Trunk Rattle
Old Jul 6, 2012 | 02:35 PM
Hoodtl's Avatar
Trunk Rattle
Hey guys,
I installed 2 12 in alpine Type e's and for the first week or so there was no rattling. After a couple of weeks my trunk rattles as soon as I turn my volume above 20. Any idea's on how to fix this myself instead of taking it somewhere?
Thanks,
Old Jul 6, 2012 | 03:37 PM
pohljm's Avatar
Identify the source of the rattle and deaden it. No sense taking it to someone thats going to do the same thing.
Old Jul 6, 2012 | 04:18 PM
I hate cars's Avatar
Agreed. If it's the common license plate and license plate frame, that's an easy fix. Put a little deadener behind the plate and make sure to use all 4 bolts. As for the frame, I removed mine. It looks cleaner to me and I could never get the rattles to completely stop.
If it's inside of the car, there are a lot of threads on this. The easiest route is sticking a piece of cardboard or anything soft between the rear shelf and the glass.
Old Jul 6, 2012 | 05:44 PM
Hoodtl's Avatar
I don't have a frame on mine either but I can only get 3 of my screws in because one of my screws broke in half inside the thread due to rust. The spot between the shelf and window is a big part of the rattle so I will try that. The other source I feel like is the trunk itself. If I stand behind the car and push the trunk down it will stop the rattle sound. I also dyno matted the license plate and that seemed to help some. Any suggestions on the trunk would be great.
Old Jul 6, 2012 | 05:56 PM
stevemk07's Avatar
I found that the direction the woofer and ports are facing and proximity to the edges of the trunk affected rattles. Now I have my woofer pointed to the front with no phase or rattle issues. No matter what though that rear shelf needs to be cushioned between it and the glass of the rear window. To fix the license plate issue I rolled up some electrical tape sticky side out and placed it between the plate and trunk.
Old Jul 6, 2012 | 08:54 PM
pohljm's Avatar
CLD tiles on the outer skin may help you as well
Old Jul 9, 2012 | 08:53 AM
jda123's Avatar
Dogmatic Dinosaur
Remove the weight in the trunk lid. It makes a lot of noise... at least mine did.
Old Jul 9, 2012 | 10:19 AM
imakeholesinu's Avatar
There is also another thread about this. Apparently it was a chronic problem with 3G TL's. This might help as well.
https://acurazine.com/forums/3g-tl-problems-fixes-114/rear-deck-bass-rattle-fix-%5Bpics-video%5D-614680/
baelim
May 10, 2018 09:53 AM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
