Has anyone tried to replicate that RV6 True Dual exhaust sound?
In my search for the best sounding exhaust, I've come to the conclusion that the RV6 True Dual sounds much better than anything I've heard on a TL. I just wish I could afford one.
I'm looking into putting together a custom setup that sounds something like that one. I assume its characteristic sound comes from the fact that it uses two 2.25" pipes.
The only dual in/dual out resonator I've come across is this one. Anyone have suggestions for other ones?
I'm also trying to figure out what mufflers to use. Should I go with a straight through perforated core packed design or a chambered design? What type are the mufflers in the RV6?
Does going to dual 2.25" pipes result in a loss of low-end torque or gas mileage?
Here's a video of the RV6 compared to the ATLP.
https://www.youtube.com/watch?v=AcsvcwICMbc#t=2m41s
Amazon.com: OBX Univeral Dual In Out Oval Muffler Resonator KV5014 Accord Corolla Camry Neon Integra Supra Prelud Without Tip: Automotive
LMAO, I was going to link that video for you. Contact Anil (swoosh user name). He's got a custom set up and has gone down different paths, most recently he was eliminating rasp and I believe he used RV6 as a guide. Okay, I happen to know for a fact that he did
Good luck on your quest, friend. It is an intoxicating sound. No loss of anything to speak of, either.
robocam (04-28-2014)
Yeah, I will say that to duplicate the sound will be tough. Justin and I basically have the same set up and even ours sound different due to slight differences (mine wrapped, he has different cats...even different tips). I couldn't believe when I was getting the tips put on, what a difference it made to the sound when they cut the old ones off!
The following 2 users liked this post by justnspace:
robocam (04-30-2014),
StealthTL-S (04-29-2014)
So both you and Justin have the RV6 True Dual? What kind of mufflers are on there? Are they straight-through with perforated tubing like the Magnaflow 11365? And do you know if the resonator is like that too?
That's interesting. How do you think the tips changed the sound? Do you guys have videos of your exhausts?
I have no idea about the mufflers or resonator, I purchased it from one of the original 8 made with the tiny tips. When they cut them off, they were shooting sound into the inner rear bumper making it LOUD in the car. Those are custom oem look alike tips that some local exhaust dude sourced for me.
My car is the one on the right in the original posted video.
08 TL type-S
Thanks much for the photos. Lookin good! I don't want the tips sticking out like that, but I do have the rear Aspec kit, so I would prefer the exhaust on a TL with the rear A-spec kit. Looks good! But, I don't have $1600!
Nice, haha, it sounds so good! I really like the OEM look alike tips too. How's the drone while cruising?
If you look into your mufflers, do you see a straight pipe with holes on the side (perforations)?
robocam (04-29-2014)
Not sure if you can check, because the way the pipes are bent / shaped, you can't just look through it.
The following 2 users liked this post by FamilyGuy:
robocam (04-29-2014),
rockstar143 (04-29-2014)
08 TL type-S
Is this drone because of the RV6 dual exhaust in 6th or is it from your Pre-cat deletes...I'm wondering about this drone with High flow cats, j pipe, with the RV6 dual .....no drone on highway?
Source of those pictures. https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/inside-type-s-muffler-853800/
There are a lot of people on Amazon raving about this resonator (not in this size but many more reviews for other sizes). I wonder if it will get rid of drone.
I also think I like the sound of the GReddy systems, but it seems that some members think it's inappropriate for a TL? I personally like the look. Do people think it makes the TL look cheap or something? Why don't people like it?
Here's a video of what it sounds like.
https://www.youtube.com/watch?v=srar7kN5xu8#t=0m08s
The sound seems to be just a higher pitched exhaust listening to other videos, although hearing it in person would be better.
Maybe with a better steel grade material will make the exhaust noise better... I've always like the lower growl sounds than a high pitched one.
johnpancakes014
04-08-2016 06:47 AM
IIDXholic
10-08-2015 07:53 AM
