To add J-pipe+test pipe... or not to.
Old Mar 10, 2014 | 11:09 PM
JdmT's Avatar
5th Gear
I currently have the single tip resonated xlr8 catback and I get a great sound out of it. Besides hp gains, will adding the xlr8 jpipe and test pipe in place of the 3rd cat create an obnoxiously loud exhuast setup? Or will it still retain the good sound I have now on top of the horsepower gains?
Old Mar 10, 2014 | 11:50 PM
pohljm's Avatar
i cant imagine removal of the one cat will do to much. try it and report back
Old Mar 11, 2014 | 12:59 AM
TLOHTL's Avatar
Removing 1 cat ( the 3rd cat attached to j-pipe ) won't make much of a difference. Even putting PCD's won't make much of a difference. Problem is once you remove all 3 cats it gets tricky..... You will experience lots of rasp if you don't have the proper set-up ( resonators etc )
So yeah if you still have the stock Pre cats and you just want to upgrade the j-pipe and delete 3rd cat with your current cat-back it shouldn't sound too bad....
Old Mar 11, 2014 | 05:57 AM
plus, that type of jpipe is OUTDATED.
you shouldnt be even looking at jpipes+test pipes....you should be looking at jpipes that removes the 3rd cat.
www.rv6-p.com
www.heeltoeauto.com
http://store.excelerateperformance.com/
noobs
Old Mar 11, 2014 | 06:11 AM
NvrDwn's Avatar
www.rv6-p.com
www.heeltoeauto.com
noobs
I wouldn't say the atlp is out of date, in fact in theory it's shorter primaries should give the best top end power while the rv6 will give you the most low end and the xlr8 being the middle ground. Though the atlp may only make a 5whp peak advantage over the completion.
Old Mar 11, 2014 | 06:59 AM
everything you just said is negligible.
the gains are so small between the pipes, that it doesnt really matter for the general masses.
to the OP who might not care about small minuscule gains, a jpipe that removes the third cat is a wonderful thing, because then he doesnt have to worry about test pipes.
Old Mar 11, 2014 | 07:37 AM
Nick216's Avatar
The Boss
As my signature says, i have the xlr8 jpipe and catback. I installed the jpipe first but i couldnt even tell a sound difference.
Old Mar 11, 2014 | 03:53 PM
Excelerate's Avatar
Former Sponsor
Installing our V1 j-pipe will net no real difference in sound. Installing our XLR8 V2 j-pipe will eliminate the third cat but it still won't alter the exhaust note that much. I'd recommend our XLR8 V2 j-pipe. It makes more power and is a better design.
Old Mar 11, 2014 | 11:39 PM
Scottwax's Avatar
Mr. Detail
Independent test on v6performance (think the owner posts here too) showed a 10 hp/9 lb-ft gain with the XLR8 V2 vs the V1 and test pipe on a J30.
emailnatec
29
Sep 28, 2018 04:27 PM
soupi
14
Nov 15, 2015 11:15 AM
LeVeL
Oct 18, 2015 04:19 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
