Hi-Speed's race engine swap
Old 01-09-2015 | 05:15 PM
  #81
Hi speed's Avatar
runnin a little boost
Found some pics from Libert's build. Maybe I'm wrong, I thought the pistons would be dished. Also with 9:1 comp it seems like it would be pretty apparent looking at the piston head.
Old 01-09-2015 | 06:32 PM
  #82
Hi speed's Avatar
I came home and checked out the stock pistons. The middle portion of the OEM piston is much larger / higher and protrudes past the top of the piston. The pistons in the new engine looked almost flush with the piston top. I am waiting on a P2R IM spacer to arrive to allow a little more room for the fittings going to the fuel rails and then I will have the car tuned.
Old 01-09-2015 | 07:21 PM
  #83
mzilvar's Avatar
tony the tiger used wiseco pistons in this build:
https://acurazine.com/forums/perform...00-whp-901774/
those actually look a little similar to the ones he used with less of a dome though and different valve reliefs any serial number or part number on them like in the pics in the other thread?
Old 01-09-2015 | 07:51 PM
  #84
Hi speed's Avatar
Tony was doing a high comp build, so his pistons would look different. I couldn't find any serial numbers on the pistons but, did find a pic Libert posted of his pistons and they look identical to the ones in the new engine. The shock of not seeing dished pistons was what scared me. Once I was able to get home and check out the stock pistons and found the pic, it eased my concerns. Looking at the stock pistons or in pics, it's hard to see how tall the dome is.
Thanks for the help, I expected to be excited after my shop visit and was throw for a loop by the pistons and everyone saying "yup those don't look low comp " dispite knowing this is a low comp build.
Old 01-09-2015 | 11:34 PM
  #85
gerzand's Avatar
If you do the math of how many CC's are actually needed comprised between the valve reliefs and deck height of a flat top piston to significantly lower the compression ratio, it's not much. I have custom wiseco flat top pistons for my application that sit .005" below below the block's deck height and it got me to 9.5:1cr rather quickly. This appears normal by the pics you've taken.
Old 01-10-2015 | 08:37 AM
  #86
KN_TL's Avatar
Here are some pics of my off the shelf Wiseco pistons with a -9 dish and according to the catalog is a 9.3:1 C/R. In their catalog it's listed as a K568M89 for a K20 RSX-S. Could be the combustion chamber on the K20 is a lot smaller but I am going to measure my results and will let you know what I actually get.
http://www.wiseco.com/Catalogs/Sport...eteCatalog.pdf
Old 01-10-2015 | 09:36 AM
  #87
screaminz28's Avatar
K20 is 50.5 (listed) and using the calculator that Gerzand posted in a different thread, and to get numbers matching Wiseco's CR, I used a .1 deck clearance. With a 5 cc dome, that gives the 11.62 listed on Wiseco. With the -9cc dome of the pistons you have, it shows as 9.31.
For the increased combustion chamber of the J32, (52.5cc chamber I presume) it shows CR at 8.94.
They don't have anything in between that size - you have to jump to the 5cc positive dome which puts CR at 11:1.
Old 01-10-2015 | 10:01 AM
  #88
gerzand's Avatar
I see based on your calculator results that you used 53.5cc for the jseries head combustion chamber volume (which is correct) but then accidentally typed 52.5 on your post above. I'm just making this post to inform folks so it doesn't confuse anyone when they try the same math themselves.
Old 01-10-2015 | 04:56 PM
  #89
Thanks - totally fat fingered that.
Old 01-10-2015 | 08:00 PM
  #90
rockstar143's Avatar
Fat fingers are Andy's specialty.
Old 01-29-2015 | 09:37 PM
  #91
Hi speed's Avatar
Update:
Did a little tuning yesterday. I couldn't stay for the whole dyno session but, did get some pics of the progress. I planed to tune to 600 WHP but, after a lot of thought I decided to limit the power to 450 WHP. The car has been down for a long time and I don't want to risk the transmission. You have to love how turbos TQ and HP numbers are almost identical.
I don't have the final dyno charts but, I was told we made the target numbers. The lower dyno chart is from running the AEM Fic when I first had the turbo installed.
Old 01-29-2015 | 10:33 PM
  #92
UTAH TSX's Avatar
Nice curious how much boost it took to get over the 400 mark, I was surprised that we got 400 with our boost falling to 5 PSI. Have fun driving bet you've been missing the surge of power
Old 01-30-2015 | 10:46 PM
  #93
Hi speed's Avatar
I think the 405 WHP run was 8 psi. I haven't looked into you setup but, if you have a ball bearing turbo combined with the extra displacement and high comp you might be making 400 WHP at a lower psi. Are you going to dyno the car once your done tuning? I really do miss the power, my commute car has about 70 WHP (civic HX ).
