Brembo brake kit
Old 10-14-2014, 05:58 PM
5th Gear
Nino_Vitug's Avatar
Brembo brake kit
I'm looking for a brembo brake kit for my 08 acura tl. Where do I get some?
Old 10-14-2014, 06:02 PM
Slot Machine Lubricator
1black_seven's Avatar
I found one, check it out
rockyfeller (10-30-2014)
Old 10-14-2014, 08:00 PM
screaminz28's Avatar
Do you have a Base TL with regular brakes and want to upgrade to Brembos, or are you just looking for pads and rotors for your OEM Brembos?
If you have a Base and want a brake upgrade, Brembo is probably not the best option. The OEM Brembos are not a direct bolt on and there are better options for the money.
You might check this out from one of the vendors:
StopTech Big Brake Kit - Excelerate - HOA - Japanese Performance Specialist
If you have OEM Brembos and want a set of pads and rotors, ExceleratePerformance offers those from Stoptech as well. I've also used PowerStop's kit with front and rear pads and rotors and they work great for the money.
Hope that helps.
Stuttgart_Eishockey87 (10-20-2014)
Old 10-14-2014, 08:50 PM
The Boss
Nick216's Avatar
Stoptech !
Old 10-14-2014, 09:53 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
^Is that yours Nick
Old 10-14-2014, 10:26 PM
The Boss
Nick216's Avatar
Originally Posted by EvilVirus
^Is that yours Nick
Yup
EvilVirus (10-16-2014)
Old 10-15-2014, 12:17 AM
5th Gear
Nino_Vitug's Avatar
Brembo brake kit for 08 acura tl
Hope that helps.
I have base TL. Why wouldn't brembos be good?
Old 10-15-2014, 12:22 AM
5th Gear
Nino_Vitug's Avatar
Originally Posted by Nick216
Stoptech !
Stop tech only does front brake kits? Or both?
Old 10-15-2014, 07:07 AM
TheBlueBomber's Avatar
The base didn't come with Brembos from the factory. Only the manuals and TL-S did. The Brembos aren't a direct swap and the effort needed to swap them over isn't worth the hassle imo. Especially since there are brake packages that are a direct swap and will provide better performance than the Brembos
Old 10-15-2014, 07:14 AM
The Boss
Nick216's Avatar
Just front
Old 10-15-2014, 07:44 AM
You could put OEM Brembos on, but you will need rotors, calipers, lines, and knuckles, at a minimum. There may be other parts needed. As BlueBomber said, it's not a direct swap.
The Stoptech kit is MADE for the Base TL - it bolts right on to your existing knuckle. Sometimes aftermarket is better than OEM.
Plus, I believe the stoptech kit has a bigger rotor, so you get better performance than the OEM Brembos.
Old 10-15-2014, 10:23 AM
Former Sponsor
ExcelerateRep's Avatar
Hope that helps.
We have them in stock and ready to ship!
Old 10-15-2014, 12:49 PM
Former Sponsor
Excelerate's Avatar
Our XLR8 Touring Big Brake Kit by STOPTECH is really the best option as it is a larger disc than the TL-S setup, better pads, a larger caliper, better rotors, and stainless steel brake lines.
Old 10-16-2014, 10:16 AM
EvilVirus's Avatar
Yup
Awesome shot
HOWELLiNC
10-19-2015 03:26 PM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
09-14-2015 10:10 AM
HOWELLiNC
09-10-2015 01:39 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Brembo brake kit
