Tweeters blew...how?
Old May 24, 2012 | 09:21 PM
slammedon19'''s Avatar
i just put them in today was cranking them for awhile and then they gave up but only my 2front 1s not the back 1s and there all the same they felt hot before they went there memphis too but are not silk how and why
Old May 24, 2012 | 10:41 PM
Trunk Monkey's Avatar
Coolest A-zine Member
They felt hot before you blew them? What?
What's your setup? ....gonna need more info
Old May 25, 2012 | 01:25 AM
lc6i
ok i got the lc6i went post amp how should it be wired i have a 4 channel amp for my components front and rear and a 2channel sub amp
Old May 25, 2012 | 05:42 AM
Opel's Avatar
Not enough info for anyone to determine why they blew.
How did you wire components? Did you use x overs?
What are their ratings?
What amp? Ratings?
How did you set up the lc6?
You said you were cranking them.... What were your amp gain settings?
Too much voltage can blow them. Maybe you wired them on the wrong terminals on the xovers
Old May 25, 2012 | 08:49 AM
If you were playing them fine on and at a decent level, I would assume you blew them due to over driving them (too much gain/voltage) AND/OR your x-over point was too low and at a moderate volume it's okay, but at high volumes it didn't like it too much
Old May 25, 2012 | 09:10 AM
I hate cars's Avatar
If you did not use a crossover, that's why you blew them. The stock tweeters have a cap built onto the tweeter. If you just hooked them up to the stock wiring, you were putting a full range signal to them but they should have sounded terrible before they blew.
Old May 25, 2012 | 11:37 AM
DiamondJoeQuimby's Avatar
Codename Duchess
Too much average power over time. That's how.
Old May 25, 2012 | 12:59 PM
Agreed. Wouldn't you say WAY too much power over time if the tweeters were hot to the touch? What do tweeters usually get, 10w? 20w? I think he had too much power because he was running a full range signal to them. Going back to read his old threads and see if that's the case.
Old May 25, 2012 | 11:42 PM
Codename Duchess
Was actually being a bit of a smartass. Since that's how all speakers blow.
Old May 26, 2012 | 12:30 AM
ok
so should i just hook the front and rears to the main input on the lc6i cause i have it hooked up now to main front sounds good but the back sounds like crap back is on channel 2
Old May 26, 2012 | 12:33 AM
You haven't given us any info.
Old May 26, 2012 | 01:31 AM
ok
i have a 4channel amp,lc61,2 sets of components with crossovers, have it post amp,main channel on lc6i with fronts hooked up and 2nd channel with backs,amp is on hp mode. what info are u looking for please explain im about to quit man please help me out
Old May 26, 2012 | 09:48 AM
rich20730's Avatar
You should really just take it to a shop and have them hook it up for you. It will probably save you a lot of time and frustration and prevent you from damaging more of your equipment.
Old May 26, 2012 | 03:44 PM
pohljm's Avatar
I would suggest you do alot more research or pay a professional. If you keep on this trial and error path your going to spend all your money to replace damaged equipment.
Old May 27, 2012 | 12:52 AM
i got it
i can only run my components to the main channel cause channal 2 on lc6i is full range and channel 3 is sub
Old May 27, 2012 | 01:21 AM
As long as you run the crossover that came with your components with new speaker wire run from the crossovers to the tweeters you should be ok. You would have to really hammer on them to blow the tweeters if it's hooked up properly.
To be clear, the only thing the tweeter should be directly hooked up to is a crossover, not directly to any other piece of equipment. If you used the stock wiring without running new wire, you did not have a crossover in the mix unless there was a cap at the tweeter itself.
Old May 28, 2012 | 12:07 AM
called memphis
they said i got bad x overs i was pissed so ijust got me some pioneer 6.5 3ways and put them on and for 160 bucks i cant believe the sound they are so clear will be getting my 400 bucks back from memphis
Old May 28, 2012 | 12:58 AM
3-way as in a "triaxial" or a 3-way comp set? I love a 3-way comp set. All else being equal they just sound better in every way, are easier to tune, and get louder while maintaining clarity.... all else being equal.
If it's the other one, you will likely have other issues such as stage issues but if it sounds good to you and you're happy, that's all that matters. Do you have a link to the ones you purchased?
Old May 28, 2012 | 10:28 AM
Opel's Avatar
I doubt he installed 3-way comps so quickly lol, and for 160 they got to be just 3-way speakers
Old May 28, 2012 | 11:39 AM
To be fair to Memphis, if you give the tweeter a full range signal it's going to sound horrible.
Old May 28, 2012 | 04:15 PM
pepboys or walmart
they sound great clairity is amazing u be surprized how they sound and for 160 u cant beat that with a bat lol
Old May 28, 2012 | 05:45 PM
Clarity should sound decent as they're playing 80-20kHz
...what a tweeter SHOULDN'T play
4drviper
Apr 23, 2025 07:13 PM
Feb 25, 2020 09:57 AM
akbears15
15
Nov 5, 2015 07:06 AM
sockr1
Oct 1, 2015 01:31 AM
ilike2cheez
Dec 28, 2001 05:35 PM
