DIY turbo idea for cheap? LOL
Old 01-17-2016, 09:36 AM
  #201
thisaznboi88's Avatar
I think i am just going to run the turbo asis just because the seller of the turbine housing is lagging so bad. I emailed him and asked for pix and i will buy it. No response back. I called and talked to him on friday andnasked for pictures and no response back. He did tell me that he used a garrett .63 housing for for the hx35. He cant get the .70 ar since those are rare and is currently making some .80 ar housing. But after that conversation he raised the price of the housing to 160 instead of 150 shipped.. So I think i am going to say screw it and run the turbo as it.
I bought a turbosmart boost gauge last night. I plan to hook it up to the manifold port so i can see actual boost that is going to the engine after pressure drop from the intercooler. That was I can correct it to run at 6 psi with the boost controller.
O yeah i still have one problem. Since that glitch on ebay I am missing parts because the sellers do not have a record of it on ebay, but they were all paid through paypal. So far only the intercooler and turbosmart boost t was sent out. I really need that intercooler piping also. The o2 sensor was refunded to me last night. I am hoping that the spark plugs will also be sent, but if not i hope they refund me also. I can pick up a set at advance auto parts.
Also tax season is just around the corner. So maybe more money for stuff.
Originally Posted by UTAH TSX
Did you figure out how your exhaust housing will work yet ? have you found anyone that has used the same housing you have on a similar or close displacement as your engine ?
Looking good the parts pile keeps building that's the hardest part (financing it)
Old 01-17-2016, 10:37 AM
  #202
I like math so here some equation to calculate air filter size for turbo application
Square inches of filter required = (lbs boost/ 14.7) + 1 x CID x max RPM
20,839
Filter Height= in2 of filter + .75
Filter Dia. X 3.14
Old 01-17-2016, 01:00 PM
  #203
Amazon.com: Turbosmart TS-0101-2023 52 mm - 2-1/16" 0-30 PSI Boost Gauge for Gated Boost Control Valves: Automotive Amazon.com: Turbosmart TS-0101-2023 52 mm - 2-1/16" 0-30 PSI Boost Gauge for Gated Boost Control Valves: Automotive
Old 01-17-2016, 01:40 PM
  #204
screaminz28's Avatar
how are you going to run the IC piping? A long straigh pipe under or over the IC to feed it, or have it run counter clockwise and then feed into the engine bay and into the throttle body?
Old 01-17-2016, 02:13 PM
  #205
Good question. On the passenger side its going to be a U pipe, then straight under near the front of the lower subframe, then a right angle up back to the turbo. On the driver side I would run it like a CAI. BOV is going to be closest to the TB. Unless you guys suggest other wise.
I am going to guess this will cause a large increase in pressure drop after the turbocharger. This is where the Boost controller comes into play, and why I have the boost gauge at the IM instead of off the turbo nipple. So what the engine sees and what they wastegate see are going to be a difference of 0.25-1psi difference depending on how much boost I lose with this setup.
So passenger side is going to be like this
Driver side
and like the upper pipe of this set up
Old 01-18-2016, 09:10 PM
  #206
well got my W2 and school tax return form. Time to do my taxes!
Old 01-19-2016, 07:42 AM
  #207
I am going to see if I can copy this guy intercooler mounting on his 4banger
Old 01-19-2016, 12:45 PM
  #208
Polished the wastegate housing, and tweaked it a little bit.
Here it is mounted on the manifold
Here is my damaged oil filter sandwich. The threads are jacked up since it was crossed threaded from the factory.
all the thread is on the bolt
Old 01-19-2016, 01:09 PM
  #209
What are you using the sandwhich adapter for?
Old 01-19-2016, 01:30 PM
  #210
Oil feed. I have no idea where to tap the block for oil. Also I might add a oil cooler in the future if needed.
Old 01-19-2016, 02:12 PM
  #211
UTAH TSX's Avatar
I would recommend using this for oil feed to turbo this goes in the back of the block by the oil filter unscrew your oil pressure sending unit screw it in and screw you sender back into it and your done just need the an 4 fitting to go into it and AN4 line to turbo and your done this is steel strong and wont strip like the cheap ones
Oil Feed Block BSP/NPT-BSP-NPT
thisaznboi88 (01-19-2016)
Old 01-19-2016, 02:18 PM
  #212
Do you have a pix of how your son did his? I am kinda clueless that why I am doing the oil sandwich. I can't find a good pix from AccordFlex and Utah type-s either
Old 01-19-2016, 05:37 PM
  #213
UTAH TSX's Avatar
Just like this, look up oil pressure sending unit on Acura parts and that will show you where it's located on a j motor
Old 01-19-2016, 06:06 PM
  #214
Number 14 on the Jseries
Old 01-19-2016, 06:19 PM
  #215
KN_TL's Avatar
The following 3 users liked this post by KN_TL:
flexer (01-25-2016), teh CL (01-20-2016), thisaznboi88 (01-19-2016)
Old 01-19-2016, 06:54 PM
  #216
@Utah TSX and KN_TL
Thank you both for making me aware that the block is BSP and not NTP. I would have screwed up that big time...
