cam
Old Oct 16, 2006 | 11:36 AM
acuratl732's Avatar
cam
will the 07 types cam and solenoid fit and work in the 04
Old Oct 16, 2006 | 08:52 PM
lookinco's Avatar
B A N N E D
you got specs on the 07 cam? What's the difference between the 04+ and 07 TypeS cam?
Old Oct 16, 2006 | 09:21 PM
CleanCL's Avatar
"Both the TL and TL Type-S feature single overhead camshaft cylinder heads made from pressure-cast, low-porosity aluminum, which helps to keep overall engine weight down.
The Type-S heads also feature hollow camshafts to save weight."
mentions nothing about increased lift spec in the cams. so the only benefit to swapping (which i think is possible) is the weight saving.
Old Oct 16, 2006 | 09:37 PM
lookinco's Avatar
B A N N E D
Hmm....i wonder if it's worth changing to the 07 TypeS cam when I am doing the 3.5L swap.
Old Oct 16, 2006 | 09:48 PM
CleanCL's Avatar
might as well, your heads will be off.
Old Oct 16, 2006 | 09:54 PM
lookinco's Avatar
B A N N E D
I just compared a few diagrams on the 06 TL and the 07 TypeS TL. It seems like the cam, cylinder head, valve and rocker arm looks exactly identical.
Old Oct 16, 2006 | 10:06 PM
CleanCL's Avatar
acura made no mention of a different head design. i dont think it will be a problem. order the cams from oemacuraparts.com and if they dont fit they will refund you, they allowed me to return the RL cams months after my purchase. but order the cams now, i'm sure its a special order item and will take over a month to get.
p.s. ask for lance at the above site, he's a good guy.
Old Oct 16, 2006 | 10:19 PM
lookinco's Avatar
B A N N E D
I actually ordered all my engine swap parts from oemacuraparts.com. They have great customer service and great price!
Old Oct 17, 2006 | 11:44 AM
acuratl732's Avatar
cam
how do i gte more aggressive cam timing out the 04 tl
Old Oct 17, 2006 | 12:41 PM
lookinco's Avatar
B A N N E D
Your only choice would probably be to get custom cam made.
Old Oct 17, 2006 | 12:57 PM
acuratl732's Avatar
cam
how do i go about that like what do i need and where would have to go to get it done
ExcelerateRep
Oct 14, 2015 08:20 AM
kmarqueling
Oct 3, 2015 01:14 AM
Papa Roe
Sep 26, 2015 11:45 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
V12 Inspire
Sep 10, 2015 04:46 PM
