sub amp qustion
Old Dec 5, 2006 | 09:32 AM
RJANACONDA's Avatar
Registered TL Lover
sub amp qustion
looking to add some bass to my tl and was wondering for those that done this what do you look for in an amp other than the obvious chanel/watt to match the sub you pick out
Old Dec 5, 2006 | 09:47 AM
MrKinn's Avatar
Your sub and amp dont have to match... Go with what u can afford.... U wanna spend money there are alot of high end amps out there.. JL has a nice amp.. memphis xtant, there are tons.. Look at pics and see what people are running.. there really is no secret other then what u mentioned@! goodluck
Old Dec 5, 2006 | 09:53 AM
RJANACONDA's Avatar
Registered TL Lover
what i meant by match is if say sub can handel 300watts peak for example paying the extra money for one that can put out 1000watts but what about cooling if i see two amp say mtx that are identical with the exception that one is fan cooled buts cost more and is bigger should i go for the one with fan cooling i have notice about a even number of amps that have cooling with those that dont so far so just looking at that fact to me not knowing much about amps that is isnt absolutly neccicary or they would prettymuch all have them
JOES05tl's Avatar
If you arent upgrading your mids and highs, then don't go over 800-1000 watts. If you do, it will be strongly out of balance. I made this mistake, and now I need to upgrade all my other speakers! I have 4000watts of bass(subs & amp) with the factory speakers for highs. W/ volume on 3, you cant hear the treble or mids, just tons of crunchy trunk-rattling bass. Overkill-
Old Dec 5, 2006 | 09:58 AM
RJANACONDA's Avatar
Registered TL Lover
well i want to go with the infinity kapapa perfect and an something in a amp around 250-300 since the sub can handle 75-350 that way i should have plent of power and i shouldnt have to worry about overdoing the sub
Old Dec 5, 2006 | 04:12 PM
Crook's Avatar
I'm not sure which Kappa Perfect or how many subs you'll be using but it's better to have a little more power over the RMS than not having enough. A little more power will give you a tighter/cleaner bass. Some weak amps will choke/clip which creates distortion. This can also overheat the voice coil leading to premature failure or a blown speaker. I think the Kappa Perfect has a high max rating so it may be able to handle the heat for extended periods.
Here are some basic features to look for on a sub amp:
Brand and previous customer ratings or comments
Price or Hot deal
4 and 2 ohm stable, rated RMS power based on your speaker(s) wiring/set up.
Speaker- and preamp-level inputs
Bass boost or EQ
Selectable subsonic filter
Size/dimensions depending on your install or space limitation
Signal-Sensing Turn-On
Turn-on delay to prevent a thump or pop when you start your car
Internal, variable-speed cooling fan if you plan on encasing it during your install
Old Dec 5, 2006 | 04:45 PM
randomthought's Avatar
rebmeM deretsigeR
JL audio is nice. Not very cheap, but worth it imo. I've got the 500/1 monoblock with 2 10w3v2 in a prowedge box. Sounds great, except for the crappy oem speakers.
Old Dec 6, 2006 | 12:56 AM
jthmmv's Avatar
So would a memphis 1000w amp with a memphis 12" sub sound nasty?? with factory head unit and factory mids and highs??
Old Dec 6, 2006 | 04:49 PM
BukvaMan's Avatar
Kicker SX line if you ask me, i just got two four channel - Im in love with them and there is a difference in amplifiers big time
Old Dec 6, 2006 | 06:25 PM
ChicoOG's Avatar
Zapco...iForce line. Zapcos are one of, if not the best amps out there. The iForce line in very affordable and better than others top of the line stuff. Their customer support is excellent as well www.zapco.com
I second the comment about keeping things in balance...it is easy to drown out the stock mids and highs. I did, and had to upgrade amps, speakers, etc... to get everything balanced out.
Good luck with the upgrade
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
