For those who purchased the ST-800 smart system
Old Aug 5, 2011 | 05:15 PM
  #161
lahma's Avatar
turn st800 start push button light off
Originally Posted by Noober
another thing i noticed is that, the push start button always stays illuminated? is there a way to wire it so it doesn't?
im heading back to the installers house to finish up the install tonight.
Yes, you can turn the start button light off in the options through the keypad... very easy to do.
Old Aug 8, 2011 | 09:17 AM
  #162
moreace's Avatar
Anthracite Trend Setter
Keypad is an interesting piece. It seems to have limited usefulness. People who have Ford's love to lock their keys in the car when they don't have or want them in their pocket. I.e. taking the dog on a run, going to the gym, etc. I assume you can't lock your key in the car here as it would be in proximity and keep the doors unlocked.
Old Aug 8, 2011 | 01:15 PM
  #163
moreace's Avatar
Can this unit be set to only unlock the drivers door when in proximity or does it open all doors?
Old Aug 8, 2011 | 07:04 PM
  #164
rhafikjaan's Avatar
love everything about it except the location of where the keypad is placed
Old Aug 8, 2011 | 07:08 PM
  #165
rhafikjaan's Avatar
ok 1 more question..what if the st800 doesn't work..how else would we start the car?
Old Aug 8, 2011 | 07:43 PM
  #166
moreace's Avatar
From reading multiple posts, it does not affect your stock key and key fob. You could operate the vehicle traditionally. The kit has a cap that covers your stock ignition. Pop it off, grab your old key and go. That assumes you don't mount the button over the ignition.
My problem is, I have a Whistler Pro 3450 radar to the left of the wheel where the button is shown. Not sure there is a good/ obvious flat surface to the right of the column to mount it.
Old Aug 8, 2011 | 07:58 PM
  #167
rhafikjaan's Avatar
for example you get in your car drive 200 miles away from home. come to the car and for some reason the ST800 isn't working. You don't have the car key on you..what do you do?
Old Aug 8, 2011 | 08:04 PM
  #168
moreace's Avatar
Call AAA. Some people are saying you have to cut a key and leave it in the ignition, you can use that.
Leave a light on and kill the car battery though and you are completely screwed and can't even get in the car.
Old Aug 8, 2011 | 10:29 PM
  #169
MasterShake's Avatar
Say you're 200 miles from home and blow two tires? What then? What if an elephant sits on your hood?
The ST800 failing is just about as likely as blowing two tires or, more realistically, just losing the keys somewhere.
Old Aug 10, 2011 | 02:55 AM
  #170
lahma's Avatar
There is an emergency mode where you type in your password on your keypad and your serial # and it will let you start/operate your car.
Old Aug 15, 2011 | 11:50 AM
  #171
Mafyoso's Avatar
Balling in the...
Yeah Im thinking about selling the Alarm... I heard from a Local Installer that the watts the alarm sends ranges from 4-24 and our car can only use 4 watts. Anymore than 4 it can Fry the electronics and wiring in the dash. So Im still Up in the air about this alarm. I love the Concept but if its gonna fuck my shit up I rather just put something else in
Old Aug 27, 2011 | 09:30 AM
  #172
JTS97Z28's Avatar
Im bringing this thread back as im very interested in adding a keyless access/push start system on my 07 TLS 6mt. I like the Alibaba system however what worries me is the horrible instructions that barely make sense. I guess it was all translated from a different language and didnt work out too well. The system seems perfect but some of the stuff I dont really want such as the alarm system or remote start. I mainly wanted just keyless access and push start, but I REALLY like their flat push button that requires no holes in your dash.
Here is another system which seems much easier to read and understand that does exactly what I want, but uses a Lexus push start button which would require putting a huge deep hole in the dash: http://www.advancedkeys.com/index.htm
A few questions...for guys with manuals do you still need to do the key in key cylinder and left in ACC mode to bypass the steering lock? I dont really want to have to put a key in my ignition and leave it there and in acc mode...which obviously means completely cutting the ACC wire which I dont want to do either.
Also, what modules are best to use for immobilizers and data integration? like a combo kit that does both in one. Do these also allow you to catch all the necessary wires right at the module as well such as door locks, tach, alarm etc etc?
