Need Some help With this PLEASE Read !!!
Old Mar 26, 2013 | 01:06 PM
JC's TL's Avatar
Okay guys i have a 08 Acura TL my engine light just came on about a month ago an i got it checked an its the Cat Converters they all bad..
Idk what to do off hand i called Acura to ask them an told me that it would be 1k per Cat.. which is insane..
Im debating on getting an Full Aftermarket exhaust but not sure which one to get or what too do one it.. Its just the 3.2 Vtec
Please give me some ideas on what i should do Would greatly appreciate it
Old Mar 26, 2013 | 01:18 PM
JC's TL's Avatar
Im wanting to get something that Has a good Sound but Nothing to loud Or raspy any ideas let me know asap
Old Mar 26, 2013 | 01:22 PM
look into High flow cats from RV6.
http://rv6-p.com/
Old Mar 26, 2013 | 01:26 PM
zachlone's Avatar
High flow cats would be your best bet
Old Mar 26, 2013 | 01:28 PM
joey06tl's Avatar
1k per cat???? fuk that!!
get all aftermarket stuff, and enjoy the new sound and performance of your car.
Old Mar 26, 2013 | 01:29 PM
JC's TL's Avatar
Alright thanks Justin do u have Suggestions to a Full Exhaust System i was thinking about doing Greddy but not sure want to add horsepower an also get a good sounds as well something thats sounds good but not Raspy
Old Mar 26, 2013 | 01:32 PM
its not really a full exhaust...
its called a cat back because its from the third cat and back.
solve one problem at a time; young buck.
solve your cat problem first. then look for exhausts.
Old Mar 26, 2013 | 01:54 PM
EvilVirus's Avatar
Are you sure its your cats and not the o2? Whats the mileage?
Old Mar 26, 2013 | 02:00 PM
JC's TL's Avatar
See what i was starting to think as well about the O2 Sensors.. the milage on the car is Roughly 97500 give or take..
Gas milage is Not been so great like it was when i first got the car..
Old Mar 26, 2013 | 02:06 PM
JC's TL's Avatar
When i had the codes Checked the reader said it was Low Emissions Cat.. an Also Cat manifold low emissions !!
Old Mar 26, 2013 | 02:09 PM
EvilVirus's Avatar
what code did you get?
Old Mar 26, 2013 | 02:12 PM
JC's TL's Avatar
Pep Boys did the code i dont remember the numbers off hand
Old Mar 26, 2013 | 02:28 PM
EvilVirus's Avatar
-_-........my advice to you is get it scan again, write down code, post here and google the codes yourself too (newbies got to learn on how to do some research). It could just be your O2 sensor; unless you or the previous owner havent been/didnt taken care of her.
However, if you plan on going aftermarket regardless, then just get the HFPC or PCD and replace the o2 sensors.
Old Mar 26, 2013 | 02:30 PM
JC's TL's Avatar
Okay thanks Man i do all my work on My Girl.. The person before me didn't take good care of her some im nursing her back to health so to speak lol.. Im going to change out the O2 sensor's this weekend an see if that fixes the problem i appreciate all the advice an i will keep it posted on how things go with this issue.
Old Mar 26, 2013 | 03:20 PM
Richie v6's Avatar
Former Sponsor
Make sure there the car isn't misfiring before switching the cats. Unburnt fuel will burn up a cat in no time. I've seen a valve cover seals leak and ground out one of the ignition coils.
Old Mar 27, 2013 | 10:28 AM
Excelerate's Avatar
Former Sponsor
If you need to replace the third cat I'd recommend an XLR8 V2 J-pipe. It will replace your j-pipe and third cat with a long tube j-pipe. The third cat isn't monitored so it won't throw a CEL. And you'll pick up a significant amount of hp and tq.
Old Mar 28, 2013 | 03:47 AM
Mrtastygoody's Avatar
Level: Noob
I would check the codes again before you go buy like 4 O2 sensors man, they're about 400 bucks for all of them. Don't be throwing your money at the car just hoping it gets better.
Old Mar 28, 2013 | 08:32 AM
nismopowerdqg's Avatar
LowNslowTL
yeah i agree with all said above, rescan to make sure its not bad o2's, you have low miles so id be surprised if you have bad cats but ive seen crazier shit happen. Also if the cats are bad just get some high flows which will run you less than 600 for both pre cats and then if you have a bad j-pipe cat as well go ahead and get that for about 450. so your right around a grand but you get a bunch of performance and nice quality parts.
Old Mar 28, 2013 | 08:45 AM
JTS97Z28's Avatar
Your cats would be fully covered under manufacturers warranty because its an emissions item! Not sure what they were talking about quoting you for that.
Old Mar 28, 2013 | 10:07 AM
Jackass's Avatar
My thoughts exactly.
Old Mar 28, 2013 | 09:31 PM
JC's TL's Avatar
Alright Guys Heres the news on what ive found out about the car..
These are the codes its throwing:
P0420: Cat Efficiency Below Threshold Bank 1..
P0430: Cat Efficiency Below Threshold Bank 2..
An The car when i bought it was at 76K which also was sold as is guys so the Factory warranty i believe doesn't apply Unfortunately.. But if u guys can help me figure out the best route to get theses issues fixed id greatly appreciate it !!
Old Mar 28, 2013 | 10:43 PM
EvilVirus's Avatar
http://www.obd-codes.com/p0420
http://www.obd-codes.com/p0430
Old Mar 28, 2013 | 11:15 PM
pohljm's Avatar
I believe the factory emissions equipment warranty would still be in place
Old Mar 29, 2013 | 04:40 PM
JC's TL's Avatar
POh I called an asked them about it an they said my TL doesnt have it on it so im screwed on that one..
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
