Stock amp wiring diagram to help install my 3sixty.1
If anyone out there has a diagram of the stock amp with labeled output and input please help. I'm going to be installing a Rockford 3sixty.1 and need the diagram to install it.
Yeah I'm planning to install the 3sixty.1 after the stock amp not before. Also I was wondering if I can use the same power and remote that goes into the stock amp to power my 3sixty. Last but not least also debating about placing it near the stock amp or in the trunk.
Is this what you need?
You ask and you shall receive ....
@ the Stereo Amplifier in the passenger kick panel in the 20 pin Black & White connector
RF+ Black
RF- Gray
LF+ Green
LF- Blue
C+ Brown
C- Greeen w/White
RR+ Orange
RR- Red
LR+ White
LR- Yellow
SW+ Red w/Blue
SW- White w/Green
Remote Turn-on -> Red w/Yellow
Amp Mute -> Yellow w/Green
RF+ Black
RF- Gray
LF+ Green
LF- Blue
C+ Brown
C- Greeen w/White
RR+ Orange
RR- Red
LR+ White
LR- Yellow
SW+ Red w/Blue
SW- White w/Green
In addition ....
@ the Stereo Amplifier in the passenger kick panel with the 14 pin gray connector contains the speaker outputs if you want to utilize the factory wiring.
RF+ Blue
RF- Red
LF+ Light Green
LF- Purple
C+ Green w/White
C- Blue w/Yellow
RR+ Red w/Blue
RR- Yellow
LR+ Brown w/White
LR- Red w/Yellow
SW+ Yellow w/Black
SW- Light Green w/Red
Ground -> Black
+12V -> White
RF+ Blue
RF- Red
LF+ Light Green
LF- Purple
C+ Green w/White
C- Blue w/Yellow
RR+ Red w/Blue
RR- Yellow
LR+ Brown w/White
LR- Red w/Yellow
SW+ Yellow w/Black
Ground -> Black
+12V -> White
in case you're not done, i put mine under the passenger seat. Theres just barely enough clearance under the seat and holes in the carpet to make grounding it and running wires very easy.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
alan_rich
09-07-2015 11:08 PM
yahelou
09-06-2015 09:12 PM
