I pulled a 13.94 @ 103.03mph in my Base Auto!
Old 11-15-2016, 11:51 AM
  #361
Received 16,263 Likes on 11,973 Posts
let's all chant in unison.
PLEXI- GLASS!
Old 11-15-2016, 11:54 AM
  #362
TheTLProject's Avatar
that's all you got from that?
Lol no but I want to know if for the time being I can just drop the power window motors out but still retain the windows until I can afford plexiglass
Old 11-15-2016, 01:11 PM
  #363
Some of you may or may not be familiar with this guy but he agreed to do a review of my car. His name is David Patterson aka ThatDudeInBlue. I'm on my second reply from him now so we are slowly closing in on getting the car on his YouTube channel.
Old 11-15-2016, 01:34 PM
  #364
rockstar143's Avatar
Received 19,991 Likes on 14,500 Posts
something tells me there are liabilities driving a car with a cracked windshield on the street and reviewing on youtube. he might pass.
hit up matt farah instead.
Old 11-15-2016, 01:38 PM
  #365
Received 8,705 Likes on 6,714 Posts
Old 11-15-2016, 01:51 PM
  #366
Changed my mind...
never mind those pesky details.
That's super lit, Fam!
The following 2 users liked this post by rockstar143:
Oh Sickest TL (11-21-2016), TheTLProject (11-15-2016)
Old 11-15-2016, 01:56 PM
  #367
Forgot to mention the windshield was fixed recently. Used a credit card (go figure)
  #368
Matt Farah got back to me too and doesn't want to do any more TL'S.
Old 11-15-2016, 02:02 PM
  #369
oh good, responsible.
could have told us!
I'm sure the gofundme's are being refunded as we speak.
Old 11-15-2016, 02:04 PM
  #370
could have told us!
Not really it's at 25 bucks and I haven't taken it out yet
Old 11-15-2016, 02:05 PM
  #371
you gave up too soon! that cash was coming bro!
Looking forward to that video review...
I wish you'd contact that wrxsubarufan car reviewer, he's one of my favorites.
Old 11-15-2016, 02:09 PM
  #372
Posting that GoFundMe on the Acura TL Facebook page was a huge mistake. But it got me 25 bucks toward the cause so that's surely better than nothing. I've heard of SubaruWRXFan and watch his videos once in a while.
Old 11-15-2016, 02:10 PM
  #373
A mistake because of the immense negative backlash I got from it
Old 11-15-2016, 02:16 PM
  #374
LOL...
Well, I'm sure you understand why you got backlash, right?
Dude, that guy reviewing cars is hilarious when he gets excited.
Old 11-15-2016, 02:19 PM
  #375
LOL...
Yeah lmao he is
Old 11-15-2016, 02:21 PM
  #376
no one likes a beggar!
Old 11-15-2016, 04:47 PM
  #377
A booger? So sticky!
Well, I look forward to the video if the guy does decide to review your car.
Does he normally review alone? Or like interview style? You'll have to put the seat and your weight back in?
Old 11-15-2016, 05:26 PM
  #378
He does it all. He's ridden alone for some videos. I'll just tape this to the "dash" and all his questions will be answered : )
2006 Full-Bolt Ons/Gutted Acura TL Auto Base
AEM 3.25 inch Cold Air Intake
Ram-Air Mod
Throttle Body Coolant Bypass
EGR Valve Bypass
J37 Throttle Body
J37 Intake Manifold
P2R J37 Throttle Body Spacer
P2R J37 Intake Manifold Spacer
P2R J37 TB Thermal Gasket x2
P2R J37 IM Thermal Gasket x1
RV6 Hi-Flow PreCats
ATLP V2 J-Pipe
JE Test Pipe
Vibrant 2.5 inch Inlet/Outlet Ultra Quiet Resonator
XLR8 Y-Pipe
Rear Mufflers Delete w/ XLR8 Single Tips
UR Lightweight Underdrive Crank Pulley
AEM Fuel/Ignition Controller
BoomSlang Adapter Harness
BrakeLogic Drilled/Slotted Front & Rear Rotors
Hawk HPS Brake Pads
BFGoodrich GForce Comp2 A/S 235/45/17 Rear
Bridgestone Potenza RE71R 235/45/17 Front
Lightweight Wheels
Stock Suspension
Pro-Tuned By JE Import Performance
Weight Saved:
Hood Insulation (2lbs)
Sound System Amplifier (3lbs)
Shifter Column Top Plate/Friction Strip (.5lbs)
Center Console Bracket (.5lbs)
AC Blower Cover (.75lbs)
AC Controls + Navi Screen (4lbs)
AC Top Vent + Clock (1.5 lbs)
AC Blower Motor + Filter (6lbs)
AC Rear Routed Air Ducting (1lb)
Driver/Passenger Air Vent + Trim (2lbs)
Leftover Carpeting (.25lbs)
Engine Bay Grill Cover (1lb)
Trunk Vibration Dampener (1lb)
Stock Airbox Replaced w/ CAI (8lbs)
Weather Strip (above hood) (2lbs)
Engine Bay Covers (6lbs)
Spare Tire (36lbs)
Rear Floor Mats (6lbs)
Rear Seat (46lbs)
Drivers/Passengers Seat Kick Panels (10lbs)
E-Brake Hand Assembly (5.5lbs)
