Stock Sub
Stock Sub
I am adding a 12 kicker cvr sub and a planet audio 850 watt. What is the best setup for the stock sub? Remove it or just unplug it or just run it with my new sub? What is everyones opinion? Also where is everyone mounting the LOC in the trunk
most ppl remove the stock sub. this exposes a positive and negative wire. Then wire the LOC to these wires in the stock sub's location.
the LOC will provide an RCA connection to connect to the amp.
Most people do it this way, so that they have factory headunit control of the aftermarket sub. this is also the easiest way.
Dogmatic Dinosaur
The line output converter on the stock sub wire is a good way to go. The control is very nice from the headunit as mentioned above.
You can leave the stock sub in the car unplugged. If you remove it, you expose a hole where more sound can get from your trunk to the interior of the car.
You can access the plug if you take the upper trunk liner off. To take the sub out, you need to remove the rear seats, a-pillar trim and the deck lid.
The gold(yellow)/black wire is the positive on the connector.
Keep in mind also that removing stock sub that reduces the structural integrity of rear deck so if you don't dynamat the who deck, it will rattle to all hell.
svttec I bought a add a fuse at the auto store for like 5 bucks I'm gonna tap into the accessory fuse! Thanks for the heads up on the rear deck parasurfer not being stable I didn't think of that. I will have to mod something up to sturdy it!
DerrickW
11-15-2015 05:52 PM
