Is my engine mount bolt supposed to look like this??
Old Nov 7, 2011 | 09:52 AM
newfrito11's Avatar
if not can i tighten it and then go kick the ass of the guy who installed it? or do i need a mechanic to mess with it?
they are aftermarket mounts XLR8s
Old Nov 7, 2011 | 10:46 AM
KN_TL's Avatar
sure doesn't look right. Did you get it back from the installer like that?
Old Nov 7, 2011 | 10:55 AM
jchcmax's Avatar
Registered VTEC junkie
Whoa! That does not seem right, it should be flushed. It's either the wrong bolt or it was not tightened and unscrewed due to vibration. I don't have those mounts but I hope that's not the tightest it can get. Can the bolt move? You should let the shop know about this.
Old Nov 7, 2011 | 11:10 AM
KN_TL's Avatar
This is from libert69. This is what it is supposed to look like
Old Nov 7, 2011 | 11:15 AM
Bearcat94's Avatar
AZ Community Team
It's a flanged bolt. It should be flush.
Old Nov 7, 2011 | 11:38 AM
Excelerate's Avatar
Former Sponsor
That's not right at all. The mounts are direct replacement mounts which mean they are direct bolt-on. All the bolts will go in the same position and thread down the same way. It appears that the threads of that bolt are cross-threaded or damaged. I would get a new bolt or run that bolt through a tap to make sure the threads are good.
Old Nov 7, 2011 | 12:42 PM
Andy07KBP's Avatar
from the picture those threads look jacked up. It could just be glare though.
Old Nov 7, 2011 | 06:14 PM
maxpsi's Avatar
No, I think you're right. Threads look smashed. Pray it's just the bolt, but use a thread chase once you find a bolt replacement as mentioned above.
Old Nov 7, 2011 | 09:43 PM
anx1300c's Avatar
Who installed that?
Old Nov 7, 2011 | 09:56 PM
thisaznboi88's Avatar
someone need to get their ass kicked.
Old Nov 8, 2011 | 03:23 PM
tsx&skate's Avatar
damn looks like the person installing it forgot to tighten that bolt.
Old Nov 8, 2011 | 05:52 PM
Andy07KBP's Avatar
im wondering if they jammed it in there to "tighten it" and it just slipped out with vibration because the bolt threads and receiver threads are completely gone..
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