I have experience doing alarms and remote starts but its been years since I have messed with that crap.
EDIT: After going downstarirs and checking it does not appear that my steering column locks on my 2007 6mt Type S. So does that mean I can eliminate a huge step by not having to leave a key in my igntition and in acc mode?
Thanks guys,
james
Old Aug 27, 2011 | 08:16 PM
  #173
lahma's Avatar
JTS, I have the st800 installed in my 04 tl (automatic) and it is a great alarm... once you get it installed (did it myself). It has a lot of cool, customizable features that have not been discussed here, probably cause you kinda have to play around with it, bc the instructions are not well translated (or not translated at all (weird Korean symbols or something lol)). Dowontec does also offer a unit JUST FOR PUSHBUTTON START. I saw it on their website. They even offer a "touch-start", the button senses touch, it doesn't depress. Check out their website, I don't know much about the other products. If you need any help, shoot me a pm. The MAIN problem you have to figure out is the ACC and IGN wires. The instructions don't explain it right, and as far as I can tell, the TL should be treated as if it has 2 ignition wire and 1 accessory wire (although all the wiring diagrams that exist call the 3 wires ACC 1, ACC 2, and IGN.) This took me 3 days to figure out (although it shouldn't have.) Good luck bro. Oh, and as far as using a data bus setup, that would save a lot of time, but there are still some things it wont do (wires u will still have to tap.) I'm not sure if you will have to leave a key in ur ignition since you have a manual, but I suspect you will. But hell, if your steering column doesn't lock, then I don't see why you'd have to. There is a great keyless transponder override on Amazon for about 40 bucks, I think.
Old Aug 27, 2011 | 09:15 PM
  #174
JTS97Z28's Avatar
Awesome thanks for the input on the ST800. I did go through their website and after lots of thinking, I think I might just go with the much simpler touch start system. I know this system does not have all the other fancy things such as remote start, keyless access, but for now I think I would rather just have full push start for now.
Im gonna drop you a PM for some addition info.
Thanks,
James
Old Aug 27, 2011 | 10:34 PM
  #175
Nice!
Old Sep 14, 2011 | 03:55 PM
  #176
dubxrossd11's Avatar
S.3.A
I'm very interested in getting these now. *White Angel* where are you located? or at least the guy that does your install for you? I live in NH but I'm considering driving down to NJ just to get it installed (maybe go on a weekend vacation while I'm at it ). I would really like these done properly and cleanly and I don't know any good places around where I live that I feel like I can trust.
Also, would I be able to put the button over the existing keyhole? I like how it lights up blue around the keyhole and I think it would be cool to have that blue circle around the start button.
Old Sep 15, 2011 | 08:23 AM
  #177
lahma's Avatar
You can put the button over the keyhole, but after much debating, I mounted mine on the dash. It just doesnt look right on the keyhole to me... Plus its really natural to have the button on the side of the dash that you get in the car on. Its very easy to turn the car off while standing outside of it with your hands full the way I have it: http://youtu.be/2p2VhrJpilY and http://youtu.be/eSHjJWmbVEY
Old Sep 18, 2011 | 03:27 PM
  #178
philland2002's Avatar
i man can i give you my email for help me to instal this
thank you
Old Sep 19, 2011 | 07:04 AM
  #179
lahma's Avatar
Thumbs up
thank you
Check your PM bro.
Old Oct 6, 2011 | 04:14 PM
  #180
mike2020's Avatar
Installer
Hey totally interested in this system but i am not about to try to do this by myself. i own an 05 RSX-s it is a standard transmission i am just completely lost in the sauce on the install I Live in Oceanside CA so a southern california installer would be what i need if you are an installer and confident in your ability with this system please email me at mbrandon7191984@gmail.com that way we can talk about the system what i need and pricing once again i appreciate everything
MIKE
Old Nov 12, 2011 | 09:04 AM
  #181
NAMco's Avatar
I took mine to the installer yesterday and we got stuck. The remote wasn't properly linked to the main control unit so the car wouldn't start with the push button. The remote buttons didn't work at all, however, I could unlock/lock the car with the keypad. I didn't try starting it via keypad though. If any of you have ran into this problem could you please help me configure the remote or did it come pre-programmed? Thanks for any help.
