AEM intake problem!!
Old Jan 2, 2007 | 12:39 AM
TimeAfterTime's Avatar
Hi i just installed the AEM CAI and when I tested it out, I could not go past 5 rpm any ideas?
Old Jan 2, 2007 | 01:16 AM
jordan0806's Avatar
chec any sensors that may have been connected to the intake...if one of them is unplugged...you'll throw it off
Old Jan 2, 2007 | 02:51 AM
wasupdog's Avatar
My Garage not
time - go back over each and every single step of the instructions and make sure you screwed everything down, connected everything including sensors and harnesses everywhere correctly, and put it all back together right.
the good thing is that the cai install is not that complicated so you can probably figure it out fairly quickly.
Old Jan 2, 2007 | 09:28 AM
ndx2's Avatar
6MT & LSD
eh, did you actually take the car for a spin, or did you leave it in N or P and rev the engine? If it's the latter, and you have an AT, that's just the way it is.
Old Jan 9, 2007 | 10:11 PM
MTVtec's Avatar
Got VTEC?
Exactly, there is a rev limiter set at 5 000 RPM when left in neutral or park.
Old Jan 10, 2007 | 09:56 AM
dman918's Avatar
Scoobie Specialist
Yep, I was worried at first as well, but then I actually drove around and it is fine.
Old Jan 10, 2007 | 11:18 AM
Excelerate's Avatar
Former Sponsor
LOL. That's what I was going to say. I believe the M/T is the same.
Old Jan 10, 2007 | 02:50 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Thats Honda Nanny watching your ass!
Old Jan 10, 2007 | 09:05 PM
ACCURATEin's Avatar
tehLEGOman
...haha and i hate it...sometimes i just want to listen to vtec while in neutral.
Old Jan 12, 2007 | 05:48 AM
bmaczo6's Avatar
Well? What did it turn out to be?
Old Jan 15, 2007 | 02:17 PM
PeterUbers's Avatar
ha.. betcha it turned out to be one of the aforementioned "doh's" ... he prolly had it just in park and wanted to hear the intake make some new noises and never realized we have a rev limited while in Neutral/Park...
Too embarrassed to fess up!
Old Jan 15, 2007 | 05:18 PM
Kracker's Avatar
05 TL
I didn't know that...
I know its not an issue but it kinda bothers me when people rev their car until it hits the limiter...
Old Jan 16, 2007 | 07:56 PM
Inaccurate's Avatar
I agree that it is annoying when poeple revs their engines to death in park. However, our engine is so smooth and quite, I can see that you could do it once or so without realizing it. After I had my UR Pulley installed, I pulled into my driveway at home and just hit the throttle lightly to see how quick the engine rev'ed with the new lightweight pulley. Before I had time to react, the tach is jumping to 4500 rpm. I just said "wow" and smiled as I shut it off.
Old Jan 18, 2007 | 03:58 AM
A SiQ TL's Avatar
Has anyone heard a popping noise coming from their AEM CAI? Mine has done it 3 times now, the last happened when I went from half throttle to full throttle. The car downshifted and I heard the pop from the front as it started accelerating. The other 2 times were when throttle was mashed on from a dead stop.
Old Jan 18, 2007 | 09:56 AM
CTS-V Import Slayer
I used to get that from time to time before I got the procats on...then it seemed to all but disappear. Sounded like a backfire in the intake tube or something...if you can imagine that sound.
Old Jan 18, 2007 | 02:17 PM
A SiQ TL's Avatar
yea, that's what it sounds like. Any one else have that happen, or know what it is?
Old Jan 18, 2007 | 10:42 PM
Inaccurate's Avatar
I think the pop sound is the sound of the butterfly (throttle plate) slamming open or slamming closed. The CAI is somewhat like a megaphone that amplifies sound. Plus, the low restriction filter does not muffle sounds either. So, you are now hearing the DBW (drive by wire) throttle slamming open and closed. I hear mine often during WOT shifts where the computer slams the throttle closed during the actual shift. It scared me that first few times I heard it. I quickly figured out what was happening although... I do WOT often.
Old Jan 23, 2007 | 12:33 AM
Mild7blues's Avatar
Hey guys I've been gone for some time; thanks for all the help. Shortly after I posted my problem I decided to give it a test run and it ran perfectly fine. I did not know about the rev limiter. Thanks for the help everybody.
Old Jan 23, 2007 | 12:34 AM
^^whoops, didn't know my friend signed on here, but thanks again for the help everybody.
Old Jul 10, 2008 | 10:25 PM
JsL138's Avatar
This just happened to me today. Glad to hear that it's nothing.
Old Jul 10, 2008 | 10:54 PM
Inaccurate's Avatar
For the record, I am undecided between it being a MILD backfire or the butterfly slamming closed. However, I still feel that it is normal for TL folks with CAI and most likely it is harmless.
Old May 22, 2009 | 05:25 PM
nhousepro's Avatar
Does you car still do this? I just installed the AEM V2 on my 06 TL and I get this weird puff sound when I turn my car off. Is there a fix?
Old May 22, 2009 | 06:34 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
that puff is a chamber echo... its normal
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
drone619
Jan 26, 2016 07:09 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
Abe_Froman
Sep 16, 2015 01:27 PM
