Ported/Polished Upper Intake Manifold and Runners!
#682
Fellas, after reading a few pages back and since I have access to a machine shop with a couple of old retired machinists, I'm wondering if I should just PnP the parts myself (with their expertise). Now, I'm not gonna be creating CNC programs and all that but just wondering if something like a drill press, lathe or other shop tools could help simplify the process. If it's really easy maybe I'll open up shop with the prices they are charging out here for PnP lol
#683
takin care of Business in
Received 4,732 Likes
DO EEET !!!!
pnp is the new thing....LOL
#687
Well regulations are strict on forum members advertising .. But idc
andy is doing em.. I can honestly say I cannot wait to install these I am counting down until I have these
#689
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
#690
well if everything goes as planned which i think it will because andy is great
it will be shipped tomorrow morning and i hope to have it by friday.. and i took off sat-tuesday for my birthday so i should have everything installed i hope
#692
^^^ here is his FS thread....you can PM him....his s/n is gerzand
https://acurazine.com/forums/showthr...7#post13553097
#693
Question,
Is the P2R spacer tapered down to the stock TL mani opening? So if you ported your mani, now you also have to port the spacer... Seems all stupid to me... Either get the IM AND TB from the 3.7(no spacer required $900), or get your IM and TB ported $250... or get the 3.7 Mani and port for TB(needs p2r adapter) $650.
The P2R spacer is almost large enough to leave alone if you're boring TB and port matching the IM to the larger TB. I wanna say mine was around 67-68 mm, where as the finished TB measured 68mm on the IM side. Actually, my IM was almost large enough to leave alone as well. Most of Maxbore's pricing on that is for the return shipping. It doesn't take much to open up the mouth a couple mm's.
#694
^^^ or just get the moores TB spacer....70mm bore and 1" thick
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#697
^^^ hahahaa sure thing....
PS: sorry i forgot the torque specs....they were not too much (18 or 28ft/lbs)....DO NOT over tighten them....they will snap !!!
Also apply some engine oil on the injectors while putting em back in
#702
^^^ hahaha the reason i had to get the ported and polished manifold was coz 2 of those bolts broke
![Snicker](https://acurazine.com/forums/images/smilies/emot-laugh.gif)
#704
I havent heard back from George bro....if i dont until Monday, will call him and find out
#706
Well guys it appears that there are some differences with the 2008 - 2012 accord v6 where the runners have a different shape (more squared insted of oval toward the engine head side) and also the front engine head valve cover has clearance issues with the aluminum manifold's removable end-caps. Mayormccheese experienced this first hand yesterday. Now to figure out why the hell honda changed this but got 3hp less from the design than on the J35A8 TL-S and Acura RL...
#709
no 8th gen has experimented with this so there might be small hoops to jump but like gerzand said this is being remedied and once it is ill enjoy every bit of this
what i can say about andy is his work is top quality and u can see he knows what hes doing and it shows in the work and any question i need or have an issue with hes a phone call away and helps every time
#710
^^^ hahaha I have experienced Andy's customer service and i vouch for it....
do post some pix of the stock runners sitting by the pnp runners....
#712
The induction system can be "tuned" or designed to have features which can improve the way the cylinder fills and determine where PEAK TORQUE will be located along the rpm range. This is what we call intentional "powerband location" placement."
This link has info on it.
http://www.team-integra.net/forum/bl...culations.html
BTW do you have a side shot of both runners. I bet the accord more squared ones are longer in length. Lends me to believe the accords powerband is more mid range oriented
#713
I wasn't bitching about your runners or your port and polished. Cuz I told him to do the runners also. I didn't know the gen8 runners were that different. Cuz there was a post on drive accord and they looked very similar.
#714
?? magnesium *stock gen8 im*> aluminium *stock base 3.2 im* that's all I saying.
#716
explain? Its not going to blow up if your worry about that. Its mag alloy, and gerzand has a port and polish IM that I really want also... I especially want it now since I broke some studs off my stock IM cover.. Opps
#717
Chapter Leader (NY/NJ)
those studs are easy to remove. the heads break off so easily that the body doesn't really have any pressure holding them in. see if you could grab them even with a fingernail to turn them.. if not, a screw driver, and then if not, broken screw remover from home depot for 5 bucks but thats last resort.. i found this out AFTER i bought the screw extractor and i forgot who i told this too and his was the same thing, he found out after buying the screw extractor.
Remove the cover and see if the body of the screw is showing above the manifold
Unless you talking about the 2 studs that have nuts and not the screws...
#718
I need some quick help fellas. So I've read the accord IM and Runners thread several times with a print out and plan to use that as my guide. Here's what I plan to do before starting the work:
1. Remove #19 fuse for fuel pump
2. Start car a few times so to release all fuel pressure
3. Disconnect battery and start opening up the TB
4. Follow Accord forum DIY.
Tips from folks:
It would be great if anyone can chime in with any extra real world tips. I felt nervous about doing my brakes but that was a breeze; I spent more time talking myself into thinking something was missing
Tips from folks:
- Apply a little motor oil to injectors to help them slip back on
- Once IM is removed, cover the runner openings so nothing falls in
- Torque IM bolts to 18 lbs and the other ones to 9 lbs
#719
http://www.my8thgen.com/forums/showt...ghlight=intake
I used that .. I didn't need it much , once u get under the hood everything looks kinda obvious what needs to be done
Motor oil on injectors did work .. Have a magnet catcher .. Once I had the runners installed and everything I dropped a bolt and had to take. The runners off again
