Noobie turbo question
Hey guys,
I'm looking at buying a 2005 TL and I would want to put a turbo on it. A lot of older threads mention J&R Next Level Performance as a company who makes one for this car. However I can't seem to find them anywhere on the internet. Are they still around? If so, and it's not too much hassle could someone point me in their direction.
Thanks for helping a new guy.
Former Sponsor
This could be another option. I can definitely help you out with any questions you might have along the way of your build.
350-073 - CT Engineering Supercharger - CL/TL - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Is it an automatic?
Hey guys,
In another thread I posted a list of threads with current turbo builds so you can read to see how others got their TL's turbocharged.
Orrrr, you can contact Andy Gerzina (gerzand on Acurazine). He has the Rotrex Supercharger Kits (Only con is no A/C
) . Here is his post from the Acura TL Generation 3 FB Page:
Hi Everyone. As some of you TL enthusiasts may know, I designed (and sell) custom Rotrex Supercharger kit(s) for our 2004-2008 Acura TL and 2007-2008 TL-S!
Please read all about it below. If you have additional questions, I will do my best to get back to you in a timely manner if you'd like to message me or briefly ask them here.
There are 6 different bundles of the kit available to order, which ship within 3 weeks from date of order. These kits are also referred to as "Stages" based on your desired power level, fuel type (gasoline or e85 ethanol), and budget. Keep in mind that some kits may be more expensive because of their ability to run e85 ethanol which has properties similar to race fuels but with bigger fuel delivery requirements. I recommend up to 425whp for stock blocks on 93 octane gasoline or 475whp when running e85 ethanol as your fuel of choice. If you install aftermarket pistons and valve springs, this number can be raised to 550whp and with the addition of aftermarket rods, to 600+ whp. Please stick with the "Stage" or bundle which fits these limits.
All kits are fabricated by me personally, and are designed to install with very little modification to the vehicle aside from some trimming of a couple of brackets and non-externally visible bumper plastics.
This kit requires the removal of the AC unit in the engine bay (there is unfortunately no feasible way around this). The car still retains cabin heat and all other functionality. There are numerous benefits of this kit over a turbo setup for the TL drive-train. These include, but are not limited to: no increased engine bay heat, no heat soaking from boost related components, no need for meth/water injection, linear torque progression which is friendly on transmission components, no increase in exhaust back pressure which results in proper scavenging of exhaust gases and less heat propagated to the coolant system, and more. This kit also adds little to no weight to the TL, since AC components removed weigh as much as the supercharger kit.
Let me know if you would like to have a conversation with further questions that you may have. Email can be a good tool, but often times a phone call works best to start things off and make a proper introduction and discuss what I can offer you in regards to reliable power and torque from a properly designed and quality-made kit. If youre genuinely interested in making an investment in your car for amazing horsepower and torque, get in touch with me.
Here are some links where you can see some pictures/videos of the unit in action:
http://www.instagram.com/gerzand
https://acurazine.com/forums/3g-tl-p...-809481/page2/
http://www.youtube.com/gerzand
Regards,
Andy
Bundle #1)
J-Series Rotrex "Stage 1 Full Kit". (Up to 425whp for safety/limited by stock internals on 93 & 110 octane gasoline). This kit is NOT e85 ethanol compatible. Please see Stage 2.5 & 3.5 kits for e85 ethanol compatibility. With the exception of RV6 Precat Deletes and a tuning solution such as Hondata Flashpro, this kit includes everything required to supercharge your engine.
Price: $4650 shipped
Parts List:
1x Rotrex J-series Bracket.
1x Rotrex C38-81 Supercharger Unit.
1x Supercharger Drive Pulley.
1x Walbro 255lph Gasoline ONLY Fuel Pump.
1x 560cc Acura RDX Fuel Injector Set w/Pigtails. 560cc rated @ 4bar/58psi.
1x Intercooler & Aluminum Piping Kit.
1x Silicone Coupler Kit.
1x Rotrex Cooler Kit.
1x K&N 3" Inlet Intake Filter
1x Supercharger/Serpentine Belt.
1x Intake Manifold Check Valve Kit.
1x Synapse Blow-off Valve.
1x Synapse 50mm (boost controlling) Wastegate (optional +$350 not automatically included in kit pricing above)
Bundle #2)
Rotrex "Stage 1.5 Full Kit". (Up to 425whp for safety/limited by stock internals on 93 & 110 octane gasoline or 475whp e85 ethanol). The inclusion of e85 ethanol compatible fuel system components contributes the the higher cost of this kit as compare to the Bundle #3) Stage 2 Full Kit below. With the exception of RV6 Precat Deletes and a tuning solution such as Hondata Flashpro, this kit includes everything required to supercharge your engine.
Price: $6,300 shipped
Parts List:
1x Aeromotive 340lph Gasoline & e85 compatible Fuel Pump.
1x 970cc Injector set w/Pigtails. 970cc rated @ 3bar/43.5psi.
1x K&N 3" Inlet Intake Filter.
1x Billet Aluminum Fuel Rail Set.
1x Russell Braided Fuel Supply Line & Fittings.
1x Russell Braided Fuel Return Line & Fittings.
1x Aeromotive Fuel Pressure Regulator.
1x Aeromotive Fuel Pressure Gauge.
