V710: Need help!
Old Aug 23, 2004 | 08:11 PM
TZVECL's Avatar
V710: Need help!
Can someone help?
1. How do I answer my call-waiting? I tried both steering wheel buttons.
2. How do I transfer to the HFL when I am on the phone and walk into the car?
3. How do I transfer to the V710 when I am on the phone and leave the car?
4. How do I check my cell voicemail? That is, how can I enter digits after the voicemail system kicks in?
5. Same concept: How do I play enter my code on my home answering machine so I can playback my messages?
THANKS!!!
Old Aug 23, 2004 | 08:54 PM
JoganJani's Avatar
never stops!
For 2 and 3. Press phone button and say command TRANSFER. And you will be able to transfer.
Old Aug 23, 2004 | 08:59 PM
TZVECL's Avatar
Thanks joganjani!
Anyone know any of the other answers??
Old Aug 23, 2004 | 09:00 PM
georgeny's Avatar
Originally Posted by TZVECL
Can someone help?
THANKS!!!
3. Just open phone, hit call button and say transfer. Call should now be on phone, works for me.
4. I just dial my own number and voicemail answers and plays message.
5. When machine answers just hit button and say SEND and the code, HFL will start to ask if whatever number, just hit button and say YES or SEND. Same for any number you need to send. I finally got to play some today and realized that I was waiting for to many prompts.
I would say call, then wait for WHAT number, then give number, then wait for prompt when all you have to do is say CALL 555-1212 on first button push. Then as soon as number appears in MID hit button and say DIAL. Much faster, same with phonebook number on first button push CALL My House, soon as number verfies on MID hit button and say DIAL. Mid comes up much faster than voice says prompt.
One this I wish phone book on HFL had was ability to program in a WAIT and second number. I have accounts I check. So first have to dial and number answers requesting account number. I have programmed in account number as a seperate number so can just say SEND account for stock or whatever then SEND. A little longer than just hitting a second number programmed after a wait like on phone.
Voice recognition works well, better when you learn not to try to yell at phone and just talk in a normal voice. Don't know if was just me but I initially had a tendency to talk louder than I normally would.
Old Aug 23, 2004 | 09:03 PM
georgeny's Avatar
Forgot, haven't tried #2 yet and I did get second call today and tried hitting call button didn't answer it. Don't know maybe should say send? Good question hope we both get answer. Will have to check manual in car tomorrow see if it addresse it.
George in NY
Old Aug 23, 2004 | 09:06 PM
boltjames's Avatar
Team Camel Executive VP
Has anyone been able to program in their Verizon voicemail code yet? On the phone, you can program button 1 to access voicemail, wait for the prompt, enter your code, hit pound, and play your first voice message with just one button press.
If you've never done this, go into your phonebook and create an entry called "Voicemail" and assign it the following number:
*86pp#9999#1 (where the 9's are your PIN)
Point this entry to keypad button "1", and you're all set.
Is there a similar funcitonality for the TL? When I enter the above string, the phone/HFL punts me like a bad Windows 95 crash.
Any fix for this? Any way to use the Pause and Pound functions of the HFL to get to message one without any more speech?
TIA
BJ
Old Aug 23, 2004 | 09:51 PM
Legend75's Avatar
This is a great thread, am looking forward to more answers. Keep up the good work guys, as for I just purchased the new V710 as well!
Old Aug 23, 2004 | 11:15 PM
TZVECL's Avatar
Call waiting help anyone??
Old Aug 24, 2004 | 12:11 AM
TZVECL's Avatar
Is my phone working incorrectly?
Is there anyway to set the ringtone so that when I have it on "vibrate" and then I plug it in to charge, it stays on "vibrate" and does NOT change to "Loud"
I understand that most people want to switch it to an audible ring tone when it is plugged in (and off of your belt), but I don't want to wake my family with my cell phone ringing.
On a tangent - somebody please check this - how come in the "vibrate" ring style, no matter what setting you have picked for the keypad volume tone (zero to full blast), I get NO tones at all. Only when there is a ring tone does Moto apparently think you want you want to hear a little button clicking action.
Just my phone??
Old Aug 24, 2004 | 12:28 AM
żGotJazz?'s Avatar
Cesspool of Knowledge
Is there anyway to set the ringtone so that when I have it on "vibrate" and then I plug it in to charge, it stays on "vibrate" and does NOT change to "Loud"?
TZVECL - I don't think that you can prevent the "switch" to "Loud" when plugging it in, but I may have an alternative: Change the "Ring Style Detail" of the "Loud" style to something quiet(er), such as a "Vibrate Dot". You may then want to modify another style (such as "Soft") to make into a "Loud" ring.
It's kind of a kludge, but it does work.
Old Aug 24, 2004 | 12:39 AM
żGotJazz?'s Avatar
TIA
BJ
From what I found (posted elsewhere), putting two HFL "pauses" together causes my V710 to reset.
I haven't found a great "one button" solution to Voicemail yet, but I have a passable one that works about 70% of the time, once I got the timing right:
http://www.acura-tl.com/forums/showp...14&postcount=5
Old Aug 24, 2004 | 09:04 AM
DopeTL04's Avatar
Is there a difference from this and just entering your phone number in keypad "1" and doing the same thing?
TIA
BJ
Old Aug 24, 2004 | 09:10 AM
briden's Avatar
I've got mine set to the following...
*86ppxxxxxx#p1
x=pin numbers
Works just fine on the 710.
Old Aug 24, 2004 | 10:21 AM
bradjs's Avatar
so call waiting doesnt work?
Old Aug 25, 2004 | 02:14 PM
wes01's Avatar
7th Gear
1. You can't answer from the steering wheel buttons and you can't see the caller ID of the second call on the display. The good news is that you can see it on the phone and switch calls as you would normally do by pressing the send key on the phone when connected to the HF Link.
4. Read the manual. You can use the Send command both to send digits or to send previously stored digits by having them saved the under a name in the phonebook.
5. See 4 above.
Old Aug 25, 2004 | 11:04 PM
żGotJazz?'s Avatar
*86ppxxxxxx#p1
x=pin numbers
briden - is this your solution from the HFL side, or the V710 side?
I don't have much of a problem with the V710 side for acessing Voicemail. It's the HFL Voicemail access that drives me nutzo!
żGotJazz?
15
Aug 24, 2004 02:43 PM
żGotJazz?
Aug 10, 2004 08:52 PM
