Window roll-up module
Old Sep 27, 2010 | 10:06 AM
EL PESADO's Avatar
hi guys please help me i have installed the viper 5901 in my car and i know if is possible install the window roll up module from this company http://www.kptechnologies.com/produc...l=TL:thumbsup:
Old Sep 27, 2010 | 10:08 AM
yes. that is the window roll up module.
Old Sep 27, 2010 | 10:10 AM
EL PESADO's Avatar
but i heard that module only work with the OEM alarm but i not sure
Old Sep 27, 2010 | 11:22 AM
LoveMyTL-S's Avatar
Can you do the window down with the Viper? If so you should be able to do the window down as well. But if not, then probably cannot do it with the Viper FOB.
Old Sep 27, 2010 | 11:53 AM
EL PESADO's Avatar
not i can;t do the windows down with the viper the shop who installed the viper want $200 for the module for roll up the windows and i was thinking maybe i can do with this other module is more cheap
Old Sep 28, 2010 | 07:16 PM
snake212's Avatar
you dont need an additional module. the tl already has a module for roll up and down. what you need to do is get the viper alarm to pulse a signal to the factory module for window roll up and down. and you also need a relay.
Old Oct 1, 2010 | 03:56 AM
blkonblk05TL's Avatar
i'm pretty sure they just roll down. there's been many threads about getting your windows to roll up with the stock fob. i'm sure an aftermarket fob is no different and possibly easier. as long as you can program a button to pulse how your window roll-up module is set as well. kptechnologies.com
Old Oct 1, 2010 | 03:36 PM
LoveMyTL-S's Avatar
^^^ The stock module is windows down only with the FOB, unless you use your key in the door, then you can do both.
Old Oct 2, 2010 | 12:28 AM
Roger555's Avatar
OCD
You need to get the dei 530t modules pretty easy to install and hook right to your Viper. One unit can control 2 windows down/up auto up when armed etc.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