Bundle # 3)
J-Series Rotrex "Stage 2 Full Kit" (Up to 550whp with built engine internals on 93 & 110 octane gasoline). This kit is NOT e85 ethanol compatible. Please see Stage 2.5 & 3.5 kits for e85 Ethanol compatibility. With the exception of RV6 Precat Deletes and a tuning solution such as Hondata Flashpro, this kit includes everything required to supercharge your engine.
Price: $5,500 shipped
Parts List:
1x Rotrex C38-91 Supercharger Unit.
1x 340LPH Gasoline & e85 compatible Fuel Pump.
1x Supercharger/Serpentine belt.
1x Intake Manifold Check Valve kit.
Bundle # 4)
J-Series Rotrex "Stage 2.5 Full Kit" (up to 550whp with aftermarket forged pistons and aftermarket performance valvesprings on 93 & 110 octane gasoline or only 475whp e85 ethanol capable due to -6an diameter fuel lines. See Bundle #6 Stage 3.5 Kit if you plan on making over 450whp on e85 ethanol. With the exception of RV6 Precat Deletes and a tuning solution such as Hondata Flashpro, this kit includes everything required to supercharge your engine.
Price: $6,500 shipped
Parts List:
1x 340LPH Gasoline & e85 Compatible Fuel Pump.
1x 6an Russell Braided Fuel Supply Line & Fittings.
1x 6an Russell Braided Fuel Return Line & Fittings.
Bundle #5)
J-Series Rotrex "Stage 3 Full Kit" (650whp with built engine internals such as aftermarket forged pistons, performance valvesprings, aftermarket forged rods on 93 & 110 octane gasoline or only 475whp e85 ethanol capable due to -6an diameter fuel lines. See Bundle #10 Stage 3.5 Kit if you plan on making over 475whp on e85 ethanol. With the exception of RV6 Precat Deletes and a tuning solution such as Hondata Flashpro, this kit includes everything required to supercharge your engine.
Price: $6,995 shipped
Parts List:
1x Rotrex C38-92 Supercharger Unit.
1x 255 or 340LPH Gasoline & e85 Compatible Fuel Pump.
1x 1300cc injector set w/Pigtails.1300cc rated @ 3bar/43.5psi.
1x Rotrex Fluid Cooler Kit.
1x K&N 3.5" Inlet Intake Filter
Bundle #6)
J-Series Rotrex "Stage 3.5 Full Kit" (up to 650whp with built engine internals such as aftermarket forged pistons and rods on 93 and 110 octane gasoline & e85 ethanol). With the exception of RV6 Precat Deletes and a tuning solution such as Hondata Flashpro, this kit includes everything required to supercharge your engine.
Price: $7,550 shipped
Parts List:
1x 460LPH Gasoline & e85 Compatible Fuel Pump.
1x 1300cc Injector set w/Pigtails. 1300cc rated @ 3bar/43.5psi.
1x 8an Russell Braided Fuel Supply Line & Fittings.
Regards,
Andy
Bundle #1)
Parts List:
Bundle #2)
Parts List:
Bundle # 3)
Parts List:
Bundle # 4)
Parts List:
Bundle #5)
Parts List:
Bundle #6)
Parts List:
![](https://cimg1.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13680876_685799474903825_4153739857298322458_n_1b2ed0e99159e15a03b09022f8511d85e55879da.jpg)
![](https://cimg4.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13901424_685799494903823_8466724941039927021_n_14e6b2c7ac4a101cf8f42ea25a1809ca77a492a5.jpg)
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13879303_685799524903820_3595766560954758268_n_fd5dcc6c12e489c201691ae1701b6a6e0b1df9a3.jpg)
![](https://cimg0.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13221691_638335852983521_5172278922467581729_n_93e02214003eec9814e9c3efe763005c0e36434f.jpg)
![](https://cimg6.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13912522_685799548237151_2691208933956770611_n_963a998f040d20d295ffec7a6fed71766b41ec21.jpg)
![](https://cimg7.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13895057_685799578237148_4784883979745230067_n_610cf0313443be122bcf2043fcb4ed2ebc0533fb.jpg)
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13668948_685109281639511_8882668948028186738_n_8e31dd6b0a89df3f3e78860e0d282e656acfc252.jpg)
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13882076_685109188306187_91057064647895867_n_8ab4fc597655dec0089d1bb50782162417c15273.jpg)
![](https://cimg4.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13886911_685109214972851_1585416766975644274_n_2a1015790bfa4a1541ce350c71e7caeb10a09436.jpg)
![](https://cimg6.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13669126_685109074972865_8014444014153314041_n_8c2e45b4980c19c33ffa137183e8d1ba857a749e.jpg)
![](https://cimg8.ibsrv.net/gimg/acurazine.com-vbulletin/960x960/13886934_690562887760817_912356143922289602_n_e543a114f783c49c9dd3d4807a5dae1d03a1392c.jpg)
![](https://cimg1.ibsrv.net/gimg/acurazine.com-vbulletin/960x540/13872711_685112031639236_4339494549670049373_n_5c67e3cc2810d092848c22a0255dd9ef3cfde96e.jpg)
EvilVirus (10-19-2016)
OhRDX
1G RDX Problems & Fixes
06-29-2018 03:44 PM
thisaznboi88
867
01-11-2018 05:12 PM
