J-Pipe or stay stock?
Hello all,
I know the j-pipe has been talked to death and yes, I did a prior search on said subject. But I still want some educated opinions if possible please.
I love my Type S and at first considered a ton of modifications, but budget and overall aesthetics have convinced me to keep it mostly stock if possible. So a CAI or short ram intake is out, some folks on here told me the stock one was made very well by Acura. Replacing the stock exhaust system is out because damn, I've wanted this dual DUAL setup for a long time. It's just too pretty.
I currently don't want to do a pre cat delete. I'm not sure if I want to do even a 3rd cat delete. This leaves me with the only performance upgrade possibility of a j-pipe.
Let me explain. My Type S is auto. I use it as my daily driver to work. Unfortunately my work is nowhere near a freeway so I end up having to drive 9 or so miles each way in CITY traffic. All I'm looking for is to maintain power in the low end (much stop & go), gain a few hp, gain some overall performance, and hopefully gain a mile or 2 per gallon of gas. I don't need a rasp or a drone in my exhaust note, so the closer to quiet the better.
I've been reading and thinking of a j-pipe change to help open things up. But, with the 3 big options (EndlessRPM, XLR8, HeelToe) I don't know if any of them are the right ones. I'm willing to delete the 3rd cat if it will help overall performance. The j-pipes that remove the 3rd cat do cost more though I notice. If I can get good performance with just a main j-pipe and keep the 3rd cat, and spend less, I'm up for that too.
I've read most of the topics here about j-pipe, and it looks to be up & down. Some notice a difference in power in different RPM bands, some say the j-pipe made no noticeable difference over the stock one. What say you fellow members, is my best option for a daily driver in city traffic?
any of the jpipes from the big 4; rv6, endless, xlr8 and atlp, will do the same thing at the most basic level.
what I think is happening is that you're over thinking this x10.
also, our cars make PEAK power at 6000 RPM, so if you DONT EVER drive at this RPM, a jpipe would be kind of pointless...
adding a jpipe will increase hp but more so at that specific RPM range
Don't over think it, pick whatever you want. I bought an RV6 j-pipe since I have the exhaust. I take dyno's at face value, their just a measuring stick, your car may not make as much power as someone elses with the same mods.
The following 2 users liked this post by 6spd-GERCO:
justnspace (05-20-2015),
usafawd (09-18-2015)
The only things the stock one is well made for is noise emissions and hydro-lock protection. It wasn't designed for max performance. It was designed to be quiet.
FamilyGuy (05-20-2015)
you get paid based on how much HP your car has?!?
SIGN ME UP!
SIGN ME UP!
You're not going to reap a single tangible benefit from just a j-pipe alone. The car won't sound any different, gas mileage won't be any better, and you certainly won't feel the 5 or 6 or even 7 or 8 horsepower you gain. If you're not planning on doing additional mods, I'd use the $400-500 for something else.
Until then, roof spoiler, all-weather mats, and door visors here I come!
ExcelerateRep (05-21-2015)
Former Sponsor
I agree with sockr1. The growl adds a nice dimension to the exhaust note, and you pick up a few extra horsepower. You will see better gains with a full exhaust, but it certainly doesn't hurt to free up exhaust flow. Depending on your butt dyno, you may actually feel some better pickup. Plus it doesn't throw a check engine light, so you'll (most likely) still pass emissions.
hoa.excelerateperformance.com/xlr8-performance/xlr8-jpipe/g-73355.aspx
The following 3 users liked this post by justnspace:
Well OP, I have the ATLP V2 jpipe and to me it was worth every penny. It gave the exhaust a (subtle) nicer note and I got +1 mpg. So you get better performance, better MPG and a nicer exhaust note. Simply the best of all worlds. IIRC, When i was researching for jpipes i found that ATLP V2 made its best power in the lower RPM range, which is where i wanted it to be and why i bought the ATLP over the RV6 where its gains were mostly seen at top end. Good luck with your decision.
But on weekends where I get to hit an open freeway, even with the automatic, I still make it a point to get that Vtec going....
Some j pipes gain in the low-mid range, not just up top in vtec, which you would enjoy in your daily commute. Food for thought.
Over time I will consider other things to add, right now I just want to maintain it and add a few OEM accessories.
Yep, thanks to Outl I am considering the ATLP j-pipe as well, costs a few hundred less since you can still keep your 3rd cat if you want. Or just buy their extension to get rid of the 3rd cat for a bit more.
This again helped with slightly enhancing the exhaust note as well
Oh and here is the link to ATLP V2 Jpipe: http://www.heeltoeauto.com/atlp-v2-j...-es0004v2.html
Former Sponsor
Puma Jim
20
10-20-2016 11:59 AM
STL TL-S
09-23-2015 08:52 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
