educate me on the TL's cats
Old Jun 18, 2010 | 10:28 AM
babbagandu's Avatar
I am coming from a G35 which only had 2 cats. No precats or secondary cats or fancy stuff like that. Replacing the cats was plain and simple for that car.
So, can someone fill me in on the cat setup for the TL? What do most people do when modyfing the cats for the TL? Thanks
Old Jun 18, 2010 | 10:43 AM
A simple search will yield great results. As this topic has been beaten to death.
search for these terms:
Pre-cat deletes
j-pipe
3rd cat
exhaust
RV6 PCD
RV6 V3 J-pipe
Old Jun 18, 2010 | 01:28 PM
07lightning's Avatar
there are 2 primary cats. then the third cat, then a resonator then 2 mufflers.
for the primarys you can get pre-cat deletes, or high flow cats.
for the third you can delete it or get a high flowing cat. deleting this does not throw a cel.
Old Jun 18, 2010 | 01:32 PM
Rick_TL-S's Avatar
I have seen the pre-cats, but who's offering high flow cats for the primarys?
Old Jun 18, 2010 | 01:35 PM
babbagandu's Avatar
cool thanks for the info. Would buying a catback delete the third cat or not?
Old Jun 18, 2010 | 01:37 PM
babbagandu's Avatar
Won't let me edit my last post.
One more question as I am a little confused. So there are 2 precats before the primary cats? So you are saying that precat deletes takes care of the primary as well?
Old Jun 18, 2010 | 02:07 PM
j1n's Avatar
j1n
No they call them "ore cat deletes" but there just talking about the main 2 cats. there are only 3 cats. the first 2 and the third which is right behind the jpipe.
it goes "precats" (2cats) > Jpipe > 3rd cat> resonator>mid muff> mufflers
no catback doesnt delete the 3rd cat. just get a test pipe or straight pipe and delete the third cat.
Old Jun 19, 2010 | 01:14 AM
D's Up's Avatar
9 mpg.
Random Q, sorry - how does it feel to drive the TL in comparison to the G35?
Old Jun 19, 2010 | 08:57 AM
j1n's Avatar
j1n
search...... there have been many threads on this.
Old Jun 19, 2010 | 09:03 AM
d-townhakuzo's Avatar
Here. The engine has 2 cats leaving it (one in front, one in back), then the cats connect to the j-pipe, which connects to the 3rd cat, which connects to the cat-back which contains a resonator, mid muffler, and 2 mufflers at the end, going to each tip.
Old Jun 19, 2010 | 04:00 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
all dem posts and no pics...
those are the primary cats... the j-series after 03 for the honda and 04 for acura no longer came with headers... only a 4 bolt (turbo style flange at the head)... what this means is the cats essentially are downpipes
at one point in time "eshift performance" made hiflowing cats... no defunct... because the 'metal' cats deteriorated... I had them on my car
Cat deletes
and w/ supercharger installed
Old Jun 19, 2010 | 04:08 PM
pohljm's Avatar
Pro cats only deteriorated when they were run with the S/C mine are still fine after 60K
Old Jun 20, 2010 | 09:52 AM
MrHeeltoe's Avatar
Former Sponsor
I wrote up an article here:
http://www.heeltoeauto.com/pitboard/?p=149
Old Jun 20, 2010 | 12:59 PM
1islandparadise's Avatar
This helps a bunch...I've heard all the terms but didn't know what order it was all located in. Now all this makes sense for all the different stage exhausts also. Thanks.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
