Type S Best Sub woofer replacement
Old Nov 23, 2010 | 10:18 PM
mani's Avatar
Hey guys,
I am a happy new TL-S owner and theres only one thing that has disappointed me. The sound system. I mean the output is not as justified as expected. To cut the long story short, I would like to know two things:
1) What is a good after market sub that can be swapped with the factory sub.
2) What is the output of the factory amp thats pushing the factory sub.
I have this BAD BOY sitting in my bedroom, but honestly it's going to take too much space in the trunk and not to mention, 85 lbs of more weight to carry.
Old Nov 23, 2010 | 10:30 PM
Build a new box for it and call it a day.
Old Nov 23, 2010 | 11:25 PM
mani's Avatar
This is actually the original Kicker enclosure. I'm not sure if getting a smaller box would have the same quality though.
Again, this bad boy is my last option. If I can sell this for 3 or 400 bucks, I would be more than glad to replace the fac. sub
Old Nov 24, 2010 | 09:15 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
There are no aftermarket subs that will improve the sound. The weak point is that the factory radio and amplifier is pushing at peak 40W @ 2ohm to the factory free air sub.
Old Nov 24, 2010 | 05:32 PM
Trunk Monkey's Avatar
Coolest A-zine Member
If your worried about space then sell that and buy a 10" sub in a ported/sealed box with your amp. Check out Audioque, Sundown...eh..just look on the car audio forums for quality brands haha. Going with a 10" will cut that box in half (just judging by apparent size in the picture) and will still have plenty of bass for ya.
Old Nov 24, 2010 | 08:18 PM
eggyhustles's Avatar
That kicker sub needs a much larger box than that prefab bs
Old Nov 24, 2010 | 08:40 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
that sub does need a bigger box..........lol..............but since you are trying to make space in the trunk , get a custom box, along the side of trunk
Old Nov 25, 2010 | 03:03 PM
cmechilling's Avatar
8th Gear
I just had two Rockford tens put in and had the amp side mounted. I had the wires extra long so I can take the box out if needed and it has made a hell of a lot of difference in the sound. I had one twelve in there and it just did not sound as good. I think adding a extra volume control switch for your subs is a must also, IMO.
Old Nov 28, 2010 | 08:49 PM
mani's Avatar
Thanks all for the info. What about the mids and highs? Is it a good idea keeping em factory while adding the sub ?
Old Nov 28, 2010 | 09:02 PM
jda123's Avatar
Dogmatic Dinosaur
The factory mids and highs are not as weak as the sub. They can wait until later if you have to do one and then the other.
I put a 12" Q in a fiberglass enclosure in the rear corner running about 1300W. It takes up very little space and absolutely slams. If you can get a high efficiency amp (usually means higher resistance near 4 ohms), then you can push these over 1000W with the stock alternator and battery with no dimming and still have room for a component amp.
My system is about 14 pounds for the box, 40 for the sub (what shipping box said - I have not weighed it), 7 for the amp and the weight of the wire.... about 65 pounds or so.
There are some REALLY, REALLY nice 10s that take less than .5 cubic feet and sound great.
Old Nov 28, 2010 | 09:30 PM
No...you start from the front and move your way back.
Old Nov 28, 2010 | 10:02 PM
TeknoKing's Avatar
I'll be selling my custom fiberglass vinyl covered box, jl 12v6, jl 500w amp, kinetic battery... but you will need to soundproof the trunk, breaded it or dynamat it.
The highs and mids are ok in the car, feed two bars more to central speaker.
The stock sub cannot be replaced with anything better, it works best when it is disconnected
Old Nov 28, 2010 | 10:49 PM
mani's Avatar
Originally Posted by teknoking
i'll be selling my custom fiberglass vinyl covered box, jl 12v6, jl 500w amp, kinetic battery... But you will need to soundproof the trunk, breaded it or dynamat it.
lol
Old Nov 28, 2010 | 10:53 PM
mani's Avatar
Ok Lets say, I will be powering the sub using this amp. What would be a good 10 inch sub and what prices are we looking at ?
Old Nov 29, 2010 | 08:31 AM
Keep your current sub and put it in the right box
Old Nov 29, 2010 | 09:07 AM
jda123's Avatar
Dogmatic Dinosaur
If you want to get a new 10", here are some that I have liked in smaller boxes. Look all of these up since I am going off of a terrible, old memory which is probably wrong. These all sound great which is normally what I am looking for.
Sound Solution ICON needs about .75
Image Dynamics IDQ 10 needs about 2/3s
FI Q 10 is less than .5
These are all in the 200 range.
These other guys are right - you might as well try out your current sub in the right box first. You can always sell it later - just don't throw away this box just in case.
Old Nov 30, 2010 | 04:15 PM
Bearcat557's Avatar
For small size with great sound go with a phoenix gold xmax they are a little old but these baby rock I was first suggested them by my friend who owns a car audio store because I needed a small box for my single cab truck box total is 1.5 cubic feet for Max sound quality
Old Nov 30, 2010 | 05:19 PM
The PG xmax can't even compare with the FI Q or the IDmax if you want top notch SQ. Just a sub wont do it though....the box is VERY important.
Old Nov 30, 2010 | 09:27 PM
hp1kw's Avatar
Just buy a JL W7 10 or whatever your budget allows, and push it with that amp and call it a day. Of course I'm prejudiced as I have the 12" in my prelude with a 1000 watt amp. Sounds great. Have used Boston Pros (more SQ than boom), Infinity, Polk, but none of the smaller brands. Also off topic, but the JL Audio Home subs are incredible and I believe they are using the same W7 driver.
Old Dec 6, 2010 | 02:59 PM
xxx_busa's Avatar
morel ultimo sc12, don't believe a word from anyone else, I've got the best sounding audio system on the board.
Feb 25, 2020 09:57 AM
Skirmich
Sep 15, 2015 06:41 PM
ellisd03tls
Sep 8, 2015 04:17 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
