Installing Headlights and Intake Tonight, Any suggestion
Old 08-01-2008 | 06:30 AM
TL1999's Avatar
GO DAWGS!! SICK'EM!!
I am changing my headlights out tonight with mod set from JnC. And since the front bumper is coming out, i am going to go ahead put on my Fujita Intake. I got video from 3g garage, etc.
I think i will run into some problem installing intake such as remove coolant and crankcase plenum. And connect everything back.
Any suggestion or input to make both install painless and smooth?
Old 08-01-2008 | 06:42 AM
TL1999's Avatar
anyone has any words of wisdom...
Old 08-01-2008 | 10:18 AM
AndrewA's Avatar
washer reservoir is on the opposite side of the intake and you just need to loosen it enough to get to the headlight HID module bracket.
can't help on removing the intake plenum since i have a weapon-r short ram and didn't need to remove mine.
Old 08-01-2008 | 11:15 AM
TL1999's Avatar
thanks andrew A.
Anyone else?
Old 08-01-2008 | 11:51 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
remove the plenum totally unneeded... I just cut a 2.5" section of the hose provided and plugged it back into the metal vaccum t shaped connection... I didn't rewire any coolant lines and such since I would've made a mess in the engine bay...
Old 08-01-2008 | 03:43 PM
TL1999's Avatar
thanks stillhere153
anyone else has word of wisdom?
Old 08-01-2008 | 04:40 PM
omnuts's Avatar
2006 TL: WDP/Ebony
you will be fine, just pay attention to what you disconnect and take off.. just do the reverse.. GL
Old 08-02-2008 | 12:10 AM
94 DC4 RS LSV/Turbo
did you do it?
Old 08-02-2008 | 10:00 AM
TL1999's Avatar
started too late, I finish the headlights...but didn't do the intake....
will post some pictures up tonight....
Old 08-02-2008 | 10:56 AM
omnuts's Avatar
2006 TL: WDP/Ebony
^ you should continue today w/ the intake.. this way u don't have to remove the bumper again...
Old 08-02-2008 | 09:51 PM
TL1999's Avatar
i agree...but needed the car today
cycdaniel
12-17-2019 10:58 AM
hues10
1G RDX (2007-2012)
09-07-2016 03:47 PM
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Installing Headlights and Intake Tonight, Any suggestion