Old 01-20-2016, 12:42 PM
  #217
front mount intercooler came in. I will post pix later today. Size was 27 x 7 x 3. Core size is 21 x 7 x 3.
Old 01-22-2016, 05:08 PM
  #218
intercooler came in
Old 01-23-2016, 06:59 PM
  #219
Thinking about using this to hang the intercooler. It is perforated metal hangers straps. Can be bent to any shape and cut to any length.
http://m.homedepot.com/p/Perforated-Metal-Hanger-Straps-3-4HS/100396917
Old 01-23-2016, 07:20 PM
  #220
UTAH TSX's Avatar
Perforated Metal Hanger Straps, 3/4HS at The Home Depot - Mobile
No that stuff is paper thin, they have 1/8 inch thick 1.5 inch wide steel or aluminum strap that would work much better use steel on the bottom that takes the most stress
thisaznboi88 (01-23-2016)
Old 01-23-2016, 09:04 PM
  #221
Thanks for the idea!
Old 01-25-2016, 05:24 PM
  #222
Manual boost controller
Old 01-26-2016, 03:20 PM
  #223
10in fan came in
Boost gauge
Intercooler pipes
Old 01-26-2016, 07:02 PM
  #224
Whats the fan for? Are you going to pull air thru the FMIC, or is it to replace the factory fans?
Old 01-26-2016, 07:58 PM
  #225
to replace the factory fan on the driver side because the turbo filter sits right up against where the oem fan would go.
Old 01-27-2016, 05:11 PM
  #226
got my carbine bit for opening up the turbo down pipe. Going to be a long loud week grinding and pissing off the neighbors trying to get my 2.15in opening. I think 2.0in is doable but not 2.15in. Just too much freaken material to take off.
Here why I am porting it and cleaning up the welds.
Old 01-27-2016, 09:43 PM
  #227
AccordFlex's Avatar
Havent been on much lately due to being so slammed with work. But wow this had come a long way. Doesnt it suck just having these parts just sitting around for months not being able to use them?
Sorry I havent been much help lately but here are a few quick pics of my oil feed area. I cant get the best pics because the car is on the ground right now tucked away in the garage ready to get pulled apart. Shoot me a PM anytime you have any questions or want pics etc.
Click image for larger version
thisaznboi88 (01-27-2016)
Old 01-27-2016, 09:48 PM
  #228
how long is your oil feel line? I have a 36in one and I am thinking about selling it and getting a 51in feed line.
Old 01-27-2016, 10:13 PM
  #229
AccordFlex's Avatar
Mine doesnt have much slack at all. Im honestly not entirely sure because the oil feed line was already made and came with the JnR. It cant hurt to have the 51" to give you a little bit more slack. I would recommend an oil cooler. This helps a ton with cooling. There isnt a ton of room in the engine bay so this helps to keep that turbo cool.
Old 01-28-2016, 06:59 AM
  #230
KN_TL's Avatar
The return is strictly done by gravity so you need a nice smooth run from turbo to pan. If you are going premade, get it long and buy another end, or just buy the hose and both ends. When we got these from J&R, that's what he did.
Old 01-28-2016, 10:23 AM
  #231
I think you got confused. I was asking about the oil feed.
My return line is short and sweet like u said. Above the oil pan line also. I pour 5qt and marked off how high it went to make sure. But thanks for the reminder
Old 01-28-2016, 10:51 AM
  #232
KN_TL's Avatar
oops...sorry about that
Old 01-28-2016, 11:05 AM
  #233
foxriderar77's Avatar
this is epic, not sure how I missed it. Looks like some serious progress is being made. Good luck
Old 01-28-2016, 12:52 PM
  #234
I will look into an oil cooler also. Thanks for the pictures. I am going to have Dom tune the car and then Derek at IMW dyno the car to see what I make. I have a baseline dyno from my last build thread.
What clutch are u running? I was looking at the south bend clutch that XLR8 was offering, but I would like to see how much tq the car makes before selecting clutch.
Old 01-29-2016, 11:30 PM
  #235
I bought the longer 51in hose.
Old 01-30-2016, 12:50 PM
  #236
gasket matched the turbo today and also polished up the compressor side as much as I could
I think I will be taking the down pipe to the machine shop to have them gasket match it and smooth out the transitions
teh CL (01-30-2016)
Old 01-30-2016, 05:24 PM
  #237
Is the compressor outlet a v-band?
Old 01-30-2016, 06:16 PM
  #238
3in vband, but there like a plate on the rear. That makes it a 3in vband. I think it must be oem because it says holset also
Old 01-30-2016, 09:12 PM
  #239
Turbo(dumb)smart boost gauge installed. It is sooo bright!!
Old 01-30-2016, 10:42 PM
  #240
UTAH TSX's Avatar
hook it to the dash illumination wire so it will adjust with the dash lights or get an adjustable resistor
Quick Reply: DIY turbo idea for cheap? LOL