Old Nov 12, 2011 | 09:53 AM
  #182
NAMco's Avatar
Just went back and re-read the whole thread. I'll see if I can get this to work.
Old Jan 16, 2012 | 10:20 AM
  #183
kumar07's Avatar
hi i live in ga and want to get this installed.. does anyone know a place in ga
Originally Posted by **WhItE-aNgEl**
Anyone in new jersey or willing to travel to nj. PM me and I can set you up an appointment with my installer.He's does a great job and he will take 2-3 hours with the install now that's he's familiar with it. He charges $175. And it's worth it due to the headache this install is.
Old Feb 22, 2012 | 08:40 PM
  #184
Cali_Joker's Avatar
i found this great video, a DIY !!!!!! well, although its not for the TL hopefully it can shed some light as to how to install this yourself or to show an installer so he can have somewhat of an idea . i still have my st800 in the box because i havent found a shop or should i say an installer who is confident enough of his skills to do it . im gonna show this to some shops now . check it out guys :
Old Apr 11, 2012 | 09:19 PM
  #185
twigglius's Avatar
we live in a simulation
Is there an option to have a push start installed in the original igntion spot?
Old Apr 29, 2012 | 08:24 AM
  #186
NBP-UA6's Avatar
BUMP!
Anyone wanna give an update to how they are holding up after almost a year?
Old Apr 29, 2012 | 05:55 PM
  #187
lahma's Avatar
My st800 is holding up great! I think this alarm is DEFINITELY money well spent. I can't tell you how nice it is to not have to worry about keys or alarm fobs... just leave it in my wallet 24/7.
Old May 7, 2012 | 01:24 AM
  #188
vancity67's Avatar
I have a question .. Doesn't this affect the memory seats n settings? When I watch white angels video I notice u have memory seats?? And reading a post abt it might fry the other electronics got me worried a bit too cuz I have navi m Bluetooth which I wouldn't wanna risk frying so I was wondering if anyone who installed this system with navi n memory seats and such?
Old May 7, 2012 | 01:49 AM
  #189
lahma's Avatar
Just like ANY alarm, if its not installed right (or just installed lazily) there can be problems. That's the reason why afteruch debating , I decided to install myself. You must have someone that REALLY knows electronics to install this. An inexperienced installer who has experience only installing over the counter mainstream alarms,is going to run into problems. I admit, the instructions aren't the best. The alarm has in no way affected any of my other electronics, including my memory seats. I have not noticed any of the strange voltage issues reported by 1 person on here.
Old May 7, 2012 | 09:46 AM
  #190
vancity67's Avatar
So it will still detect u as driver 1 and automatically change all settings back if say someone else drove the car and moved the seats and such once u walk to the door it will still reg u and change back the setting? And yea that's the other thing I worried about it to find a shop who's gonna be able to do this right cuz I know I won't be able to diy this myself .. And I wonder if there's any difference at all between a us model and a Canadian model of the tl?
Old May 7, 2012 | 02:07 PM
  #191
Mafyoso's Avatar
Balling in the...
So Yeah Im deff Installing this soon. Just waiting for my Installer to give me a date. He told me Ill have to leave the car all day on a Sunday so he can do it. Just still waiting cause Sundays are his days off...
Old Jun 17, 2012 | 09:12 PM
  #192
sl0067's Avatar
We can make our windows open and close without buying any extra parts just with the aux ports? If I wanted my windows to close as I walk away and the car locks. Would I need an extra module?
Yes you can control the window up and down without buying any additional module. All you have to do is tap the AUX1 and AUX2 wires to the window controls. Then program AUX1 and AUX2 to output for 7 seconds of continuos pulse.
Old Feb 1, 2014 | 07:22 PM
  #193
marzxbarz's Avatar
Bump.
How are all your units holding up? I'm looking to install something similar (EasyGo Universal) in the East Bay (CA) so if anyone can recommend a shop in the SF Bay Area, that'd be much appreciated. Thanks!
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Nov 4, 2019 06:44 AM
Sep 15, 2015 06:44 PM
Gianni Formica
Sep 7, 2015 08:28 PM
DRR98
1G RDX Problems & Fixes
Sep 2, 2015 10:52 AM
