USA SPEC BT45-HON3 work with broken Nav?
Old Nov 20, 2018 | 01:08 PM
Dbrez8's Avatar
I have an 06 TL with Nav. The Nav no longer works (Disc read error) so I cant access the screen. Alpine now wants $750 to fix these units. Not worth it since I use my phone for nav anyways. XM and all audio features, besides the EQ, sigh.., are working normally through physical buttons.
I'm looking to get the USA SPEC BT45-HON3 for BT audio & AUX. Can anyone confirm if I'll be able to set it up and use it ok without the Nav screen being functional?
Thanks!
Old Nov 25, 2018 | 12:55 PM
ghernz's Avatar
Good question, have the same problem.
Old Dec 3, 2018 | 12:30 AM
donkiboy's Avatar
I've been using the USA SPEC BT45 in my TL after my nav failed. You'll be able to control volume and previous / next song by using the physical buttons on radio & steering wheel. The song info (artist, album, song name) is displayed on that tiny upper screen on our TLs.
The USA SPEC installs directly into the XM tuner in trunk and is accessed by hitting the XM button on factory head unit.
Old Dec 3, 2018 | 09:33 AM
ghernz's Avatar
Thank you!
Old Dec 3, 2018 | 01:54 PM
Dbrez8's Avatar
Awesome, thanks. Did you install after the nav failed or before? Any reason it might be a problem for setup, rather than ongoing use?
Old Dec 4, 2018 | 03:04 PM
donkiboy's Avatar
My NAV failed long before installing the USA SPEC. No problems except that the provided mic need to connect to the USA SPEC module in trunk and route the wire to the front of the car.
If your able to pair your phone with the car's HFL then their provided mic won't be needed.
dookie320
101
May 30, 2022 09:47 AM
RobPE
Jan 4, 2019 01:53 PM
Waffeey
Aug 15, 2017 06:39 PM
Jamie Dominguez
Sep 22, 2016 09:28 PM
SHaFT7
Aug 15, 2015 10:30 AM
