Exaust Help
Old Jun 17, 2008 | 11:20 PM
bcbtony's Avatar
07 WDP TL
Exaust Help
Hi i need some help i had 2 Apexi N1 i got bored of it n switch it to hks hi power ti turbo i left my car there at the shop to be done while i was at school went baack every thing look good and payed the guy i then went to test my new exaust it sounded alot deeper but i felt lost in horse power i then went home n look at my exaust n when i looked inside my exaust n saw this and im guessin this is the reason why i lost power but not sure if it is but i apperciate it if yu guys can help me on this.
Old Jun 18, 2008 | 12:45 AM
TLAdvanced's Avatar
The Kinetics of Bleu
What do you mean?? Because of the straight thru design?
Old Jun 18, 2008 | 01:00 AM
bcbtony's Avatar
07 WDP TL
no if yu look in the picture at the back you will see the piping that goes in to the muffler is angled which is blocking the starit thru design
Old Jun 18, 2008 | 02:29 AM
JCL622's Avatar
A-spec steering wheel ftw
umm your piping is supposed to be bent in certain areas to fit with the original piping...
actually if it was straight thru ignoring where the hangers are and shields, you'd probably lose power.
i think the first thing you want to check is what's the piping diameter for everything. 2.5" all around is max for cars with no boost. if you have 3" piping ...well it's not breathing properly.
Old Jun 18, 2008 | 02:53 AM
scotterson's Avatar
wat
+1
find out what diameter the piping is.
Old Jun 18, 2008 | 12:17 PM
bcbtony's Avatar
07 WDP TL
it is 2.5'' piping
Old Jun 18, 2008 | 12:22 PM
bcbtony's Avatar
07 WDP TL
like if yu look at the pictire ita at the back the pipe that goes into muffler is angled where when it goes out of the exaust it hits the wall of the exaust then it comes out
Old Jun 18, 2008 | 12:24 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
well looks to me like their bends suck ass... whatever happend to 90 degrees?
Old Jun 18, 2008 | 03:37 PM
bcbtony's Avatar
07 WDP TL
yea do you know if this i how im losing power????
Old Jun 18, 2008 | 06:08 PM
94 DC4 RS LSV/Turbo
could well be, you have to make sure that if they crush bent they didn't over bend... because a crush bend alters the diameter of the tubing...
also you have to make sure where they welded the 2 sections together they overlapped them, because a direct weld on 2 pipes creates restriction aswell...
all these factors could be the cause, or it could well be you have to do something as simple as reset the ecu
Old Jun 18, 2008 | 10:51 PM
JCL622's Avatar
yea i just logged on, cuz i remembered ~ you probably didn't reset the ECU....try that first.
also if this guy was really shitty, stillhere's right, if he crushbent, your airflow is messed up, uneven surfaces all the way fromt he down pipes to the exhaust tips in the end will definitely create a feel-able loss in power.
Billu99tl
Sep 13, 2015 11:30 AM
notcreative
Apr 16, 2006 08:54 PM
MemRheins
Console & Computer Gaming
Mar 7, 2005 01:35 AM
dennis
Jan 15, 2003 07:52 AM
wild2.3cl
Nov 4, 2002 05:45 PM
