Remote start w/ factory key fob how to???
Old Dec 6, 2010 | 06:45 PM
Turbocoop's Avatar
Ive been searching for a while and so far what Ive found out is it IS possible to hook up a remote start using your factory key fob with the DEI 561T Valet system. I couldn't find a real "how-to", but Im sure I could figure it out once I order it and get the wiring diagrams... Now that its freezing balls outside Ive decided to do this mod to my car- so what Im wanting to know is there already a how to on this that I just haven't been able to find? If not- would anyone be interested in me making one once I do this?
Ive been trying to see if a solution was ever found to the problem people were having of not being able to unlock/lock the car once the remote start was engaged with the engine running- I couldn't find a definite solution for that either. Also has anyone figured out a way to extend the short ass range of the factory fob? I'd have to do something with that too because mine only works from like 50' away max...
If you have this remote start or have any info please feel free to chime in, Id like to get as much info together as possible before getting started. Thanks
Old Dec 6, 2010 | 06:55 PM
Turbocoop's Avatar
Apparently the DEI 561T is discontinued and was replaced with the Avital 4003, so Ill probably get that one. Its a little cheaper anyway
Old Dec 7, 2010 | 01:34 AM
ciscopath's Avatar
You sound like me 2 years ago. I bought the 561T system. Bought two of them in fact. Wouldn’t work for crap so I hope the Avital is a much better product. I doubt you’ll find any info on how to boost the range of the factory fob on this forum. More range equals more power either to the fob itself or the receiver under the dash. The time you spend researching and performing trial/error at the risk of messing up your TL, you could have bought an aftermarket system pre-built with two-mile range plus other features. I’m sure that’s the general consensus here.
If you still want to go through with this, there is a way to use your fob while the car is running. Here’s info I got years ago.
Originally Posted by PeterUbers
Yes, to bypass the BECU input such that you can use your keyfob (Acura keyfobs) you can basically wire as follows, i think it's the yellow wire you splice ( i wrote a DIY in one of the threads on that):
Pin 85: 12 volts
Pin 86: Ground while running (-)
Pin 87: empty (no wires connect here)
Pin 87a: to BECU side of split yellow wire
Pin 30: to other end of split yellow wire
The yellow wire mentioned runs to the fob receiver (BECU) underneath the dash right above the brake pedal. Can’t miss it. When the car is running, the wire becomes energized basically telling the receiving to stop accepting any commands from the fob. What you would need is a 30-40 amp SPDT relay. Cut the yellow wire and make the connections mentioned above. I always wondered if the relay was necessary since cutting the wiring would mean the BECU would not know the car was running. Guess it prevents throwing a code or something. Since the 561T didn’t work for me and I now have Viper, guess I’ll never know. Don’t really see PeterUbers around here anymore but he was chockfull of info about this. Couldn’t hurt hitting him up or searching for his DIY
Old Dec 7, 2010 | 07:00 PM
Turbocoop's Avatar
Yeah I read about that yellow wire thing in all the old threads I found while looking for info. So you could never get the 561T to work with the remote start at all??? Thats weird, how much time/money did you waste? The only reason I was thinking about going with this is to save money, Im fine with the stock alarm system I just want remote start- The Avital 4003 is only like $65 and I can get a relay for free... I guess Ill keep researching, I almost ordered the 4003 last night- Im glad I waited. Thanks a bunch for the info
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
asahrts
Sep 4, 2015 05:55 PM