Old 01-31-2015 | 12:39 AM
  #94
UTAH TSX's Avatar
Yeah we will put it on a dyno when the tuning is done, it's taking a bit trying to get the boost stable and not spike, the broken piston story's has us a little nervous
Old 01-31-2015 | 06:13 PM
  #95
yungone501's Avatar
J-series addict
Are you running meth injection on your setup?
Old 01-31-2015 | 07:56 PM
  #96
UTAH TSX's Avatar
No meth just careful tuning, we have pee water 91 octane
Old 02-01-2015 | 11:37 AM
  #97
yungone501's Avatar
J-series addict
Why not use it then? It will help the IATs, the combustion temps, EGTs, knock suppression, etc...just curious. Especially since you fear breaking things internally on your stock motor.
Old 02-01-2015 | 06:52 PM
  #98
UTAH TSX's Avatar
#1 I hate it to much crap pumps tanks controller lines #2 It's a DD #3 I think we can make plenty of power without it #4 refer to #1, My kid want's it but I'm fighting it
Old 02-01-2015 | 07:59 PM
  #99
Hi speed's Avatar
I'm using the windshield washer tank to hold the methanol/water mix and there is a nice mounting spot for the pump right below the tank. The AEM controller is pretty easy to use as well if you guys change your mind. I don't use or have the windshield sprayers connected anyway, since I have removed the cowl below the windshield to aid in ventilation of the engine compartment.
My methanol injection system was damaged in a rain storm, so it not working. The plan was to tune without it and just run it as a safe guard, so I will fix it at some point. I welded a bung for the methanol nozzle about 2 feet from the TB and seem to be working pretty well. I also have only gone thru 1 gal of "boost juice " in 10k+ miles, so even with the larger jet installed and a good bit of driving in boost I didn't go thru much.
Old 02-01-2015 | 08:25 PM
  #100
Hi speed's Avatar
The size of the windshield washer tank is massive. The oil cooler has also helped a lot to keep temps in check and it adds another quart to the oil system. I have been running this plate style Earls oil cooler on older mustangs for a long time and they are very durable even when mounted in a area hit by debris.
Old 02-01-2015 | 09:56 PM
  #101
yungone501's Avatar
J-series addict
Hi Speed is right. Its a much simpler system than most imagine it to be and other than the need to add fluid, its relatively a maintenance free/automated setup. Its simplicity (not to mention recently improved technology for increased reliability) and cost makes it almost a necessity for anyone running boost. It will give knock resistance comparable to race fuel. I know admitting your son is right isn't very easy to do (mine is 12 and thinks he's an adult) but you should reconsider the decision against using it. Just saying...
Old 02-02-2015 | 06:37 AM
  #102
KN_TL's Avatar
I agree with the meth injection addition as well but you both live in sunny warm areas.
I had initially used my windshield washer bottle as my tank but found I needed my washer sprayers being in a 4 season state.
I was able to fit another bottle next to the washer bottle but it isn't as big so I also installed a float switch. I still need to wire it into my boost controller as a failsafe when the bottle is empty.
Yes, more work but worth it.
I would also recommend Alky over AEM. Julio is awesome to work with.
Old 02-02-2015 | 08:23 AM
  #103
thisaznboi88's Avatar
I run this
Aquamist direct
teh CL (02-02-2015)
Old 02-02-2015 | 08:38 AM
  #104
KN_TL's Avatar
Originally Posted by thisaznboi88
I run this
Aquamist direct
Those are extremely nice systems.....
Old 02-04-2015 | 06:46 PM
  #105
Hi speed's Avatar
Update on head damage:
I picked up Bert's heads today from the shop and pulled the cams out of both the damaged and non damaged head. What I found seemed to warrant my recent head swap. Both cams had some gaulding on the retaining lobes, with what I think is the damaged heads cam being the worst. Both cams also had a good bit of rust on the lobes and retaining surfaces. The engine sat for a long time before install and I think that let enough moisture in to damage the cams. Here are some pics I took of both cams.
Old 02-04-2015 | 11:20 PM
  #106
good call on the swap
Old 02-06-2015 | 08:03 PM
  #107
Hi speed's Avatar
The car has been home now for a few days and I finally had a chance to drive around a little bit. The extra power combined with it coming in much more quickly has been fun. The twin disk clutch is definitely a challenge to drive,with the instant grab and lightweight flywheel starting from a stop has resulted in quite a few stalls. Once the car is moving there is no problem but, starting from a stop is taking some getting use to. I have always driven the car pretty gently so riding the clutch and launching at a higher rpm is difficult to get use to.
