Upgrading the stereo in my '05 TL
I just joined this forum and was hoping to get some advice. I'm looking to upgrade the stereo in my non-navi 05 TL. I just feel that it's a little under powered, and would like a system with a crisper sound. I really don't want to butcher my dash, just looked to add a little power. Any suggestions would be greatly appreciated.
dwa629 (08-13-2011)
Thank you for the reply Trunk Monkey. I guess I'm looking for something a little louder then my current system, with better sound quality. A major priority would be ease of installation. I have recently decided that I'm keeping my TL for the long haul and decided to give it some love by adding a few things that would have come with a newer car, e.i. an ipod hookup etc. As for budget, I don't want to spend too much, as I park the car on the street and don't want to temp vandals. Any thought's?
You won't gain much volume from just speakers. Many people say the stock speakers sound better with an amp. Trouble is you need 6 channels of amplification to do it all. The TL just isnt' an "easy" car to upgrade. What most people seem to start with is buying a good set of components for the front. (id ctx65cs for example) and then adding a 4 channel amp in the rear. Driving the fronts of two channels, and bridge the other two for a sub in a small box. That sort of setup tends to start around $400 if you install it yourself.
Id try amping the stockers first. You'll want an amp eventually anyways.
dwa629 (08-14-2011)
Eggyhustles, are the Infinity 6030 cs no good? Any recommendation for a set of 2 ohm door speakers would really be appreciated. I'm honestly just looking for a little crisper sound, don't feel like having to put in an amp.
Coolest A-zine Member
Lol never seen this
Ok. Most stock units won't power many aftermarket speakers. A replacement in the TL is damn near impossible, but has been done. It has to be custom though and will run you quite a bit.
OP- I think you'd be happy with a component set, 10 or 12 in sealed box and 4-channel amp. Should be able to pick it all up and install it for pretty cheap. You won't get much more out of our stock amp..you need to upgrade now or you'll be back here in a month and end up spending more money than you should have
TL is no exception. You have to get 2 ohm speakers if you're not getting an amp. Those are some slim pickings. replacing the HU is a pain and a half on the TL.
dwa629 (08-16-2011)
So I'm guessing you'll need a loc? I wouldn't wanna mess with the existing hu either!
But couldn't you put one in the cd compartment, similar to the 7th gen accords?
I've heard that the 6030cs are a good pair of front components. I couldn't get them due to their low impedence. Just make sure you get an amp that can handle it. Some have tried to let the stock hu drive it!!! Big nono!
Stockies are 2ohm but only get 40 watts per. You're likely not going to like anything that can be driven by 40 watts. A single 4-channel amp with components and a possible sub in the future would be perfect. I'm not sure why you don't want to go with an amp. If you are worried about the amp install, just take it somewhere and have them run all the cables (power, etc..) for like $50-60. If you found a small amp you could put it under the seat and not have to take up space in the trunk. Shorter cable/speaker wire runs too.
If you're just looking to get more volume and better sound you should start by getting an amp to power the OEM speakers. If you don't want to spend a lot you could just get an amp to power the fronts and sub. I was surprised at how much better they got when I did it. Since you probably want to keep all the speakers running you could let the stock amp power the rears and center. The center is small and doesn't do a lot and rears are just fill anyway (I ended up disconnecting the rears).
You could get a small 4 channel to power the fronts and sub and mount it under the passenger seat. Be careful with the sub because it's 2ohms and most amps won't bridge into 2ohms safely. I guess you could just use one channel for it if you don't want to replace it right away. Adding power to the stock sub sounded quite a bit better as well.
I've replaced speakers without adding power and was totally disappointed with the results. Adding an amp to the stock speakers always net a better return for me.
Adding more power to the stock speakers will make a huge difference...
Wallet raped by my
Y.DO THEY NOT MAKE A RETRO FIT KIT ?
You need 2ohm speakers if you're not getting an amp. Otherwise volume will be very low.
Ive been reading up lately as many TL drivers have the same issue with the OEM system. I'm just wondering if a 3d processor such as the Cleansweep or 360 or anything similar to the like is absolutely necessary or would I be happy with swapping out the fronts with some components and getting a 5 channel amp for all the speakers (running stock center/rears) ?
porkyxp (10-20-2011)
Mistuh DRiiVA
This is worth checking out as well....Im going this way
https://acurazine.com/forums/showthr...=834940&page=1
https://acurazine.com/forums/showthr...1#post13307549
Thanks for the feedback; the plug and play amp does look mighty appealing especially for the DIYers, but I am a bit concerned about losing the center channel and also if it power up aftermarket fronts?
So I'm one of those individuals whom decided to swap out the front speakers to components (massive sk6 stage II components) thinking that the front stage was the most important without considering to swap out the amp; HUGE mistake, but for the fact that using the cassette player with aftermarket sub sounds sufficient for now.
Ive been reading up lately and I've come to the conclusion that the center channel and rear speakers doesn't really need to be changed, as there is little improvement (and function as fillers)... so my question is, is it feasible to get a four channel amp and keep the stock amp running for the center speaker ? Or is this just something really silly for me to think about? OR Would it just be wiser to get a 5channel for the aftermarket fronts, stock rears & center?
Thanks a bunch guys for the response, I was real hesitant to even do this as I didn't think it would be worth getting a processor, aftermarket amp, and dice unit, so it would sound and look clean
I've got to say, that whole "TAPE PLAY" thing On the display is kind of annoying and unfitting, which is why the DICE unit is so desirable, text few! (but not unless the sound quality is good,obviously)
Got The Midas Touch
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