Rear Window Light Cover (.5lbs)
Interior Carpeting + Insulation (25lbs)
Door and Center Console Trim (10lbs)
Front Floor Mats (5lbs)
Glove Box (9lbs)
Dashboard Removal (75%, 7lbs)
Glove Box Mounting Beam (.5lbs)
Trunk Insulation (23lbs)
Lighter Exhaust Parts (30lbs)
Lighter Intake Manifold (8lbs)
Passenger Air Bag (13lbs)
Side Air Bags (10lbs)
Air Bag Trim Pieces (4lbs)
UR Lightweight Underdrive Crank Pulley (7lbs static, 21lbs dynamic)
Headliner and Plastic Bracket (6lbs)
Rear Door Panels (14lbs)
Center Console (13lbs)
Rear Speaker + Rear Sub (8lbs)
Center Speaker (.5 lbs)
Drivers/Passengers Side Tweeters (1lb)
Rear Seat Belts (6lbs)
Rear Speaker Cover (5lbs)
Foot Rest Plate (1.2lbs)
Partial Firewall Insulation (10lbs)
Radio Delete (6.5lbs)
Metal Front/Rear Door Accent Trim (2lbs)
Front Door Panels and Front Speakers (22.5lbs)
DVD Drive + Touch Sensor + Buttons (5.5lbs)
Rear Wheel Well Insulation (3lbs)
Sun Visors (2.5lbs)
XM Antenna (.5lb)
Front bumper vibration damper and support (26lbs)
Motegi TrakLite V2 Wheels (55lbs static, 108lbs dynamic)
Full exhaust heat shield delete (3lbs)
Steering wheel undertrim (1lb)
Passenger Seat Head Rest (3lbs)
Passenger Seat (57lbs)
Current (New) Scale Weight: 3013lbs (less than a Prius)
Factory (OEM) Scale Weight: 3580lbs
Static Weight Removed : 567lbs
Rotational Weight Removed : 129lbs
Total (Static + Rotational) Weight Removed : 639lbs
Theoretical Weight Including Rotational Weight Reduction : 2884lbs
Fluids Used
Motor Oil - Motul Fully Synthetic
Transmission Fluid - Honda DW-1 ATF
Pending mods
Innovative Polyurethane Motor Mounts (85A)
RacingBrake Lightweight Front Rotors
Tein Street Advance Coilover Suspension
Type S Non-Adjustable Front Sway Bar
Progress Adjustable Rear Sway Bar
Lightweight Racing Seats
Larger 4 Inch Intake w/ Oversized AirRaid Filter
Ported & Polished Lower Intake Runners
Ported & Polished Intake Manifold
Ported & Polished Throttle Body
Nitto Drag Radials (245/45/17)
Full AC Delete
My YouTube channel with every video for the car so far:
https://m.youtube.com/user/Dark04GTS
Old 11-15-2016, 05:35 PM
  #379
don't be shocked if he tl;dr you and just says "this is an acura tl with some exhaust and interior taken out, sounds fast "
Old 11-15-2016, 06:56 PM
  #380
what does "tl:dr" mean?
Old 11-15-2016, 07:06 PM
  #381
Old 11-15-2016, 07:19 PM
  #382
Oh lol
Old 11-15-2016, 07:37 PM
  #383
LMAO, you googled?
Old 11-15-2016, 07:52 PM
  #384
LMAO, you googled?
Nah I thought that it was HTML for the smiley you just posted
Old 11-15-2016, 09:47 PM
  #385
So you don't know what it means
Old 11-15-2016, 10:51 PM
  #386
champaned_out's Avatar
"Too long; didn't read"
your welcome
Old 11-16-2016, 06:16 AM
  #387
It means TL Driver. Done.
Old 11-16-2016, 06:26 AM
  #388
this is hilarious...
Old 11-16-2016, 07:18 AM
  #389
Guess I'm not up to date on the internet lingo.
Old 11-16-2016, 11:10 AM
  #390
I'm barely keeping up, man...
You'll get it!
Old 11-21-2016, 07:24 PM
  #391
You'll get it!
Dont worry my car hasn't killed me yet. Made a "teaser" video for my races next year.
Old 11-21-2016, 07:59 PM
  #392
Jeff
Oh Sickest TL's Avatar
did you srsly start a go fund me account for your car
​​​​​​​WTF!
I also didnt know what tl;dr meant
Old 11-21-2016, 08:42 PM
  #393
WTF!
Desperate times called for desperate measures
Old 11-21-2016, 08:58 PM
  #394
Jeff
jeez I should start one up too
TheTLProject (11-22-2016)
Old 11-22-2016, 06:25 AM
  #395
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
Removed passenger seat. 67lbs all day.
Jeez. It looks like Jason's mask is in the front passenger footwell area.
Old 11-22-2016, 06:27 AM
  #396
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Yeah now it's very noticeable from the front that it's gutted since one of the seats are removed
You should totally drive for Uber in that thing. Imagine the space in the back seat!
Old 11-22-2016, 06:45 AM
  #397
where's the seat belt?
gone, because weight savings.
Old 11-22-2016, 06:49 AM
  #398
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I fail to see your point.
Old 11-22-2016, 06:58 AM
  #399
maybe they could get a bargainuber discount?
Old 11-22-2016, 08:30 AM
  #400
There is no back seat lol it's got more room than a small SUV
Quick Reply: I pulled a 13.94 @ 103.03mph in my Base Auto!
