Where to route amplifier power cable?
Old Jul 1, 2009 | 10:46 PM
robocam's Avatar
I want to lay down some 8 gauge power cable to the trunk. Where's a good place to run it?
Do I have to remove the rear seat to get the cable into the trunk?
Old Jul 1, 2009 | 11:12 PM
ashkooly's Avatar
you can run it down the left side of the car. you can pull up the plastic pieces at the bottom of the door sill and probably fit it under there.
as for the rear seat, you don't necessarily have remove it to fit the cable through. when i installed my dom's box, i fit two video cables and some power wires through a hole in the right side of the rear seat. I had a snap-on grab tool that i fished through to see if there was a hole and i was able to feed the cables through there. its where the back and bottom cushions of the rear seat meet.
you have the remove the trunk lining in order to see where they come through, and then you can just pull them through.
Old Jul 1, 2009 | 11:29 PM
robocam's Avatar
Thanks for your reply!
When you say "right side of the rear seat," is that the right side when facing forwards? like, the passenger side?
Old Jul 2, 2009 | 12:41 AM
pbcmedia's Avatar
HOME SWEET HOME....
na im sure he's talking about the drivers side of the car as thats the side the battery is on. i ran my power cord from the battery through the firewall, along the drivers side under the plastics through to the trunk... easiest cleanest way
Old Jul 2, 2009 | 01:17 AM
robocam's Avatar
thanks
Did you have to drill into the firewall?
Old Jul 2, 2009 | 08:21 AM
ashkooly's Avatar
sorry, all of my directions i say in terms of standing from the trunk and looking toward the front of the car. so, run your power cable down the driver side because, as stated, that is the side that the battery is on.
the cables i ran, i did on the other side, and i know there is an opening in the seat there. i would only assume it is the same on the driver's side, but i haven't checked.
Old Jul 2, 2009 | 08:32 AM
Trew's Avatar
Here you go dude... This thread will answer ALL of your questions about where to run the amp wire
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
Old Jul 2, 2009 | 08:53 AM
rockstar143's Avatar
I was able to fig 4 gauge into that little channel under the rubber thing on TOP of the door sill...I'm sure 8 will be no problem.
4drviper
Apr 23, 2025 07:13 PM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
ValdezQ26
Oct 1, 2015 04:48 PM