Now I'm on to fixing the Methanol system and replacing the o2 sensor. I hope the Inovate AFR controller is not damaged from the water I stupidly drove thru. With the car running as rich as it was, I fouled 2 o2 sensors since the turbo was installed but, it did die around the time of the puddle incident. Here's a pic of the car resting with its friend the Mustang.
Old 02-07-2015 | 03:55 PM
  #108
6spd-GERCO's Avatar
Very nice Hi Speed! Why did you go with a lightweight flywheel? Just curious.
Old 02-07-2015 | 06:05 PM
  #109
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Sup buddy! Amazing work man! Glad to see you're still in the game. I remember before supercharging my TL how many threads I read and read almost every single post you made about supercharging the TL. Other than power, which would you have liked better the Turbo or the supercharger?
I can't pull away from the whine, sounds so awesome.
Old 02-07-2015 | 07:00 PM
  #110
UTAH TSX's Avatar
Looks good but you're left leg is going to be all beefy if you drive it to much LOL I see you have the cowl off to let the heat out we are messing with that now that it's warming up here in Utah
Old 02-07-2015 | 07:35 PM
  #111
Cj002's Avatar
This build sounds awesome! I am fairly new to this forum. Anyone hear word on the CT supercharger? Is it worth the money? Or would it be better to just go with a Turbo? Also, the S2000 motor swap...would that fit in a 3rd gen TL? I have an 04 TL and I am starting to price upgrades and thangs, so any input ya'll could throw my way is greatly appreciated.
Thank you,
Chris
Old 02-07-2015 | 10:48 PM
  #112
Hi speed's Avatar
The stock flywheel is a two piece dampened flywheel to absorb the shock of shifting, the new flywheel is the more traditional solid flywheel. The aluminum flywheel used for the twin disc clutch is quite a bit lighter.
Old 02-07-2015 | 11:00 PM
  #113
Hi speed's Avatar
I really loved the SC whine but, the way power comes in with the turbo I'm happier with the turbo. For someone starting or staying with a stock car the SC would be the best bet, the whine and power increase from stock with free flowing exhaust is the best bang for the buck.
04WDPSeDaN (02-08-2015)
Old 02-07-2015 | 11:07 PM
  #114
Hi speed's Avatar
Thank you,
Chris
See if you can find the blackmarket section (for sale parts section ) There is a SC available, other wise check with one of our vendors. The s2000 engine idea is not worth it.
Old 02-08-2015 | 07:28 AM
  #115
KN_TL's Avatar
I was amazed how much pedal effort there was with the Tilton twin disc. My typical driving is around town so I invested in the hydraulic release setup.
Old 02-08-2015 | 01:34 PM
  #116
Mystralhawk's Avatar
Hey there, I bought a B&M trans cooler (for my AT) but realized I liked the mounting design of your Earls cooler much better. Can you tell me which one you ordered or the size?
One of the issues I've seen with plate coolers is that they want you to use the straws to poke through your radiator or you have to find a weird way to mount them.
Thanks!
Old 02-08-2015 | 04:26 PM
  #117
Hi speed's Avatar
Thanks!
The cooler I used was 4 inch tall by 12 inches long and 2 inches thick using -8 AN lines. That said I was trying to look up the part # for you and I looks like its not offered any more in -8 AN fittings. The replacement part uses -10 AN fittings and is 13 inches long. Your using it to cool you tranny so the larger lines should be ok. I would get the black version since it hides it the cooler better. Check this one out.
http://www.summitracing.com/parts/ea...aerl/overview/
Old 02-08-2015 | 06:02 PM
  #118
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
I know all about that whine. I love it! Keep up the great work on your TL buddy!
Hi speed (02-08-2015)
Old 02-08-2015 | 06:35 PM
  #119
Hi speed's Avatar
That looks sweet, I badly want to do a polished intake. I bought a used IM a while back and haven't got around to polishing it. Also trying to decide on black or blue power coating for the valve cover.
Old 02-08-2015 | 06:40 PM
  #120
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
It wasn't all that terrible. If you have a hand sander start with 80 and work your way to wet sanding 1000 to 4000 grit. Use mothers aluminum polish and put in a lot of elbow grease. It took me about 3 solid days (Friday-Sunday) to do the intake. The blower was a few hours. I spray painted my valve covers, totally regret it now. Powder coating is a MUST. I would do something nice with pearl in it. Everything else is black under the hood. I got my wheels powder coated. I was in this guys office for 3 hours picking colors because everything looks great! If you need any help let me know.
Quick Reply: Hi-Speed's race engine swap
