter Leader (NY/NJ)
Just run 93. You'll be fine. Higher octane will burn quicker and stops the backfire. Even when I had my 91 accord 10 years ago I never used anything but 93. Shit back then I even used sunoco 94. (Gas prices were still around a dollar back then)
BostonSilverTypeS (03-24-2012)
#948
#950
#951
i spent 50 dollars on gas at 397 a gallon and got 3/4![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
i did a video but stupid me left the radio on and i missed 3rd because i tried going into 3rd using my phone to push in the gear lol FAIL lol
for now on im going to run premium even if it doesnt require premium.. with all my mods theyd probably work better together with a better fuel.. plus i only use shell so some V power
#952
ok back to the turbulence with the mdx spacer. Do you think that you will have turbulence running an ported/polished intake manifold, taper bored/polished spacer, and stock runners?
Since I already order the mdx spacer im going to use it. So I was thinking that with wanting to get the intake manifold ported and polished, why not also have the mdx spacer ported/polished on the intake manifold side and taper to the stock intake runners. Also would want to have the gasket between the spacer and manifold bored to match the port work.
Do you guys think this will remove some of, maybe all the turbulence ? Im about to start looking for another intake manifold soon. Also when this happens I plan to do the coolant bypass on the TB.
yes, i have the MDX spacer bored as callahan mentioned.....its 46.xmm in diameter as compared to the stock 44.xmm....
True words !!!
i have been procrastinating the dyno but i know i need to do it with and without the spacer !!!.....
this spacer might come in handy after you do cams work as with the cams you loose low end TQ and gain massive high end and the spacer might counter the low end losses....
True words !!!
![](http://img820.imageshack.us/img820/1561/mppspacer.jpg)
Uploaded with ImageShack.us
#953
^^^ lets see how that works out buddy....
am eager to see how it will work out....
#956
Yeah, I got it from Moores and will be installing it later this week. Just got back from vacation and am jet lagged. The spacers not as thick as the MDX spacer but will be sandwiched between two P2R gaskets. I thought I read somewhere about the optimal spacer thickness being 1/4" - 1/2" and that the MDX spacer was too thick causing top end loss which would make sense since the MDX needs more power lower in the band due to the target demographics.
I don't know if I will even be able to notice top end loss or whatever this turbulence is.
#957
^^^ well if that proves nice, i might get my spacer cnc-ed and sell half of it
![Snicker](https://acurazine.com/forums/images/smilies/emot-laugh.gif)
#959
^^^ oh shit really. I was thinking of not installing it on the lower end of the spacer. Did you do the ultimate cooling mod? The hybrid UCM is my next project before summer so moar vtec is a go. lol
