Base 6MT Clutch Upgrade Options & Discussion
Old 03-31-2009, 06:59 AM
  #41
Wiggy Wiggy Wiggy
powerflow's Avatar
Originally Posted by princelybug
Would you happen to know what that price is?
I don't. I read about it somewhere on here when I was researching clutch options. I noticed it's not listed on their site too. I want to say it was about 700 bucks, but I could be way off.
Old 03-31-2009, 12:54 PM
  #42
Green Machine
t0talacuratl's Avatar
Originally Posted by HQTL6SPD
does the same apply for the stock-sized UR pulley?
Most likely since it too is lighter than the OEM pulley. Size don't matter in this case.
Old 03-31-2009, 06:22 PM
  #43
Former Sponsor
Excelerate's Avatar
We have the Clutchmaster's setup for about $1300 shipped for the Stage 2-4.
Old 03-31-2009, 06:58 PM
  #44
runnin a little boost
Hi speed's Avatar
This is a FW and clutch combo?
Old 03-31-2009, 07:36 PM
  #45
HQTL6SPD's Avatar
I always thought the issue was size since our engines are already internally balanced...
Josh/Sean what do you guys say?
Old 04-01-2009, 01:19 PM
  #46
THE J35A2...
SIRSIG's Avatar
Originally Posted by t0talacuratl
Sorry, I meant that they do not mix well. I had that issue on my turbo eclipse when I had a lighten flywheel and underdriven pulley at the same time. I had little to no low end power which made the drivability bad. Can anyone else confirm this?
I had both of them on my last set-up and they go pretty well, only thing is that you can feel a little bit of vibration on the gas pedal on WOT specially on the top end, but I don't mind that cos I love how the needle goes up so fast pass 3500rpm tho
J32 engine has a decent amount of torque on low throttle that your eclipse might not have before, i mean it's two different cars... now, it might be also different if your CL aren't FI and tuned, but like I said it flows pretty well on my part before...
Old 04-01-2009, 04:00 PM
  #47
JwongTLS's Avatar
How much harder does the clutch grab?
Do u need to change out the tranny mounts?
Old 04-01-2009, 11:54 PM
  #48
Former Whyner
RonJonTL757's Avatar
Originally Posted by exclusivedq
UPDATE: so on my way back from school, i decided that 150 miles into the new clutch, i should rip on it a little to feel it...each shift, the clutch immediatley grabs on, leaving no room for error. I noticed that in between shifts, the RPM's were not dropping as much which is great! Still got some more research to be conducted through out the next couple of days.....
150 MILES
Rule of thumb 500 miles but its your clutch. I would have waited a tad longer to start banging it around.
Old 04-02-2009, 02:15 AM
  #49
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Originally Posted by RonJonTL757
150 MILES
Yup, rule of thumb is 500 miles. I believe CM recommends 300 miles?
Old 04-02-2009, 02:56 AM
  #50
Former Whyner
Yeah somewhere in that realm. I remember when I got my Exedy stage 3 for my GSR I drove for noooo reason whatsoever I volunteering to take everyone everywhere just to get past 500 miles
Old 04-02-2009, 10:33 AM
  #51
I got the Shifts
phee's Avatar
i thought you were supposed to break in performance clutches HARD to prevent glazing..
Old 04-02-2009, 04:56 PM
  #52
exclusivedq's Avatar
150 MILES
I didnt slamm on the clutch at alllllll....i know better than that! i just rev'd it higher and shifting a little faster....im up to 360miles....almost there!!!
Old 04-02-2009, 06:51 PM
  #53
Former Sponsor
Excelerate's Avatar
Yes.
I wouldn't recommend doing the light flywheel and the lightweight pulley since they both are doing the same job in essence. It doesn't matter whether it's underdrive or stock diameter; either way the aluminum pulley is light weight.
150 MILES
Yes I would recommend a break in of 500-750 miles. That means no hard launches, no quick revs, no chirping gears; it should be a lot of city driving so you can engage and disengage the clutch at different speeds.
Old 04-02-2009, 07:31 PM
  #54
HQTL6SPD's Avatar
My question really is
Is it harmful in any way? I don't see what could be wrong with having a stock sized lightweight pulley and a lightened flywheel. Plenty of cars have had such a set up.. (pulley kit + clutch/flywheel)
Is it just about low end torque? I know throttle response would be insane!
Old 07-25-2009, 11:51 PM
  #55
wut.
CG2PROJECT's Avatar
tt
Old 07-26-2009, 12:38 AM
  #56
Opel's Avatar
stock crank pulley has a harmonic damper... if u could have the light weight flywheel. its better to leave the stock crank pulley alone...harmonic damper is there to aid the cranks balancing... the gains from flywheel tripple...u got off rotating mass, a better friction plate, the dual feature, fast revs, slow decel... u wouldn't notice any of those, if i took off ur stock pulley and replaced with the lighweight, if u didnt know i did.... so dont get greedy and leave some assistance for ur poor crank.... this isn;t a race motor...it aint balanced like u'd think.
as far as Spec clutch kits...i had that happen to me...when i got it, it looked like a painted stock PP, which it was...i called up and spoke to them....they said bcs of the self adjusting...they just supposedly re-enforced the PP to add clamping force....i didnt notice a stiffer pedal...however, my dash chatters when i pop the clutch...i mean just popping it breaks the tires without any accel whatsoever...... sometimes its hard to feel it through the pedal, on a hydralic clutch, when the stiffness of PP isn't by a lot over stock.
but the ceramic unsprung disk makes a tremendous difference.... i have no slippage.... i mean i could make any clutch slip...but abusing it properly...it holds well enough so far
Old 02-20-2011, 12:12 PM
  #57
callahan's Avatar
I bought a stage two clutch a couple months ago, now I need a light flywheel. Does anyone just sell a light flywheel and not a kit or just a clutch. Thanks
Old 09-10-2011, 02:59 PM
  #58
cleptosis's Avatar
just got a sach clutch kit yuck i liked stock better
Old 09-14-2011, 08:03 PM
  #59
Opel's Avatar
Been running the CM StageIII for about 5 months now. I have 0 complaints so far. I haven't been running it hard, so I can't elaborate much on that, but so far its the perfect clutch. Harsh enough, yet not too harsh for our weak tranny. With the deletion of the SCV, you get a great shifting experience.
As far as running it hard, Sean has tested that aspect and he speaks good things about it.
Many thanks to Sean (04Accordcpe) for his suggestions...
and also XLR8 for the decent price and fairly quick shipping (wasn't under time pressure)
And btw Josh....I haven't received an e-mail with the invoice lol
Old 09-14-2011, 10:35 PM
  #60
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
Opel posting... Looks like i got you back into cars lol
Old 09-15-2011, 09:53 AM
  #61
All motor
Sonnick's Avatar
I would've been running the CM Stage 2 kit/lw flywheel...but the car wouldn't go into gear once turned on, so now I'm selling it
Old 09-15-2011, 11:12 AM
  #62
Former Sponsor
Excelerate's Avatar
Sorry, I thought I emailed it. Send me an email to sales@excelerateperformance.com with your info and I'll send it back.
Old 09-15-2011, 02:27 PM
  #63
Opel's Avatar
nah, its cool...id just like to have it, at least for warranty purposes anyway
Soul_Deamon
11-13-2018 04:44 PM
dom
Sports Talk & Fantasy Leagues
2032
02-10-2016 01:47 PM
Zonian22
11-14-2015 01:20 PM
Quick Reply: Base 6MT Clutch Upgrade Options & Discussion
